[Liblas-commits] hg: clean up liblas::Point::Header rename from the previous efforts
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jun 21 15:49:31 EDT 2011
details:   http://hg.liblas.orghg/rev/cfc25597300c
changeset: 2973:cfc25597300c
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jun 21 14:49:27 2011 -0500
description:
diffstat:
 include/liblas/point.hpp |   2 +-
 src/point.cpp            |  34 +++++++++++++++++-----------------
 2 files changed, 18 insertions(+), 18 deletions(-)
diffs (131 lines):
diff -r 4b49b8d9631d -r cfc25597300c include/liblas/point.hpp
--- a/include/liblas/point.hpp	Tue Jun 21 14:02:39 2011 -0500
+++ b/include/liblas/point.hpp	Tue Jun 21 14:49:27 2011 -0500
@@ -219,7 +219,7 @@
     std::vector<boost::uint8_t>::size_type GetDimensionBytePosition(std::size_t dim_pos) const;
     // HeaderPtr m_header;
-    HeaderOptionalConstRef m_header_new;
+    HeaderOptionalConstRef m_header;
     Header const& m_default_header;
diff -r 4b49b8d9631d -r cfc25597300c src/point.cpp
--- a/src/point.cpp	Tue Jun 21 14:02:39 2011 -0500
+++ b/src/point.cpp	Tue Jun 21 14:49:27 2011 -0500
@@ -66,7 +66,7 @@
 Point::Point()
     // m_header(HeaderPtr())
-     m_header_new(HeaderOptionalConstRef())
+     m_header(HeaderOptionalConstRef())
     , m_default_header(DefaultHeader::get())
@@ -77,7 +77,7 @@
 Point::Point(HeaderPtr hdr)
     // m_header(hdr)
-     m_header_new(HeaderOptionalConstRef(*hdr))
+     m_header(HeaderOptionalConstRef(*hdr))
     m_data.resize(ePointSize3);
@@ -87,7 +87,7 @@
 Point::Point(Point const& other)
     : m_data(other.m_data)
     // , m_header(other.m_header)
-    , m_header_new(HeaderOptionalConstRef(other.GetHeader()))
+    , m_header(HeaderOptionalConstRef(other.GetHeader()))
@@ -98,7 +98,7 @@
         m_data = rhs.m_data;
         // m_header = rhs.m_header;
-        m_header_new = rhs.m_header_new;
+        m_header = rhs.m_header;
     return *this;
@@ -321,7 +321,7 @@
         throw liblas_error("header reference for SetHeader is void");
-    if (!m_header_new) m_header_new = header;
+    if (!m_header) m_header = header;
     boost::uint16_t wanted_length;
@@ -333,12 +333,12 @@
     //FIXME: check boost::optional returns
-    if (detail::compare_distance(header->GetScaleX(), m_header_new->GetScaleX()) &&
-        detail::compare_distance(header->GetScaleY(), m_header_new->GetScaleY()) &&
-        detail::compare_distance(header->GetScaleZ(), m_header_new->GetScaleZ()) &&
-        detail::compare_distance(header->GetOffsetX(), m_header_new->GetOffsetX()) &&
-        detail::compare_distance(header->GetOffsetY(), m_header_new->GetOffsetY()) &&
-        detail::compare_distance(header->GetOffsetZ(), m_header_new->GetOffsetZ()))
+    if (detail::compare_distance(header->GetScaleX(), m_header->GetScaleX()) &&
+        detail::compare_distance(header->GetScaleY(), m_header->GetScaleY()) &&
+        detail::compare_distance(header->GetScaleZ(), m_header->GetScaleZ()) &&
+        detail::compare_distance(header->GetOffsetX(), m_header->GetOffsetX()) &&
+        detail::compare_distance(header->GetOffsetY(), m_header->GetOffsetY()) &&
+        detail::compare_distance(header->GetOffsetZ(), m_header->GetOffsetZ()))
         bSetCoordinates = false;
     else
         bSetCoordinates = true;
@@ -355,7 +355,7 @@
         data.resize(wanted_length);
         data.assign(wanted_length, 0);
         m_data = data;
-        m_header_new = header;
+        m_header = header;
         return;
@@ -366,13 +366,13 @@
         // layout is likely changing as a result of the
         // schema change.
         Point p(*this);
         std::vector<boost::uint8_t> data;
         m_data = data;
         SetX(p.GetX());
         SetY(p.GetY());
@@ -410,7 +410,7 @@
     // The header's scale/offset can change the raw storage of xyz.
     // SetHeaderPtr can result in a rescaling of the data.
     if (bSetCoordinates)
@@ -423,7 +423,7 @@
 HeaderOptionalConstRef Point::GetHeader() const
-    if (m_header_new) return m_header_new; else return HeaderOptionalConstRef(m_default_header);
+    if (m_header) return m_header; else return HeaderOptionalConstRef(m_default_header);
 liblas::property_tree::ptree Point::GetPTree() const
@@ -1074,7 +1074,7 @@
 std::vector<boost::uint8_t>::size_type Point::GetDimensionBytePosition(std::size_t dim_pos) const
     boost::optional<Dimension const&> d;
-    d = m_header_new->GetSchema().GetDimension(dim_pos);
+    d = m_header->GetSchema().GetDimension(dim_pos);
     if (!d)
More information about the Liblas-commits mailing list
