[Liblas-commits] hg-main-tree: rename to pdal
liblas-commits at liblas.org
Wed Jun 22 12:35:03 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/440b2f7c1a9c
changeset: 796:440b2f7c1a9c
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jun 22 09:34:57 2011 -0700
description:
rename to pdal
diffstat:
csharp/libpc_swig_cpp/libpc.i | 445 ---------------------------
csharp/libpc_swig_cpp/libpc_swig_cpp.vcxproj | 185 -----------
csharp/pdal_swig_cpp/libpc.i | 445 +++++++++++++++++++++++++++
csharp/pdal_swig_cpp/libpc_swig_cpp.vcxproj | 185 +++++++++++
4 files changed, 630 insertions(+), 630 deletions(-)
diffs (truncated from 1278 to 300 lines):
diff -r 845bcaad6665 -r 440b2f7c1a9c csharp/libpc_swig_cpp/libpc.i
--- a/csharp/libpc_swig_cpp/libpc.i Tue Jun 21 12:49:00 2011 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,445 +0,0 @@
- * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
- * Purpose: swig/C# bindings for liblas
- * Author: Michael P. Gerlek (mpg at flaxen.com)
- * Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-%module pdal_swig_cpp
-#include <iostream>
-#include "pdal/pdal_config.hpp"
-#include "pdal/Bounds.hpp"
-#include "pdal/Range.hpp"
-#include "pdal/Dimension.hpp"
-#include "pdal/DimensionLayout.hpp"
-#include "pdal/Schema.hpp"
-#include "pdal/SchemaLayout.hpp"
-#include "pdal/PointData.hpp"
-#include "pdal/Header.hpp"
-#include "pdal/Stage.hpp"
-#include "pdal/Filter.hpp"
-#include "pdal/Producer.hpp"
-#include "pdal/DecimationFilter.hpp"
-#include "pdal/../../src/drivers/liblas/header.hpp"
-#include "pdal/../../src/drivers/liblas/reader.hpp"
-%include "typemaps.i"
-// C# support for std::string
-%include "std_string.i"
-// C# support for std::vector<T>
-%include "std_vector.i"
-namespace std
- %template(std_vector_u8) vector<unsigned char>;
- %template(std_vector_double) vector<double>;
- %template(std_vector_Dimension) vector<pdal::Dimension>;
- %template(std_vector_Range_double) vector<pdal::Range<double> >;
-// fix up some missing types
-namespace std
- typedef unsigned int size_t;
-%include "std/std_iostream.i"
-namespace boost
- typedef unsigned char uint8_t;
- typedef signed char int8_t;
- typedef unsigned short uint16_t;
- typedef signed short int16_t;
- typedef unsigned int uint32_t;
- typedef signed int int32_t;
- typedef unsigned long long uint64_t;
- typedef signed long long int64_t;
-namespace pdal
-template <typename T>
-class Range
-public:
- typedef T value_type;
- Range();
- Range(T minimum, T maximum);
- T getMinimum() const;
- void setMinimum(T value);
- T getMaximum() const;
- void setMaximum(T value);
- bool equal(Range const& other) const;
- bool overlaps(Range const& r) const;
- bool contains(Range const& r) const;
- bool contains(T v) const;
- bool empty(void) const;
- void clip(Range const& r);
- void grow(T v);
- void grow(Range const& r);
- void grow(T lo, T hi);
- T length() const;
-%rename(Range_double) Range<double>;
-%template(Range_double) Range<double>;
-class Vector
-public:
- Vector();
- Vector(T v0);
- Vector(T v0, T v1);
- Vector(T v0, T v1, T v2);
- Vector(std::vector<T> v);
- T get(std::size_t index);
- void set(std::size_t index, T v);
- void set(std::vector<T> v);
- bool equal(Vector const& other) const;
- std::size_t size() const;
-%rename(Vector_double) Vector<double>;
-%template(Vector_double) Vector<double>;
-class Bounds
-public:
- typedef typename std::vector< Range<T> > RangeVector;
- Bounds( T minx,
- T miny,
- T minz,
- T maxx,
- T maxy,
- T maxz);
- Bounds(const Vector<T>& minimum, const Vector<T>& maximum);
- T getMinimum(std::size_t const& index) const;
- void setMinimum(std::size_t const& index, T v);
- T getMaximum(std::size_t const& index) const;
- void setMaximum(std::size_t const& index, T v);
- Vector<T> getMinimum();
- Vector<T> getMaximum();
- RangeVector const& dimensions() const;
- bool equal(Bounds<T> const& other) const;
- bool overlaps(Bounds const& other) const;
- bool contains(Vector<T> point) const;
- bool contains(Bounds<T> const& other) const;
- void clip(Bounds const& r);
- void grow(Bounds const& r);
- void grow(Vector<T> const& point);
- T volume() const;
- bool empty() const;
-%rename(Bounds_double) Bounds<double>;
-%template(Bounds_double) Bounds<double>;
-class Dimension
-public:
- enum Field
- Field_INVALID = 0,
- Field_X,
- Field_Y,
- Field_Z,
- Field_Intensity,
- Field_ReturnNumber,
- Field_NumberOfReturns,
- Field_ScanDirectionFlag,
- Field_EdgeOfFlightLine,
- Field_Classification,
- Field_ScanAngleRank,
- Field_UserData,
- Field_PointSourceId,
- Field_GpsTime,
- Field_Red,
- Field_Green,
- Field_Blue,
- Field_WavePacketDescriptorIndex,
- Field_WaveformDataOffset,
- Field_ReturnPointWaveformLocation,
- Field_WaveformXt,
- Field_WaveformYt,
- Field_WaveformZt,
- // add more here
- Field_User1 = 512,
- Field_User2,
- Field_User3,
- Field_User4,
- Field_User5,
- Field_User6,
- Field_User7,
- Field_User8,
- Field_User9,
- // feel free to use your own int here
- Field_LAST = 1023
- enum DataType
- Int8,
- Uint8,
- Int16,
- Uint16,
- Int32,
- Uint32,
- Int64,
- Uint64,
- Float, // 32 bits
- Double // 64 bits
-public:
- Dimension(Field field, DataType type);
- std::string const& getFieldName() const;
- Field getField() const;
- DataType getDataType() const;
- static std::string getDataTypeName(DataType);
- static DataType getDataTypeFromString(const std::string&);
- static std::size_t getDataTypeSize(DataType);
- static bool getDataTypeIsNumeric(DataType);
- static bool getDataTypeIsSigned(DataType);
- static bool getDataTypeIsInteger(DataType);
- static std::string const& getFieldName(Field);
- std::size_t getByteSize() const;
- inline std::string getDescription() const;
- inline void setDescription(std::string const& v);
- inline bool isNumeric() const;
- inline bool isSigned() const;
- inline bool isInteger() const;
- inline double getMinimum() const;
- inline void setMinimum(double min);
- inline double getMaximum() const;
- inline void setMaximum(double max);
- inline double getNumericScale() const;
- inline void setNumericScale(double v);
- inline double getNumericOffset() const;
- inline void setNumericOffset(double v);
- template<class T>
- double applyScaling(T x) const;
- inline bool isFinitePrecision() const;
- inline void isFinitePrecision(bool v);
-%extend Dimension
- %template(getNumericValue_Int32) applyScaling<boost::int32_t>;
-class DimensionLayout
More information about the Liblas-commits
