[Liblas-commits] libpc: plumbing for OCI driver
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 1 13:30:46 EST 2011
details:   http://hg.liblas.orglibpc/rev/ce568eebe707
changeset: 133:ce568eebe707
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Mar 01 12:29:56 2011 -0600
description:
diffstat:
 src/CMakeLists.txt              |     3 +-
 src/drivers/CMakeLists.txt      |     7 +-
 src/drivers/oci/CMakeLists.txt  |    19 +
 src/drivers/oci/oci_wrapper.cpp |  1774 +++++++++++++++++++++++++++++++++++++++
 src/drivers/oci/oci_wrapper.h   |   417 +++++++++
 5 files changed, 2218 insertions(+), 2 deletions(-)
diffs (truncated from 2257 to 300 lines):
diff -r 4f0309a45e4e -r ce568eebe707 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Tue Mar 01 08:57:41 2011 -0600
+++ b/src/CMakeLists.txt	Tue Mar 01 12:29:56 2011 -0600
@@ -52,6 +52,7 @@
   ${LIBPC_HEADERS_DIR}/Writer.hpp)
 set (LIBPC_SOURCES "libpc_config.cpp" CACHE INTERNAL "sources to compile")
+set (APPS_CPP_DEPENDENCIES "${LIBPC_LIB_NAME}" CACHE INTERNAL "libraries to link")
 add_subdirectory(drivers)
@@ -120,7 +121,7 @@
 add_library(${LIBPC_LIB_NAME} SHARED ${LIBPC_SOURCES})
-target_link_libraries(${LIBPC_LIB_NAME}
+target_link_libraries(${APPS_CPP_DEPENDENCIES}
   ${LIBPC_LIB_NAME}
   ${LIBLAS_LIBRARY}
   ${TIFF_LIBRARY}
diff -r 4f0309a45e4e -r ce568eebe707 src/drivers/CMakeLists.txt
--- a/src/drivers/CMakeLists.txt	Tue Mar 01 08:57:41 2011 -0600
+++ b/src/drivers/CMakeLists.txt	Tue Mar 01 12:29:56 2011 -0600
@@ -9,4 +9,9 @@
 add_subdirectory(liblas)
-add_subdirectory(las)
\ No newline at end of file
+add_subdirectory(las)
+if(ORACLE_FOUND AND GDAL_FOUND)
+    add_subdirectory(oci)
+endif()
diff -r 4f0309a45e4e -r ce568eebe707 src/drivers/oci/CMakeLists.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/drivers/oci/CMakeLists.txt	Tue Mar 01 12:29:56 2011 -0600
@@ -0,0 +1,19 @@
+# src/drivers/liblas/CMakeLists.txt controls building of libPC library
+# Copyright (c) 2011 Howard Butler <hobu at hobu.net>
+set (SOURCES
+  oci_wrapper.cpp
+SET(APPS_CPP_DEPENDENCIES "${APPS_CPP_DEPENDENCIES};${ORACLE_LIBRARY}" CACHE INTERNAL "source files for foo")
+FOREACH(file ${SOURCES})
+        SET(LIBPC_SOURCES "${LIBPC_SOURCES};${CMAKE_CURRENT_SOURCE_DIR}/${file}" CACHE INTERNAL "source files for foo")
+ENDFOREACH(file)
diff -r 4f0309a45e4e -r ce568eebe707 src/drivers/oci/oci_wrapper.cpp
+++ b/src/drivers/oci/oci_wrapper.cpp	Tue Mar 01 12:29:56 2011 -0600
@@ -0,0 +1,1774 @@
+ * $Id: $
+ * Name:     oci_wrapper.cpp
+ * Project:  Oracle Spatial GeoRaster Driver
+ * Purpose:  Limited wrapper for OCI (Oracle Call Interfaces)
+ * Author:   Ivan Lucena [ivan.lucena at pmldnet.com]
+ * Copyright (c) 2008, Ivan Lucena
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ * OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+#include "oci_wrapper.h"
+static const OW_CellDepth ahOW_CellDepth[] = {
+    {"8BIT_U",          GDT_Byte},
+    {"16BIT_U",         GDT_UInt16},
+    {"16BIT_S",         GDT_Int16},
+    {"32BIT_U",         GDT_UInt32},
+    {"32BIT_S",         GDT_Int32},
+    {"32BIT_REAL",      GDT_Float32},
+    {"64BIT_REAL",      GDT_Float64},
+    {"32BIT_COMPLEX",   GDT_CFloat32},
+    {"64BIT_COMPLEX",   GDT_CFloat64},
+    {"1BIT",            GDT_Byte},
+    {"2BIT",            GDT_Byte},
+    {"4BIT",            GDT_Byte}
+/*                            OWConnection                                   */
+OWConnection::OWConnection( const char* pszUserIn,
+                            const char* pszPasswordIn,
+                            const char* pszServerIn )
+    pszUser         = CPLStrdup( pszUserIn );
+    pszPassword     = CPLStrdup( pszPasswordIn );
+    pszServer       = CPLStrdup( pszServerIn );
+    hEnv            = NULL;
+    hError          = NULL;
+    hSvcCtx         = NULL;
+    hDescribe       = NULL;
+    hNumArrayTDO    = NULL;
+    hGeometryTDO    = NULL;
+    hGeoRasterTDO   = NULL;
+    hElemArrayTDO   = NULL;
+    hOrdnArrayTDO   = NULL;
+    bSuceeeded      = false;
+    nCharSize       = 1;
+    //  Operational Systems's authentication option
+    const char* pszUserId = "/";
+    ub4 eCred = OCI_CRED_RDBMS;
+    if( EQUAL(pszServer, "") &&
+        EQUAL(pszPassword, "") &&
+        EQUAL(pszUser, "") )
+        eCred = OCI_CRED_EXT;
+    else
+        pszUserId = pszUser;
+    //  Initialize Environment handler                                  */
+    if( OCIEnvCreate( &hEnv,
+        (ub4) ( OCI_DEFAULT | OCI_OBJECT | OCI_THREADED ),
+        (dvoid *) 0, (dvoid * (*)(dvoid *, size_t)) 0,
+        (dvoid * (*)(dvoid *, dvoid *, size_t)) 0,
+        (void (*)(dvoid *, dvoid *)) 0, (size_t) 0,
+        (dvoid **) 0), NULL )
+        return;
+    //  Initialize Error handler
+    if( CheckError( OCIHandleAlloc( (dvoid *) hEnv, (dvoid **) &hError,
+        OCI_HTYPE_ERROR, (size_t) 0, (dvoid **) 0), NULL ) )
+        return;
+    //  Initialize Server Context
+    if( CheckError( OCIHandleAlloc( (dvoid *) hEnv, (dvoid **) &hSvcCtx,
+        OCI_HTYPE_SVCCTX, (size_t) 0, (dvoid **) 0), hError ) )
+        return;
+    //  Allocate Server and Authentication (Session) handler
+    if( CheckError( OCIHandleAlloc( (dvoid *) hEnv, (dvoid **) &hServer,
+        (ub4) OCI_HTYPE_SERVER, (size_t) 0, (dvoid **) 0), hError ) )
+        return;
+    if( CheckError( OCIHandleAlloc((dvoid *) hEnv, (dvoid **)&hSession,
+        (ub4) OCI_HTYPE_SESSION, (size_t) 0, (dvoid **) 0), hError ) )
+        return;
+    //  Attach to the server
+    if( CheckError( OCIServerAttach( hServer, hError, (text*) pszServer,
+        strlen((char*) pszServer), 0), hError ) )
+        return;
+    if( CheckError( OCIAttrSet((dvoid *) hSession, (ub4) OCI_HTYPE_SESSION,
+        (dvoid *) pszUserId, (ub4) strlen((char *) pszUserId),
+        (ub4) OCI_ATTR_USERNAME, hError), hError ) )
+        return;
+        (dvoid *) pszPassword, (ub4) strlen((char *) pszPassword),
+        (ub4) OCI_ATTR_PASSWORD, hError), hError ) )
+        return;
+    if( CheckError( OCIAttrSet( (dvoid *) hSvcCtx, OCI_HTYPE_SVCCTX, (dvoid *)hServer,
+        (ub4) 0, OCI_ATTR_SERVER, (OCIError *) hError), hError ) )
+        return;
+    //  Initialize Session
+    if( CheckError( OCISessionBegin(hSvcCtx, hError, hSession, eCred,
+        (ub4) OCI_DEFAULT), hError ) )
+        return;
+    //  Initialize Service
+    if( CheckError( OCIAttrSet((dvoid *) hSvcCtx, (ub4) OCI_HTYPE_SVCCTX,
+        (dvoid *) hSession, (ub4) 0,
+        (ub4) OCI_ATTR_SESSION, hError), hError ) )
+        return;
+    bSuceeeded = true;
+    //  Get Character Size based on current Locale
+    OCINlsNumericInfoGet( hEnv, hError,
+        &nCharSize, OCI_NLS_CHARSET_MAXBYTESZ );
+    //  Get Server Version
+    char szVersionTxt[OWTEXT];
+    OCIServerVersion (
+        hSvcCtx,
+        hError,
+        (text*) szVersionTxt,
+        (ub4) OWTEXT,
+        (ub1) OCI_HTYPE_SVCCTX );
+    nVersion = OWParseServerVersion( szVersionTxt );
+    //  Initialize/Describe types
+    CheckError( OCIHandleAlloc(
+        (dvoid*) hEnv,
+        (dvoid**) (dvoid*) &hDescribe,
+        (ub4) OCI_HTYPE_DESCRIBE,
+        (size_t) 0,
+        (dvoid**) NULL ), hError );
+    hNumArrayTDO    = DescribeType( (char*) SDO_NUMBER_ARRAY );
+    hGeometryTDO    = DescribeType( (char*) SDO_GEOMETRY );
+    hGeoRasterTDO   = DescribeType( (char*) SDO_GEORASTER );
+    hPCTDO          = DescribeType( (char*) SDO_PC );
+    hElemArrayTDO   = DescribeType( (char*) SDO_ELEM_INFO_ARRAY);
+    hOrdnArrayTDO   = DescribeType( (char* ) SDO_ORDINATE_ARRAY);
+OWConnection::~OWConnection()
+    OCIHandleFree( (dvoid*) hDescribe, (ub4) OCI_HTYPE_DESCRIBE);
+    if( hSvcCtx && hError && hSession )
More information about the Liblas-commits mailing list
