[Liblas-commits] hg: Use the m_zipPoint's LASzip instead of one on
the writer
liblas-commits at liblas.org
Mon Jun 27 15:05:00 EDT 2011
details: http://hg.liblas.orghg/rev/a2f492012245
changeset: 3022:a2f492012245
user: Howard Butler <hobu.inc at gmail.com>
date: Mon Jun 27 14:04:52 2011 -0500
description:
Use the m_zipPoint's LASzip instead of one on the writer
diffstat:
include/liblas/detail/writer/zipwriter.hpp | 1 -
include/liblas/detail/zippoint.hpp | 2 ++
src/detail/writer/zipwriter.cpp | 22 ++++++++--------------
3 files changed, 10 insertions(+), 15 deletions(-)
diffs (103 lines):
diff -r 73bc7006a148 -r a2f492012245 include/liblas/detail/writer/zipwriter.hpp
--- a/include/liblas/detail/writer/zipwriter.hpp Mon Jun 27 12:29:38 2011 -0500
+++ b/include/liblas/detail/writer/zipwriter.hpp Mon Jun 27 14:04:52 2011 -0500
@@ -99,7 +99,6 @@
private:
boost::uint32_t m_pointCount;
- boost::scoped_ptr<LASzip> m_zip;
boost::scoped_ptr<LASzipper> m_zipper;
boost::scoped_ptr<ZipPoint> m_zipPoint;
diff -r 73bc7006a148 -r a2f492012245 include/liblas/detail/zippoint.hpp
--- a/include/liblas/detail/zippoint.hpp Mon Jun 27 12:29:38 2011 -0500
+++ b/include/liblas/detail/zippoint.hpp Mon Jun 27 14:04:52 2011 -0500
@@ -73,6 +73,8 @@
bool ValidateVLR(const VariableRecord& vlr) const;
bool IsZipVLR(const VariableRecord& vlr) const;
+ LASzip* GetZipper() const { return m_zip.get(); }
private:
void ConstructItems(unsigned char, unsigned short);
diff -r 73bc7006a148 -r a2f492012245 src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp Mon Jun 27 12:29:38 2011 -0500
+++ b/src/detail/writer/zipwriter.cpp Mon Jun 27 14:04:52 2011 -0500
@@ -64,7 +64,6 @@
//m_point_writer(PointWriterPtr( )),
m_header_writer(HeaderWriterPtr()),
m_pointCount(0),
- m_zip(NULL),
m_zipper(NULL),
m_zipPoint(NULL)
@@ -101,12 +100,8 @@
void ZipWriterImpl::WritePoint(liblas::Point const& point)
- if (!m_zip)
+ if (!m_zipPoint)
- // Initialize a scoped_ptr and swap it with our member variable
- // that will contain it.
- boost::scoped_ptr<LASzip> s(new LASzip());
- m_zip.swap(s);
PointFormatName format = m_header->GetDataFormatId();
@@ -114,19 +109,19 @@
m_zipPoint.swap(z);
bool ok = false;
- ok = m_zip->setup((unsigned char)format, m_header->GetDataRecordLength());
+ ok = m_zipPoint->GetZipper()->setup((unsigned char)format, m_header->GetDataRecordLength());
if (!ok)
std::ostringstream oss;
- oss << "Error opening compression core: " << std::string(m_zip->get_error());
+ oss << "Error opening compression core: " << std::string(m_zipPoint->GetZipper()->get_error());
throw liblas_error(oss.str());
- ok = m_zip->pack(m_zipPoint->his_vlr_data, m_zipPoint->his_vlr_num);
+ ok = m_zipPoint->GetZipper()->pack(m_zipPoint->his_vlr_data, m_zipPoint->his_vlr_num);
if (!ok)
- oss << "Error packing VLR data for compression: " << std::string(m_zip->get_error());
+ oss << "Error packing VLR data for compression: " << std::string(m_zipPoint->GetZipper()->get_error());
@@ -138,11 +133,11 @@
bool stat(false);
- stat = m_zipper->open(m_ofs, m_zip.get());
+ stat = m_zipper->open(m_ofs, m_zipPoint->GetZipper());
if (!stat)
- oss << "Error opening LASzipper: " << std::string(m_zip->get_error());
+ oss << "Error opening LASzipper: " << std::string(m_zipPoint->GetZipper()->get_error());
@@ -162,7 +157,7 @@
if (!ok)
- oss << "Error writing compressed point data: " << std::string(m_zip->get_error());
+ oss << "Error writing compressed point data: " << std::string(m_zipper->get_error());
++m_pointCount;
@@ -182,7 +177,6 @@
m_zipPoint.reset();
- m_zip.reset();
m_zipper.reset();
More information about the Liblas-commits
