[Liblas-commits] libpc: simplify allValid to hop out of testing once we hit a fal...
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 2 11:49:15 EST 2011
details:   http://hg.liblas.orglibpc/rev/23076ea40a50
changeset: 155:23076ea40a50
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Mar 02 10:49:11 2011 -0600
description:
simplify allValid to hop out of testing once we hit a false one.  Clean up initialization of m_numPoints so it is only set once on construction
diffstat:
 src/PointData.cpp |  20 ++++++++------------
 1 files changed, 8 insertions(+), 12 deletions(-)
diffs (41 lines):
diff -r cb18d91a3ee5 -r 23076ea40a50 src/PointData.cpp
--- a/src/PointData.cpp	Wed Mar 02 10:39:52 2011 -0600
+++ b/src/PointData.cpp	Wed Mar 02 10:49:11 2011 -0600
@@ -48,11 +48,10 @@
 PointData::PointData(const SchemaLayout& schemaLayout, boost::uint32_t numPoints) :
     m_schemaLayout(schemaLayout),
     m_data(NULL),
-    m_pointSize(0),
+    m_pointSize(m_schemaLayout.getByteSize()),
     m_numPoints(numPoints),
     m_isValid(numPoints)
-    m_pointSize = m_schemaLayout.getByteSize();
     m_data = new boost::uint8_t[m_pointSize * m_numPoints];
     // the points will all be set to invalid here
@@ -77,17 +76,14 @@
 bool PointData::allValid() const
-    // Assuming each byte is set to 1 for true and 0 for false,
-    // if the sum of all of the bytes in the mask == the size
-    // of the mask, all the data are valid.  This hopefully is faster
-    // than walking all of the points individually and doing an
-    // if test
+    valid_mask_type::size_type i = 0;
+    while(i < m_isValid.size())
+        if (m_isValid[i] != 1) return false;
+        i++;
+    return true;
-    boost::uint32_t sum = std::accumulate(m_isValid.begin(), m_isValid.end(), 0);
-    if (sum == m_isValid.size())
-        return true;
-    return false;
 void
More information about the Liblas-commits mailing list
