[Liblas-commits] hg-main-tree: sync with liblas/laszip
liblas-commits at liblas.org
Thu Jun 30 17:26:28 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/5d625cbd1719
changeset: 824:5d625cbd1719
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Jun 30 17:21:19 2011 -0400
description:
Subject: hg-main-tree: sync laszip ref files for 2.0
details: http://hg.libpc.orghg-main-tree/rev/475963785a2f
changeset: 825:475963785a2f
date: Thu Jun 30 17:22:26 2011 -0400
description:
diffstat:
src/drivers/las/ZipPoint.cpp | 2 +-
test/data/1.2-with-color.laz | 0
test/data/1.2-with-color_LIBLAS.laz | 0
test/data/1.2-with-color_NATIVE.laz | 0
test/unit/LasWriterTest.cpp | 2 +-
test/unit/LiblasWriterTest.cpp | 2 +-
6 files changed, 3 insertions(+), 3 deletions(-)
diffs (42 lines):
diff -r ae2ab1d4b9ac -r 475963785a2f src/drivers/las/ZipPoint.cpp
--- a/src/drivers/las/ZipPoint.cpp Thu Jun 30 15:13:38 2011 -0500
+++ b/src/drivers/las/ZipPoint.cpp Thu Jun 30 17:22:26 2011 -0400
@@ -60,7 +60,7 @@
static const char* laszip_userid("laszip encoded");
static boost::uint16_t laszip_recordid = 22204;
-static const char* laszip_description = "encoded for sequential access";
+static const char* laszip_description = "http://laszip.org";
ZipPoint::ZipPoint(PointFormat format, const std::vector<VariableLengthRecord>& vlrs)
diff -r ae2ab1d4b9ac -r 475963785a2f test/data/1.2-with-color.laz
Binary file test/data/1.2-with-color.laz has changed
diff -r ae2ab1d4b9ac -r 475963785a2f test/data/1.2-with-color_LIBLAS.laz
Binary file test/data/1.2-with-color_LIBLAS.laz has changed
diff -r ae2ab1d4b9ac -r 475963785a2f test/data/1.2-with-color_NATIVE.laz
Binary file test/data/1.2-with-color_NATIVE.laz has changed
diff -r ae2ab1d4b9ac -r 475963785a2f test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Thu Jun 30 15:13:38 2011 -0500
+++ b/test/unit/LasWriterTest.cpp Thu Jun 30 17:22:26 2011 -0400
@@ -118,7 +118,7 @@
pdal::drivers::las::LasReader reader("temp.laz");
- bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color.laz"));
+ bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color_NATIVE.laz"));
BOOST_CHECK(filesSame);
if (filesSame)
diff -r ae2ab1d4b9ac -r 475963785a2f test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp Thu Jun 30 15:13:38 2011 -0500
+++ b/test/unit/LiblasWriterTest.cpp Thu Jun 30 17:22:26 2011 -0400
@@ -113,7 +113,7 @@
Utils::closeFile(ofs);
+ bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color_LIBLAS.laz"));
if (filesSame)
More information about the Liblas-commits
