[Liblas-commits] hg: no need to copy the vlr data,
properly order the setup() and...
liblas-commits at liblas.org
Wed Jun 29 09:33:54 EDT 2011
details: http://hg.liblas.orghg/rev/3a69d4575fdb
changeset: 3035:3a69d4575fdb
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Jun 28 16:47:35 2011 -0500
description:
no need to copy the vlr data, properly order the setup() and unpack() in the case we have a VLR
Subject: hg: text normalizing
details: http://hg.liblas.orghg/rev/4ff2ade1966c
changeset: 3036:4ff2ade1966c
date: Tue Jun 28 16:48:00 2011 -0500
description:
text normalizing
Subject: hg: remove lint
details: http://hg.liblas.orghg/rev/2290ff4322f9
changeset: 3037:2290ff4322f9
date: Wed Jun 29 08:21:16 2011 -0500
description:
remove lint
Subject: hg: setup is only for compression
details: http://hg.liblas.orghg/rev/62bcd5d0e24e
changeset: 3038:62bcd5d0e24e
date: Wed Jun 29 08:33:48 2011 -0500
description:
diffstat:
include/liblas/detail/zippoint.hpp | 2 --
src/detail/reader/zipreader.cpp | 11 +++++------
src/detail/zippoint.cpp | 29 ++++++++++-------------------
3 files changed, 15 insertions(+), 27 deletions(-)
diffs (106 lines):
diff -r 1807a68342fa -r 62bcd5d0e24e include/liblas/detail/zippoint.hpp
--- a/include/liblas/detail/zippoint.hpp Tue Jun 28 15:49:07 2011 -0500
+++ b/include/liblas/detail/zippoint.hpp Wed Jun 29 08:33:48 2011 -0500
@@ -84,8 +84,6 @@
// LASzip::unpack() just reads from the vlr_data we give it (we allocate and delete) ["our"]
int his_vlr_num;
unsigned char* his_vlr_data;
- int our_vlr_num;
- boost::scoped_array<boost::uint8_t> our_vlr_data;
boost::scoped_ptr<LASzip> m_zip;
diff -r 1807a68342fa -r 62bcd5d0e24e src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp Tue Jun 28 15:49:07 2011 -0500
+++ b/src/detail/reader/zipreader.cpp Wed Jun 29 08:33:48 2011 -0500
@@ -109,6 +109,7 @@
PointFormatName format = m_header->GetDataFormatId();
boost::scoped_ptr<ZipPoint> z(new ZipPoint(format, m_header->GetVLRs()));
m_zipPoint.swap(z);
if (!m_unzipper)
@@ -116,11 +117,11 @@
boost::scoped_ptr<LASunzipper> z(new LASunzipper());
m_unzipper.swap(z);
- bool stat(false);
+ bool ok(false);
m_ifs.seekg(m_header->GetDataOffset(), std::ios::beg);
- stat = m_unzipper->open(m_ifs, m_zipPoint->GetZipper());
+ ok = m_unzipper->open(m_ifs, m_zipPoint->GetZipper());
- if (!stat)
+ if (!ok)
std::ostringstream oss;
const char* err = m_unzipper->get_error();
@@ -194,11 +195,9 @@
void ZipReaderImpl::ReadIdiom()
bool ok = false;
- std::cout << "ReadIdiom pos: " << m_ifs.tellg() << std::endl;
ok = m_unzipper->read(m_zipPoint->m_lz_point);
if (!ok)
diff -r 1807a68342fa -r 62bcd5d0e24e src/detail/zippoint.cpp
--- a/src/detail/zippoint.cpp Tue Jun 28 15:49:07 2011 -0500
+++ b/src/detail/zippoint.cpp Wed Jun 29 08:33:48 2011 -0500
@@ -79,16 +79,6 @@
break;
- if (vlr)
- our_vlr_num = vlr->GetData().size();
- boost::scoped_array<boost::uint8_t> d( new boost::uint8_t[ our_vlr_num ] );
- our_vlr_data.swap(d);
- for (int i=0; i<our_vlr_num; i++)
- our_vlr_data[i] = vlr->GetData()[i];
unsigned char pointFormat = 0;
unsigned short pointSize = 0;
@@ -116,11 +106,15 @@
if (vlr)
- m_zip->unpack(our_vlr_data.get(), our_vlr_num);
- m_zip->setup((const unsigned short int) m_zip->num_items,
- (const LASitem*)m_zip->items,
- LASZIP_COMPRESSOR_DEFAULT);
- ConstructItems();
+ bool ok(false);
+ ok = m_zip->unpack(&(vlr->GetData()[0]), vlr->GetData().size());
+ if (!ok)
+ std::ostringstream oss;
+ oss << "Error unpacking zip VLR data: " << std::string(m_zip->get_error());
+ throw liblas_error(oss.str());
} else
@@ -130,12 +124,9 @@
oss << "Error setting up LASzip for format " << pointFormat <<": " << m_zip->get_error();
- ConstructItems();
+ ConstructItems();
return;
More information about the Liblas-commits
