[Liblas-commits] libpc: start at bindings
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 2 23:43:44 EST 2011
details:   http://hg.liblas.orglibpc/rev/735337180ebd
changeset: 158:735337180ebd
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Mar 02 20:43:42 2011 -0800
description:
start at bindings
diffstat:
 csharp/README.txt                                 |    45 +
 csharp/libpc_swig_cpp/libpc.i                     |   130 +
 csharp/libpc_swig_cpp/libpc_wrap.cpp              |  1722 +++++++++++++++++++++
 csharp/libpc_swig_cs/Dimension.cs                 |   179 ++
 csharp/libpc_swig_cs/Properties/AssemblyInfo.cs   |    36 +
 csharp/libpc_swig_cs/VectorU32.cs                 |   349 ++++
 csharp/libpc_swig_cs/VectorU8.cs                  |   349 ++++
 csharp/libpc_swig_cs/libpc_swig_cpp.cs            |    17 +
 csharp/libpc_swig_cs/libpc_swig_cppPINVOKE.cs     |   427 +++++
 csharp/libpc_swig_cs/libpc_swig_cs.csproj         |   105 +
 csharp/libpc_swig_test/Program.cs                 |    70 +
 csharp/libpc_swig_test/Properties/AssemblyInfo.cs |    36 +
 csharp/libpc_swig_test/TestDimension.cs           |    28 +
 csharp/libpc_swig_test/libpc_swig_test.csproj     |    96 +
 14 files changed, 3589 insertions(+), 0 deletions(-)
diffs (truncated from 3647 to 300 lines):
diff -r 11e7f5485f7e -r 735337180ebd csharp/README.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/csharp/README.txt	Wed Mar 02 20:43:42 2011 -0800
@@ -0,0 +1,45 @@
+README for libPC C# Support
+ *** UNDER DEVELOPMENT ***  (proceed with caution)
+This directory contains the code needed to create C# bindings and the pcview
+app for libPC.
+If questions, contact mpg at flaxen.com.
+The C# work does not use CMake, as CMake doesn't yet support C# builds.
+* The solution file libpc_swig.sln has three projects:
+  - libpc_swig_cpp
+    . runs swig on the .i file
+	  - creates the .cpp wrapper file
+	  - creates the .cs wrapper classes
+	. compiles the .cpp wrapper file
+	. creates libpc_swig_cpp.dll
+  - libpc_swig_cs
+    . compiled the .cs wrapper classes
+	. creates libpc_swig_cs.dll
+  - libpc_swig_test
+    . compiles a simple test app to verify the bindings work
+	. creates swig_test.exe
+* The two DLLs and the EXE are put into the main libpc bin directory, for ease of use.
+* Only Visual Studio 2010 is supported.  Four build configurations are possible:
+  - x86/Debug
+  - x86/Release
+  - x64/Debug
+  - x64/Release
+Of these four, only x64/Debug has actually been tested :-)
+There seems to be an issue with running swig-generated code in x86 mode on a
+64-bit OS, and the examples that ship with swig bear this out.  I'm not sure
+what's up with that.  See this thread:
+  http://old.nabble.com/SWIG-examples-will-not-run-on-my-windows-7---64-bits-td29085404.html
+* The test app should be run from the csharp/libpc-swig-test directory.
diff -r 11e7f5485f7e -r 735337180ebd csharp/libpc_swig_cpp/libpc.i
+++ b/csharp/libpc_swig_cpp/libpc.i	Wed Mar 02 20:43:42 2011 -0800
@@ -0,0 +1,130 @@
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  swig/C# bindings for liblas
+ * Author:   Michael P. Gerlek (mpg at flaxen.com)
+ * Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+%module libpc_swig_cpp
+#include "libpc/libpc_config.hpp"
+#include "libpc/Dimension.hpp"
+%include "typemaps.i"
+// C# support for std::string
+%include "std_string.i"
+// C# support for std::vector<T>
+%include "std_vector.i"
+namespace std {
+   %template(VectorU8) vector<unsigned char>;
+   %template(VectorU32) vector<unsigned int>;
+// fix up some missing types
+namespace std
+	typedef unsigned int size_t;
+namespace boost
+	typedef unsigned char uint8_t;
+	typedef signed char int8_t;
+	typedef unsigned short uint16_t;
+	typedef signed short int16_t;
+	typedef unsigned int uint32_t;
+	typedef signed int int32_t;
+// BUG: how do I do a rename such that "SWIGTYPE_p_std__istream" can
+// become something like "IStreamHandle"?
+namespace libpc
+class Dimension
+public:
+    enum DataType
+        Int8,
+        Uint8,
+        Int16,
+        Uint16,
+        Int32,
+        Uint32,
+        Int64,
+        Uint64,
+        Float,       // 32 bits
+        Double       // 64 bits
+public:
+    Dimension(std::string const& name, DataType type);
+    inline std::string const& getName() const;
+    DataType getDataType() const;
+    static std::string getDataTypeName(DataType);
+    static DataType getDataTypeFromString(const std::string&);
+    static std::size_t getDataTypeSize(DataType);
+    static bool getDataTypeIsNumeric(DataType);
+    static bool getDataTypeIsSigned(DataType);
+    static bool getDataTypeIsInteger(DataType);
+    std::size_t getByteSize() const;
+    inline std::string getDescription() const;
+    inline void setDescription(std::string const& v);
+    inline bool isNumeric() const;
+    inline bool isSigned() const;
+    inline bool isInteger() const;
+    inline double getMinimum() const;
+    inline void setMinimum(double min);
+    inline double getMaximum() const;
+    inline void setMaximum(double max);
+    inline double getNumericScale() const;
+    inline void setNumericScale(double v);
+    inline double getNumericOffset() const;
+    inline void setNumericOffset(double v);
+    inline bool isFinitePrecision() const;
+    inline void isFinitePrecision(bool v);
+}; // namespace
diff -r 11e7f5485f7e -r 735337180ebd csharp/libpc_swig_cpp/libpc_wrap.cpp
+++ b/csharp/libpc_swig_cpp/libpc_wrap.cpp	Wed Mar 02 20:43:42 2011 -0800
@@ -0,0 +1,1722 @@
+ * This file was automatically generated by SWIG (http://www.swig.org).
+ * Version 2.0.1
+ * This file is not intended to be easily readable and contains a number of
+ * coding conventions designed to improve portability and efficiency. Do not make
+ * changes to this file unless you know what you are doing--modify the SWIG
+ * interface file instead.
+#define SWIGCSHARP
+#ifdef __cplusplus
+/* SwigValueWrapper is described in swig.swg */
+template<typename T> class SwigValueWrapper {
+  struct SwigMovePointer {
+    T *ptr;
+    SwigMovePointer(T *p) : ptr(p) { }
+    ~SwigMovePointer() { delete ptr; }
+    SwigMovePointer& operator=(SwigMovePointer& rhs) { T* oldptr = ptr; ptr = 0; delete oldptr; ptr = rhs.ptr; rhs.ptr = 0; return *this; }
+  } pointer;
+  SwigValueWrapper& operator=(const SwigValueWrapper<T>& rhs);
+  SwigValueWrapper(const SwigValueWrapper<T>& rhs);
+public:
+  SwigValueWrapper() : pointer(0) { }
+  SwigValueWrapper& operator=(const T& t) { SwigMovePointer tmp(new T(t)); pointer = tmp; return *this; }
+  operator T&() const { return *pointer.ptr; }
+  T *operator&() { return pointer.ptr; }
+template <typename T> T SwigValueInit() {
+  return T();
+#endif
+ *  This section contains generic SWIG labels for method/variable
+ *  declarations/attributes, and other compiler dependent labels.
+/* template workaround for compilers that cannot correctly implement the C++ standard */
+#ifndef SWIGTEMPLATEDISAMBIGUATOR
+# if defined(__SUNPRO_CC) && (__SUNPRO_CC <= 0x560)
+#  define SWIGTEMPLATEDISAMBIGUATOR template
+# elif defined(__HP_aCC)
+/* Needed even with `aCC -AA' when `aCC -V' reports HP ANSI C++ B3910B A.03.55 */
+/* If we find a maximum version that requires this, the test would be __HP_aCC <= 35500 for A.03.55 */
+# else
+# endif
+#endif
+/* inline attribute */
+#ifndef SWIGINLINE
+# if defined(__cplusplus) || (defined(__GNUC__) && !defined(__STRICT_ANSI__))
+#   define SWIGINLINE inline
+# else
+# endif
+#endif
+/* attribute recognised by some compilers to avoid 'unused' warnings */
+#ifndef SWIGUNUSED
+# if defined(__GNUC__)
+#   if !(defined(__cplusplus)) || (__GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4))
+#     define SWIGUNUSED __attribute__ ((__unused__))
+#   else
+#   endif
+# elif defined(__ICC)
+# else
+# endif
+#endif
+#ifndef SWIG_MSC_UNSUPPRESS_4505
+# if defined(_MSC_VER)
+#   pragma warning(disable : 4505) /* unreferenced local function has been removed */
+# endif
+#endif
+#ifndef SWIGUNUSEDPARM
+# ifdef __cplusplus
+#   define SWIGUNUSEDPARM(p)
+# else
+#   define SWIGUNUSEDPARM(p) p SWIGUNUSED
+# endif
+#endif
+/* internal SWIG method */
+#ifndef SWIGINTERN
+# define SWIGINTERN static SWIGUNUSED
+#endif
+/* internal inline SWIG method */
+#ifndef SWIGINTERNINLINE
+# define SWIGINTERNINLINE SWIGINTERN SWIGINLINE
+#endif
+/* exporting methods */
+#if (__GNUC__ >= 4) || (__GNUC__ == 3 && __GNUC_MINOR__ >= 4)
+#  ifndef GCC_HASCLASSVISIBILITY
+#    define GCC_HASCLASSVISIBILITY
+#  endif
+#endif
+#ifndef SWIGEXPORT
+# if defined(_WIN32) || defined(__WIN32__) || defined(__CYGWIN__)
+#   if defined(STATIC_LINKED)
+#     define SWIGEXPORT
More information about the Liblas-commits mailing list
