[Liblas-commits] hg: support setting the raw data via python #237
liblas-commits at liblas.org
Thu Jun 23 16:52:30 EDT 2011
details: http://hg.liblas.orghg/rev/193fe2fc0028
changeset: 3012:193fe2fc0028
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Jun 23 15:52:24 2011 -0500
description:
diffstat:
python/liblas/core.py | 20 ++++++-------
python/liblas/point.py | 72 +++++++++++--------------------------------------
2 files changed, 25 insertions(+), 67 deletions(-)
diffs (110 lines):
diff -r 4c54e0703399 -r 193fe2fc0028 python/liblas/core.py
--- a/python/liblas/core.py Thu Jun 23 15:30:31 2011 -0500
+++ b/python/liblas/core.py Thu Jun 23 15:52:24 2011 -0500
@@ -341,17 +341,15 @@
las.LASPoint_GetXML.argtypes = [ctypes.c_void_p]
las.LASPoint_GetXML.errcheck = free_returned_char_p
-# las.LASPoint_GetExtraData.argtypes = [ctypes.c_void_p,
-# ctypes.POINTER(ctypes.POINTER(ctypes.c_ubyte)),
-# ctypes.POINTER(ctypes.c_int)]
-# las.LASPoint_GetExtraData.errcheck = check_value
-# las.LASPoint_GetExtraData.restype = ctypes.c_int
-# las.LASPoint_SetExtraData.argtypes = [ctypes.c_void_p,
-# ctypes.POINTER(ctypes.c_ubyte),
-# ctypes.c_int]
-# las.LASPoint_SetExtraData.errcheck = check_value
-# las.LASPoint_SetExtraData.restype = ctypes.c_int
+las.LASPoint_GetData.argtypes = [ctypes.c_void_p,
+ ctypes.POINTER(ctypes.c_ubyte)]
+las.LASPoint_GetData.errcheck = check_value
+las.LASPoint_GetData.restype = ctypes.c_int
+las.LASPoint_SetData.argtypes = [ctypes.c_void_p,
+las.LASPoint_SetData.errcheck = check_value
+las.LASPoint_SetData.restype = ctypes.c_int
las.LASPoint_Create.restype = ctypes.c_void_p
las.LASPoint_Create.errcheck = check_void
diff -r 4c54e0703399 -r 193fe2fc0028 python/liblas/point.py
--- a/python/liblas/point.py Thu Jun 23 15:30:31 2011 -0500
+++ b/python/liblas/point.py Thu Jun 23 15:52:24 2011 -0500
@@ -554,60 +554,20 @@
return core.las.LASPoint_GetXML(self.handle)
xml = property(get_xml, None, None, None)
+ def get_data(self):
+ length = self.header.data_record_length
+ d = (ctypes.c_ubyte*length)()
+ d2 = ctypes.cast(d, ctypes.POINTER(ctypes.c_ubyte))
+ core.las.LASPoint_GetData(self.handle, d2)
+ return d
- # def descale(self, header):
- # """Descales the point with a given :obj:`liblas.header.Header` instance
- # :param header: A header with :obj:`liblas.header.Header.offset` and \
- # :obj:`liblas.header.Header.scale` values set"""
- # self.x = (self.x - header.offset[0]) / header.scale[0]
- # self.y = (self.y - header.offset[1]) / header.scale[1]
- # self.z = (self.z - header.offset[2]) / header.scale[2]
- # def scale(self, header):
- # """Scales the point with a given :obj:`liblas.header.Header` instance
- # self.x = (self.x * header.scale[0]) + header.offset[0]
- # self.y = (self.y * header.scale[1]) + header.offset[1]
- # self.z = (self.z * header.scale[2]) + header.offset[2]
- # def get_data(self):
- # l = ctypes.pointer(ctypes.c_int())
- # d = ctypes.pointer(ctypes.c_ubyte())
- # core.las.LASPoint_GetExtraData(self.handle, ctypes.byref(d), l)
- # d2 = ctypes.cast(d, ctypes.POINTER(ctypes.c_ubyte * l.contents.value))
- # s = (ctypes.c_ubyte * l.contents.value)()
- # for i in range(l.contents.value):
- # s[i] = d2.contents[i]
- # p_d = ctypes.cast(d, ctypes.POINTER(ctypes.c_char_p))
- # core.las.LASString_Free(p_d)
- # return s
- # def set_data(self, data):
- # d = ctypes.cast(data, ctypes.POINTER(ctypes.c_ubyte))
- # core.las.LASPoint_SetExtraData(self.handle, d, len(data))
- # doc = """Extra byte data for the point. You can attach a variable amount
- # of extra data to each individual point by setting the
- # :obj:`liblas.header.Header.dataformat_id` to a valid value, and then
- # setting the :obj:`liblas.header.Header.data_record_length` to a value that
- # is larger than the nominal length for that format as noted in the
- # specification_.
- # Interpreting the data is up to the user, however. Because these are raw
- # bytes, you can store any additional data that you wish.
- # .. note::
- # The data will be clipped to exactly the
- # :obj:`liblas.header.Header.data_record_length` when they are actually
- # written to the file. If you set data on the point that is larger than
- # the difference between the nominal point format data record length and
- # the data record length you set in the header, it will be thrown away.
- # data = property(get_data, set_data, None, doc)
+ def set_data(self, data):
+ d = ctypes.cast(data, ctypes.POINTER(ctypes.c_ubyte))
+ core.las.LASPoint_SetData(self.handle, d, len(data))
+ doc = """Raw data for the point. Shoot yourself in the foot if you must!
+ data = property(get_data, set_data, None, doc)
More information about the Liblas-commits
