[Liblas-commits] libpc: add Stage::getName()
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 1 16:40:33 EST 2011
details:   http://hg.liblas.orglibpc/rev/4083a8ad908e
changeset: 145:4083a8ad908e
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Mar 01 13:40:24 2011 -0800
description:
diffstat:
 include/libpc/ColorFilter.hpp  |  2 ++
 include/libpc/CropFilter.hpp   |  2 ++
 include/libpc/FauxReader.hpp   |  2 ++
 include/libpc/FauxWriter.hpp   |  2 ++
 include/libpc/LasReader.hpp    |  2 ++
 include/libpc/LasWriter.hpp    |  2 +-
 include/libpc/MosaicFilter.hpp |  2 ++
 include/libpc/Stage.hpp        |  5 +++++
 src/ColorFilter.cpp            |  7 +++++++
 src/CropFilter.cpp             |  7 +++++++
 src/FauxReader.cpp             |  7 +++++++
 src/FauxWriter.cpp             |  7 +++++++
 src/LasReader.cpp              |  7 +++++++
 src/LasWriter.cpp              |  7 +++++++
 src/MosaicFilter.cpp           |  7 +++++++
 src/drivers/liblas/reader.cpp  |  7 +++++++
 src/drivers/liblas/reader.hpp  |  2 ++
 src/drivers/liblas/writer.cpp  |  7 +++++++
 src/drivers/liblas/writer.hpp  |  2 ++
 test/unit/CropFilterTest.cpp   |  1 +
 test/unit/FauxReaderTest.cpp   |  1 +
 test/unit/FauxWriterTest.cpp   |  1 +
 test/unit/LiblasReaderTest.cpp |  1 +
 test/unit/LiblasWriterTest.cpp |  1 +
 24 files changed, 90 insertions(+), 1 deletions(-)
diffs (truncated from 331 to 300 lines):
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/ColorFilter.hpp
--- a/include/libpc/ColorFilter.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/ColorFilter.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -50,6 +50,8 @@
 public:
     ColorFilter(Stage& prevStage);
+    const std::string& getName() const;
     boost::uint32_t readPoints(PointData&);
 private:
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/CropFilter.hpp
--- a/include/libpc/CropFilter.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/CropFilter.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -49,6 +49,8 @@
 public:
     CropFilter(Stage& prevStage, Bounds<double> const& bounds);
 private:
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/FauxReader.hpp
--- a/include/libpc/FauxReader.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/FauxReader.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -66,6 +66,8 @@
     FauxReader(const Bounds<double>&, int numPoints, Mode mode);
     FauxReader(const Bounds<double>&, int numPoints, Mode mode, const std::vector<Dimension>& dimensions);
     boost::uint32_t readPoints(PointData& data);
     void seekToPoint(boost::uint64_t);
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/FauxWriter.hpp
--- a/include/libpc/FauxWriter.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/FauxWriter.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -53,6 +53,8 @@
 public:
     FauxWriter(Stage& prevStage);
     // retrieve the summary info
     float getMinX() const { return m_minimumX; }
     float getMinY() const { return m_minimumY; }
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/LasReader.hpp
--- a/include/libpc/LasReader.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/LasReader.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -48,6 +48,8 @@
 public:
     LasReader(std::istream&);
     virtual boost::uint32_t readPoints(PointData&);
     // default is to reset() and then read N points manually
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/LasWriter.hpp
--- a/include/libpc/LasWriter.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/LasWriter.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -45,7 +45,7 @@
 public:
     LasWriter(Stage& prevStage, std::ostream&);
-    //void write();
 protected:
     // this is called once before the loop with the writeBuffer calls
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/MosaicFilter.hpp
--- a/include/libpc/MosaicFilter.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/MosaicFilter.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -47,6 +47,8 @@
 public:
     MosaicFilter(Stage& prevStage, Stage& prevStage2);
diff -r 4c5f9ca6e064 -r 4083a8ad908e include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/include/libpc/Stage.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -52,6 +52,11 @@
     Stage();
     virtual ~Stage();
+    // Implement this in your concrete classes to return a constant string
+    // as the name of the stage.  Use upper camel case, with spaces between
+    // words.  The last word should be "Reader", "Writer", or "Filter".
+    virtual const std::string& getName() const = 0;
     // This reads a set of points at the current position in the file.
     // The schema of the PointData buffer we are given here might
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/ColorFilter.cpp
--- a/src/ColorFilter.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/ColorFilter.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -53,6 +53,13 @@
+const std::string& ColorFilter::getName() const
+    static std::string name("Color Filter");
+    return name;
 boost::uint32_t ColorFilter::readPoints(PointData& data)
     m_prevStage.readPoints(data);
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/CropFilter.cpp
--- a/src/CropFilter.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/CropFilter.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -49,6 +49,13 @@
+const std::string& CropFilter::getName() const
+    static std::string name("Crop Filter");
+    return name;
 boost::uint32_t CropFilter::readPoints(PointData& data)
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/FauxReader.cpp
--- a/src/FauxReader.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/FauxReader.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -88,6 +88,13 @@
+const std::string& FauxReader::getName() const
+    static std::string name("Faux Reader");
+    return name;
 boost::uint32_t FauxReader::readPoints(PointData& data)
     if (data.getSchemaLayout().getSchema().getDimensions().size() != 4)
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/FauxWriter.cpp
--- a/src/FauxWriter.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/FauxWriter.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -50,6 +50,13 @@
+const std::string& FauxWriter::getName() const
+    static std::string name("Faux Writer");
+    return name;
 void FauxWriter::writeBegin()
     m_minimumX = m_minimumY = m_minimumZ = std::numeric_limits<float>::max();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/LasReader.cpp
--- a/src/LasReader.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/LasReader.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -54,6 +54,13 @@
+const std::string& LasReader::getName() const
+    static std::string name("Las Reader");
+    return name;
 const LasHeader& LasReader::getLasHeader() const
     return (const LasHeader&)getHeader();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/LasWriter.cpp
--- a/src/LasWriter.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/LasWriter.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -52,6 +52,13 @@
+const std::string& LasWriter::getName() const
+    static std::string name("Liblas Writer");
+    return name;
 void LasWriter::writeBegin()
     Header& baseHeader = getHeader();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/MosaicFilter.cpp
--- a/src/MosaicFilter.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/MosaicFilter.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -60,6 +60,13 @@
+const std::string& MosaicFilter::getName() const
+    static std::string name("Mosaic Filter");
+    return name;
 boost::uint32_t MosaicFilter::readPoints(PointData& destData)
     boost::uint32_t numPoints = destData.getNumPoints();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/drivers/liblas/reader.cpp
--- a/src/drivers/liblas/reader.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/drivers/liblas/reader.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -83,6 +83,13 @@
+const std::string& LiblasReader::getName() const
+    static std::string name("Liblas Reader");
+    return name;
 void LiblasReader::processExternalHeader()
     const liblas::Header& externalHeader = m_externalReader->GetHeader();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/drivers/liblas/reader.hpp
--- a/src/drivers/liblas/reader.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/drivers/liblas/reader.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -60,6 +60,8 @@
     LiblasReader(std::istream&);
     ~LiblasReader();
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/drivers/liblas/writer.cpp
--- a/src/drivers/liblas/writer.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/drivers/liblas/writer.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -76,6 +76,13 @@
+const std::string& LiblasWriter::getName() const
+    return name;
 void LiblasWriter::setupExternalHeader()
     setFormatVersion(1,2);
diff -r 4c5f9ca6e064 -r 4083a8ad908e src/drivers/liblas/writer.hpp
--- a/src/drivers/liblas/writer.hpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/src/drivers/liblas/writer.hpp	Tue Mar 01 13:40:24 2011 -0800
@@ -53,6 +53,8 @@
 public:
     LiblasWriter(Stage& prevStage, std::ostream&);
     ~LiblasWriter();
     void setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion);
     void setPointFormat(boost::int8_t pointFormat);
diff -r 4c5f9ca6e064 -r 4083a8ad908e test/unit/CropFilterTest.cpp
--- a/test/unit/CropFilterTest.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/test/unit/CropFilterTest.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -53,6 +53,7 @@
     FauxReader reader(srcBounds, 1000, FauxReader::Random);
     CropFilter filter(reader, dstBounds);
+    BOOST_CHECK(filter.getName() == "Crop Filter");
     FauxWriter writer(filter);
diff -r 4c5f9ca6e064 -r 4083a8ad908e test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp	Tue Mar 01 13:40:08 2011 -0800
+++ b/test/unit/FauxReaderTest.cpp	Tue Mar 01 13:40:24 2011 -0800
@@ -45,6 +45,7 @@
     Bounds<double> bounds(1.0, 2.0, 3.0, 101.0, 102.0, 103.0);
     FauxReader reader(bounds, 1000, FauxReader::Constant);
+    BOOST_CHECK(reader.getName() == "Faux Reader");
     const Schema& schema = reader.getHeader().getSchema();
     SchemaLayout layout(schema);
diff -r 4c5f9ca6e064 -r 4083a8ad908e test/unit/FauxWriterTest.cpp
--- a/test/unit/FauxWriterTest.cpp	Tue Mar 01 13:40:08 2011 -0800
More information about the Liblas-commits mailing list
