[Liblas-commits] hg: add total length output for VLRs
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jun 28 16:21:59 EDT 2011
details:   http://hg.liblas.orghg/rev/67a04c839a8d
changeset: 3030:67a04c839a8d
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jun 28 13:10:36 2011 -0500
description:
Subject: hg: turn off header padding preservation for now
details:   http://hg.liblas.orghg/rev/0c10f5e95f23
changeset: 3031:0c10f5e95f23
date:      Tue Jun 28 15:21:05 2011 -0500
description:
Subject: hg: try to consolidate LASzip* creation and management into the ZipPoint class
details:   http://hg.liblas.orghg/rev/47fa1baf1aa4
changeset: 3032:47fa1baf1aa4
date:      Tue Jun 28 15:21:50 2011 -0500
description:
diffstat:
 include/liblas/detail/zippoint.hpp |   2 +-
 src/detail/reader/zipreader.cpp    |  25 ++++++-------------------
 src/detail/writer/header.cpp       |   7 +++----
 src/detail/writer/zipwriter.cpp    |  17 -----------------
 src/detail/zippoint.cpp            |  31 ++++++++++++++++++++++---------
 src/variablerecord.cpp             |   2 ++
 6 files changed, 34 insertions(+), 50 deletions(-)
diffs (202 lines):
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 include/liblas/detail/zippoint.hpp
--- a/include/liblas/detail/zippoint.hpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/include/liblas/detail/zippoint.hpp	Tue Jun 28 15:21:50 2011 -0500
@@ -77,7 +77,7 @@
     LASzip* GetZipper() const { return m_zip.get(); }
 private:
-    void ConstructItems(unsigned char, unsigned short);
+    void ConstructItems();
 public: // for now
     // LASzip::pack() allocates/sets vlr_data and vlr_num for us, and deletes it for us  ["his"]
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/src/detail/reader/zipreader.cpp	Tue Jun 28 15:21:50 2011 -0500
@@ -95,6 +95,9 @@
     m_ifs.clear();
     m_ifs.seekg(0);
+    m_zipPoint.reset();
+    m_unzipper.reset();
     // Reset sizes and set internal cursor to the beginning of file.
     m_current = 0;
     m_size = m_header->GetPointRecordsCount();
@@ -108,24 +111,6 @@
         PointFormatName format = m_header->GetDataFormatId();
         boost::scoped_ptr<ZipPoint> z(new ZipPoint(format, m_header->GetVLRs()));
         m_zipPoint.swap(z);
-        bool ok = false;
-        ok = m_zipPoint->GetZipper()->setup((unsigned char)format, m_header->GetDataRecordLength());
-        if (!ok)
-            std::ostringstream oss;
-            oss << "Error setting up compression engine: " << std::string(m_zipPoint->GetZipper()->get_error());
-            throw liblas_error(oss.str());
-        ok = m_zipPoint->GetZipper()->unpack(m_zipPoint->our_vlr_data.get(), m_zipPoint->our_vlr_num);
-        if (!ok)
-            oss << "Error unpacking zip VLR data: " << std::string(m_zipPoint->GetZipper()->get_error());
     if (!m_unzipper)
@@ -211,9 +196,11 @@
 void ZipReaderImpl::ReadIdiom()
     bool ok = false;
+    std::cout << "ReadIdiom pos: " << m_ifs.tellg() << std::endl;
     ok = m_unzipper->read(m_zipPoint->m_lz_point);
     if (!ok)
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/src/detail/writer/header.cpp	Tue Jun 28 15:21:50 2011 -0500
@@ -154,7 +154,6 @@
             VariableRecord v;
             zpd.ConstructVLR(v);
             m_header.AddVLR(v);
-            m_header.SetDataOffset(m_header.GetDataOffset()+v.GetRecordLength());
 #else
             throw configuration_error("LASzip compression support not enabled in this libLAS configuration.");
 #endif
@@ -169,13 +168,13 @@
         if (difference <= 0)
             int32_t d = abs(difference);
-            int32_t padding_from_before = m_header.GetDataOffset() - m_header.GetHeaderSize();
+            // int32_t padding_from_before = m_header.GetDataOffset() - m_header.GetHeaderSize();
             if (m_header.GetVersionMinor()  ==  0)
                 // Add the two extra bytes for the 1.0 pad
                 d = d + 2;
-            m_header.SetDataOffset(m_header.GetDataOffset() + d + padding_from_before);
+            m_header.SetDataOffset(m_header.GetDataOffset() + d);
@@ -243,7 +242,7 @@
     detail::write_n(m_ofs, n2, sizeof(n2));
     // 14. Offset to data
-    n4 = m_header.GetDataOffset();
+    n4 = m_header.GetDataOffset();
     detail::write_n(m_ofs, n4, sizeof(n4));
     // 15. Number of variable length records
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/src/detail/writer/zipwriter.cpp	Tue Jun 28 15:21:50 2011 -0500
@@ -107,23 +107,6 @@
         m_zipPoint.swap(z);
-        bool ok = false;
-        if (!ok)
-            oss << "Error opening compression core: " << std::string(m_zipPoint->GetZipper()->get_error());
-        ok = m_zipPoint->GetZipper()->pack(m_zipPoint->his_vlr_data, m_zipPoint->his_vlr_num);
-        if (!ok)
-            oss << "Error packing VLR data for compression: " << std::string(m_zipPoint->GetZipper()->get_error());
     if (!m_zipper)
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/src/detail/zippoint.cpp	Tue Jun 28 15:21:50 2011 -0500
@@ -114,9 +114,26 @@
         throw liblas_error("point format not supported by laszip");
-    m_zip->setup(pointFormat, pointSize);
+    if (vlr)
+        m_zip->unpack(our_vlr_data.get(), our_vlr_num);
+        m_zip->setup((const unsigned short int) m_zip->num_items,
+                     (const LASitem*)m_zip->items,
+                     LASZIP_COMPRESSOR_DEFAULT);
+        ConstructItems();
+    } else
-    ConstructItems(pointFormat, pointSize);
+        if (!m_zip->setup(pointFormat, pointSize))
+            std::ostringstream oss;
+            oss << "Error setting up LASzip for format " << pointFormat <<": " << m_zip->get_error();
+            throw liblas_error(oss.str());
+        ConstructItems();
     return;
@@ -131,14 +148,9 @@
-void ZipPoint::ConstructItems(unsigned char pointFormat, unsigned short size)
+void ZipPoint::ConstructItems()
-    if (!m_zip->setup(pointFormat, size))
-        oss << "Error setting up LASzip for format " << pointFormat <<": " << m_zip->get_error();
     // construct the object that will hold a laszip point
@@ -159,6 +171,7 @@
         point_offset += m_zip->items[i].size;
+    assert (point_offset == m_lz_point_size);
     return;
diff -r 3dc7a81a65f8 -r 47fa1baf1aa4 src/variablerecord.cpp
--- a/src/variablerecord.cpp	Tue Jun 28 11:20:13 2011 -0500
+++ b/src/variablerecord.cpp	Tue Jun 28 15:21:50 2011 -0500
@@ -220,6 +220,7 @@
     vlr.put("description", GetDescription(false));
     vlr.put("length", GetRecordLength());
     vlr.put("id", GetRecordId());
+    vlr.put("total_length", GetTotalSize());
     return vlr;
@@ -238,6 +239,7 @@
              << std::endl;
     os << "    ID: " << tree.get<boost::uint32_t>("id")
              << " Length: " << tree.get<boost::uint32_t>("length")
+             << " Total Size: " << tree.get<boost::uint32_t>("total_length")
              << std::endl;
     return os;
More information about the Liblas-commits mailing list
