[Liblas-commits] hg-main-tree: lint, for builds without GDAL
liblas-commits at liblas.org
Mon Jun 27 16:00:17 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/98ae80605e4e
changeset: 814:98ae80605e4e
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Jun 27 12:56:41 2011 -0700
description:
diffstat:
src/SpatialReference.cpp | 6 ++++++
src/drivers/las/VariableLengthRecord.cpp | 6 ++++++
src/filters/ReprojectionFilter.cpp | 10 ++++++++--
3 files changed, 20 insertions(+), 2 deletions(-)
diffs (95 lines):
diff -r 533f0b8c911e -r 98ae80605e4e src/SpatialReference.cpp
--- a/src/SpatialReference.cpp Mon Jun 27 12:30:57 2011 -0700
+++ b/src/SpatialReference.cpp Mon Jun 27 12:56:41 2011 -0700
@@ -37,6 +37,7 @@
#include <boost/concept_check.hpp>
#include <boost/property_tree/xml_parser.hpp>
+#include <boost/concept_check.hpp> // ignore_unused_variable_warning
// gdal
@@ -279,6 +280,7 @@
return (output==1);
#else
+ boost::ignore_unused_variable_warning(input);
throw pdal_error ("SpatialReference equality testing not available without GDAL+libgeotiff support");
#endif
@@ -295,6 +297,8 @@
return ostr;
#else
+ boost::ignore_unused_variable_warning(ostr);
+ boost::ignore_unused_variable_warning(srs);
throw pdal_error ("SpatialReference io operator<< is not available without GDAL+libgeotiff support");
#endif
@@ -329,6 +333,8 @@
return istr;
#else
+ boost::ignore_unused_variable_warning(istr);
throw pdal_error ("SpatialReference io operator>> is not available without GDAL+libgeotiff support");
#endif
diff -r 533f0b8c911e -r 98ae80605e4e src/drivers/las/VariableLengthRecord.cpp
--- a/src/drivers/las/VariableLengthRecord.cpp Mon Jun 27 12:30:57 2011 -0700
+++ b/src/drivers/las/VariableLengthRecord.cpp Mon Jun 27 12:56:41 2011 -0700
@@ -34,6 +34,8 @@
#include <pdal/drivers/las/VariableLengthRecord.hpp>
#include <pdal/SpatialReference.hpp>
#include "GeotiffSupport.hpp"
@@ -288,6 +290,9 @@
const std::string wkt = geotiff.getWkt(false,false);
srs.setFromUserInput(wkt);
+#else
+ boost::ignore_unused_variable_warning(vlrs);
#endif
return true;
@@ -437,6 +442,7 @@
vlrs.push_back(record);
#endif
+ boost::ignore_unused_variable_warning(modeFlag);
std::string wkt = srs.getWKT( SpatialReference::eCompoundOK );
diff -r 533f0b8c911e -r 98ae80605e4e src/filters/ReprojectionFilter.cpp
--- a/src/filters/ReprojectionFilter.cpp Mon Jun 27 12:30:57 2011 -0700
+++ b/src/filters/ReprojectionFilter.cpp Mon Jun 27 12:56:41 2011 -0700
@@ -34,6 +34,8 @@
#include <pdal/filters/ReprojectionFilter.hpp>
#include <pdal/Dimension.hpp>
#include <pdal/Schema.hpp>
#include <pdal/exceptions.hpp>
@@ -197,9 +199,13 @@
msg << "Could not project point for ReprojectionTransform::" << CPLGetLastErrorMsg() << ret;
throw std::runtime_error(msg.str());
+#else
+ boost::ignore_unused_variable_warning(x);
+ boost::ignore_unused_variable_warning(y);
+ boost::ignore_unused_variable_warning(z);
+#endif
return;
-#endif
More information about the Liblas-commits
