[Liblas-commits] hg: remove the libxml cmake config,
which has never been used
liblas-commits at liblas.org
Thu Jun 23 10:53:27 EDT 2011
details: http://hg.liblas.orghg/rev/bc17a199464d
changeset: 2999:bc17a199464d
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jun 23 09:53:22 2011 -0500
description:
remove the libxml cmake config, which has never been used
diffstat:
CMakeLists.txt | 14 --------------
1 files changed, 0 insertions(+), 14 deletions(-)
diffs (24 lines):
diff -r d3f7e33c647d -r bc17a199464d CMakeLists.txt
--- a/CMakeLists.txt Thu Jun 23 08:45:13 2011 -0500
+++ b/CMakeLists.txt Thu Jun 23 09:53:22 2011 -0500
@@ -193,20 +193,6 @@
link_directories(${Boost_LIBRARY_DIRS})
-# libxml2 support - optional, default=ON
-set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
-if(WITH_LIBXML2)
- find_package(LibXml2)
- mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
- mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
- if(LIBXML2_FOUND)
- include_directories(${LIBXML2_INCLUDE_DIR})
- add_definitions(-DHAVE_LIBXML2=1)
- endif()
-endif()
# GDAL/OGR support - optional, default=OFF
set(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
More information about the Liblas-commits
