[Liblas-commits] hg: put a boost::scoped_ptr<LASzip> to manage VLR and point size...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Jun 24 16:10:47 EDT 2011
details:   http://hg.liblas.orghg/rev/f2f79555e12b
changeset: 3014:f2f79555e12b
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Jun 24 14:57:25 2011 -0500
description:
put a boost::scoped_ptr<LASzip> to manage VLR and point size stuff in ZipPoint
Subject: hg: use a boost::scoped_ptr instead of a naked array for exception safety for m_lz_point_data
details:   http://hg.liblas.orghg/rev/e9bf37763cf5
changeset: 3015:e9bf37763cf5
date:      Fri Jun 24 15:10:33 2011 -0500
description:
diffstat:
 include/liblas/detail/zippoint.hpp |   11 +-
 src/detail/reader/zipreader.cpp    |    2 +-
 src/detail/zippoint.cpp            |  164 +++++++++++++-----------------------
 3 files changed, 70 insertions(+), 107 deletions(-)
diffs (255 lines):
diff -r 6013e0dcb9cc -r e9bf37763cf5 include/liblas/detail/zippoint.hpp
--- a/include/liblas/detail/zippoint.hpp	Fri Jun 24 10:53:42 2011 -0500
+++ b/include/liblas/detail/zippoint.hpp	Fri Jun 24 15:10:33 2011 -0500
@@ -49,10 +49,13 @@
 // boost
 #include <boost/cstdint.hpp>
 #include <boost/shared_ptr.hpp>
+#include <boost/scoped_ptr.hpp>
+#include <boost/scoped_array.hpp>
 // liblaszip
 class LASzipper;
 class LASitem;
+class LASzip;
 namespace liblas { namespace detail {
@@ -72,7 +75,7 @@
     bool IsZipVLR(const VariableRecord& vlr) const;
 private:
-    void ConstructItems(PointFormatName);
+    void ConstructItems(unsigned char, unsigned short);
 public: // for now
     // LASzip::pack() allocates/sets vlr_data and vlr_num for us, and deletes it for us  ["his"]
@@ -82,10 +85,10 @@
     int our_vlr_num;
     unsigned char* our_vlr_data;
-    unsigned int m_num_items;
-    LASitem* m_items;
+    boost::scoped_ptr<LASzip> m_zip;
     unsigned char** m_lz_point;
-    unsigned char* m_lz_point_data;
+    boost::scoped_array<boost::uint8_t> m_lz_point_data;
     unsigned int m_lz_point_size;
diff -r 6013e0dcb9cc -r e9bf37763cf5 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp	Fri Jun 24 10:53:42 2011 -0500
+++ b/src/detail/reader/zipreader.cpp	Fri Jun 24 15:10:33 2011 -0500
@@ -231,7 +231,7 @@
         unsigned int size = m_zipPoint->m_lz_point_size;
         assert(size == data.size());
-        unsigned char* p = m_zipPoint->m_lz_point_data;
+        unsigned char* p = m_zipPoint->m_lz_point_data.get();
         data.assign(p, p+size);
         ++m_current;
diff -r 6013e0dcb9cc -r e9bf37763cf5 src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp	Fri Jun 24 10:53:42 2011 -0500
+++ b/src/detail/zippoint.cpp	Fri Jun 24 15:10:33 2011 -0500
@@ -66,13 +66,13 @@
     , his_vlr_data(0)
     , our_vlr_num(0)
     , our_vlr_data(0)
-    , m_num_items(0)
-    , m_items(NULL)
     , m_lz_point(NULL)
     , m_lz_point_data(NULL)
     , m_lz_point_size(0)
-    ConstructItems(format);
+    boost::scoped_ptr<LASzip> s(new LASzip());
+    m_zip.swap(s);
     const VariableRecord* vlr = NULL;
     for (unsigned int i=0; i<vlrs.size(); i++)
@@ -94,100 +94,6 @@
-    return;
-ZipPoint::~ZipPoint()
-    m_num_items = 0;
-    delete[] m_items;
-    m_items = NULL;
-    delete[] m_lz_point;
-    delete[] m_lz_point_data;
-    delete[] our_vlr_data;
-    return;
-void ZipPoint::ConstructItems(PointFormatName format)
-    switch (format)
-    case ePointFormat0:
-        m_num_items = 1;
-        m_items = new LASitem[1];
-        m_items[0].type = LASitem::POINT10;
-        m_items[0].size = 20;
-        break;
-    case ePointFormat1:
-        m_num_items = 2;
-        m_items = new LASitem[2];
-        m_items[1].type = LASitem::GPSTIME11;
-        m_items[1].size = 8;
-        break;
-    case ePointFormat2:
-        m_num_items = 2;
-        m_items[1].type = LASitem::RGB12;
-        m_items[1].size = 6;
-        break;
-    case ePointFormat3:
-        m_num_items = 3;
-        m_items = new LASitem[3];
-        m_items[2].type = LASitem::RGB12;
-        m_items[2].size = 6;
-        break;
-    default:
-        throw liblas_error("Bad point format in header");
-    // construct the object that will hold a laszip point
-    // compute the point size
-    m_lz_point_size = 0;
-    for (unsigned int i = 0; i < m_num_items; i++)
-        m_lz_point_size += m_items[i].size;
-    // create the point data
-    unsigned int point_offset = 0;
-    m_lz_point = new unsigned char*[m_num_items];
-    m_lz_point_data = new unsigned char[m_lz_point_size];
-    for (unsigned i = 0; i < m_num_items; i++)
-        m_lz_point[i] = &(m_lz_point_data[point_offset]);
-        point_offset += m_items[i].size;
-    return;
-void ZipPoint::ConstructVLR(VariableRecord& v, PointFormatName format) const
-    boost::uint16_t record_length_after_header = (boost::uint16_t)(34+6*m_num_items);
-    // set the header
-    v.SetReserved(0xAABB);
-    v.SetUserId(laszip_userid);
-    v.SetRecordId(laszip_recordid);
-    v.SetRecordLength(record_length_after_header);
-    v.SetDescription(laszip_description);
     unsigned char pointFormat = 0;
     unsigned short pointSize = 0;
     switch (format)
@@ -212,14 +118,62 @@
         throw liblas_error("point format not supported by laszip");
-    LASzip laszip;
-    laszip.setup(pointFormat, pointSize);
+    m_zip->setup(pointFormat, pointSize);
-    LASzipper zipper;
+    ConstructItems(pointFormat, pointSize);
+    return;
+ZipPoint::~ZipPoint()
+    delete[] m_lz_point;
+    delete[] our_vlr_data;
+    return;
+void ZipPoint::ConstructItems(unsigned char pointFormat, unsigned short size)
+    if (!m_zip->setup(pointFormat, size))
+        std::ostringstream oss;
+        oss << "Error setting up LASzip for format " << pointFormat <<": " << m_zip->get_error();
+        throw liblas_error(oss.str());
+    // construct the object that will hold a laszip point
+    // compute the point size
+    m_lz_point_size = 0;
+    for (unsigned int i = 0; i < m_zip->num_items; i++)
+        m_lz_point_size += m_zip->items[i].size;
+    // create the point data
+    unsigned int point_offset = 0;
+    m_lz_point = new unsigned char*[m_zip->num_items];
+    boost::scoped_array<boost::uint8_t> d( new boost::uint8_t[ m_lz_point_size ] );
+    m_lz_point_data.swap(d);
+    for (unsigned i = 0; i < m_zip->num_items; i++)
+        m_lz_point[i] = &(m_lz_point_data[point_offset]);
+        point_offset += m_zip->items[i].size;
+    return;
+void ZipPoint::ConstructVLR(VariableRecord& v, PointFormatName format) const
     unsigned char* data;
     int num;
-    laszip.pack(data, num);
+    m_zip->pack(data, num);
     // Ick.
     std::vector<boost::uint8_t> vdata;
@@ -227,7 +181,13 @@
         vdata.push_back(data[i]);
+    // set the header
+    v.SetReserved(0xAABB);
+    v.SetUserId(laszip_userid);
+    v.SetRecordId(laszip_recordid);
+    v.SetRecordLength(num);
+    v.SetDescription(laszip_description);
     v.SetData(vdata);
     v.SetRecordLength((boost::uint16_t)num);
More information about the Liblas-commits mailing list
