[Liblas-commits] hg: ignore unused parameter when no HAVE_GDAL
liblas-commits at liblas.org
Thu Jun 23 15:57:01 EDT 2011
details: http://hg.liblas.orghg/rev/35d23fe15154
changeset: 3004:35d23fe15154
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jun 23 14:40:23 2011 -0500
description:
Subject: hg: ignore unused parameter when no HAVE_GDAL
details: http://hg.liblas.orghg/rev/2ccda9fbe7d4
changeset: 3005:2ccda9fbe7d4
date: Thu Jun 23 14:45:40 2011 -0500
description:
Subject: hg: clean up type comparison warning
details: http://hg.liblas.orghg/rev/64eaab02ad89
changeset: 3006:64eaab02ad89
date: Thu Jun 23 14:56:47 2011 -0500
description:
Subject: hg: clean up unused parameter warnings
details: http://hg.liblas.orghg/rev/ccdb2052657f
changeset: 3007:ccdb2052657f
date: Thu Jun 23 14:56:54 2011 -0500
description:
diffstat:
include/liblas/detail/opt_allocator.hpp | 3 +++
src/c_api.cpp | 2 +-
src/spatialreference.cpp | 3 +++
3 files changed, 7 insertions(+), 1 deletions(-)
diffs (52 lines):
diff -r 370cddd89833 -r ccdb2052657f include/liblas/detail/opt_allocator.hpp
--- a/include/liblas/detail/opt_allocator.hpp Thu Jun 23 14:35:03 2011 -0500
+++ b/include/liblas/detail/opt_allocator.hpp Thu Jun 23 14:56:54 2011 -0500
@@ -107,6 +107,7 @@
opt_allocator(const opt_allocator<T>& other )
+ boost::ignore_unused_variable_warning(other);
template <typename U>
@@ -161,6 +162,8 @@
else
::operator delete(p);
+ boost::ignore_unused_variable_warning(num);
void construct(pointer p, const_reference value)
diff -r 370cddd89833 -r ccdb2052657f src/c_api.cpp
--- a/src/c_api.cpp Thu Jun 23 14:35:03 2011 -0500
+++ b/src/c_api.cpp Thu Jun 23 14:56:54 2011 -0500
@@ -550,7 +550,7 @@
if (d.size() != size)
d.resize(size);
- d.assign(0, size);
+ d.assign(0, d.size());
for (boost::uint16_t i=0; i < size; i++) {
diff -r 370cddd89833 -r ccdb2052657f src/spatialreference.cpp
--- a/src/spatialreference.cpp Thu Jun 23 14:35:03 2011 -0500
+++ b/src/spatialreference.cpp Thu Jun 23 14:56:54 2011 -0500
@@ -137,6 +137,7 @@
return bool(output == 1);
#else
+ boost::ignore_unused_variable_warning(input);
throw std::runtime_error ("SpatialReference equality testing not available without GDAL+libgeotiff support");
#endif
@@ -938,6 +939,8 @@
return ostr;
#else
+ boost::ignore_unused_variable_warning(ostr);
+ boost::ignore_unused_variable_warning(srs);
throw std::runtime_error("SpatialReference io operator<< is not available without GDAL+libgeotiff support");
#endif
More information about the Liblas-commits
