[Liblas-commits] libpc: fix argument order
liblas-commits at liblas.org
Thu Mar 3 15:16:10 EST 2011
details: http://hg.liblas.orglibpc/rev/a67292b37e25
changeset: 165:a67292b37e25
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Mar 03 12:15:52 2011 -0800
description:
fix argument order
Subject: libpc: merge
details: http://hg.liblas.orglibpc/rev/946a47f1de74
changeset: 166:946a47f1de74
date: Thu Mar 03 12:16:04 2011 -0800
description:
merge
diffstat:
include/libpc/Utils.hpp | 6 +
include/libpc/chipper.hpp | 139 +++++++++++++++++
src/CMakeLists.txt | 1 +
src/PointData.cpp | 2 +-
src/chipper.cpp | 371 ++++++++++++++++++++++++++++++++++++++++++++++
5 files changed, 518 insertions(+), 1 deletions(-)
diffs (truncated from 564 to 300 lines):
diff -r 598d3126a001 -r 946a47f1de74 include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp Thu Mar 03 10:09:26 2011 -0800
+++ b/include/libpc/Utils.hpp Thu Mar 03 12:16:04 2011 -0800
@@ -39,6 +39,7 @@
#include <string>
#include <stdexcept>
#include <cassert>
+#include <cmath>
#include <boost/concept_check.hpp>
#include <boost/cstdint.hpp>
@@ -135,6 +136,11 @@
dest.write(p, num);
assert(check_stream_state(dest));
+ // From http://stackoverflow.com/questions/485525/round-for-float-in-c
+ static inline double sround(double r) {
+ return (r > 0.0) ? floor(r + 0.5) : ceil(r - 0.5);
private:
template<typename T>
diff -r 598d3126a001 -r 946a47f1de74 include/libpc/chipper.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/chipper.hpp Thu Mar 03 12:16:04 2011 -0800
@@ -0,0 +1,139 @@
+#ifndef LIBLAS_CHIPPER_H
+#define LIBLAS_CHIPPER_H
+#include <libpc/Stage.hpp>
+#include <libpc/Bounds.hpp>
+#include <libpc/export.hpp>
+#include <libpc/Dimension.hpp>
+#include <vector>
+namespace libpc
+namespace chipper
+enum Direction
+ DIR_X,
+ DIR_Y,
+ DIR_NONE
+class LIBPC_DLL PtRef
+public:
+ double m_pos;
+ boost::uint32_t m_ptindex;
+ boost::uint32_t m_oindex;
+ bool operator < (const PtRef& pt) const
+ { return m_pos < pt.m_pos; }
+struct LIBPC_DLL RefList
+public:
+ std::vector<PtRef> m_vec;
+ Direction m_dir;
+ RefList(Direction dir = DIR_NONE) : m_dir(dir)
+ std::vector<PtRef>::size_type size() const
+ { return m_vec.size(); }
+ void reserve(std::vector<PtRef>::size_type n)
+ { m_vec.reserve(n); }
+ void resize(std::vector<PtRef>::size_type n)
+ { m_vec.resize(n); }
+ void push_back(const PtRef& ref)
+ { m_vec.push_back(ref); }
+ std::vector<PtRef>::iterator begin()
+ { return m_vec.begin(); }
+ std::vector<PtRef>::iterator end()
+ { return m_vec.end(); }
+ PtRef& operator[](boost::uint32_t pos)
+ { return m_vec[pos]; }
+ std::string Dir()
+ if (m_dir == DIR_X)
+ return "X";
+ else if (m_dir == DIR_Y)
+ return "Y";
+ else
+ return "NONE";
+class LIBPC_DLL Chipper;
+class LIBPC_DLL Block
+ friend class Chipper;
+private:
+ RefList *m_list_p;
+ boost::uint32_t m_left;
+ boost::uint32_t m_right;
+ libpc::Bounds<double> m_bounds;
+ // double m_xmin;
+ // double m_ymin;
+ // double m_xmax;
+ // double m_ymax;
+public:
+ std::vector<boost::uint32_t> GetIDs() const;
+ libpc::Bounds<double> const& GetBounds() const {return m_bounds;}
+ void SetBounds(libpc::Bounds<double> const& bounds) {m_bounds = bounds;}
+ // double GetXmin() const
+ // { return m_xmin; }
+ // double GetYmin() const
+ // { return m_ymin; }
+ // double GetXmax() const
+ // { return m_xmax; }
+ // double GetYmax() const
+ // { return m_ymax; }
+public:
+ Chipper(Stage& prevStage, boost::uint32_t max_partition_size) :
+ m_stage(prevStage), m_threshold(max_partition_size),
+ m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
+ void Chip();
+ std::vector<Block>::size_type GetBlockCount()
+ { return m_blocks.size(); }
+ const Block& GetBlock(std::vector<Block>::size_type i)
+ { return m_blocks[i]; }
+private:
+ void Load(RefList& xvec, RefList& yvec, RefList& spare);
+ void Partition(boost::uint32_t size);
+ void Split(RefList& xvec, RefList& yvec, RefList& spare);
+ void DecideSplit(RefList& v1, RefList& v2, RefList& spare,
+ boost::uint32_t left, boost::uint32_t right);
+ void Split(RefList& wide, RefList& narrow, RefList& spare,
+ void FinalSplit(RefList& wide, RefList& narrow,
+ boost::uint32_t pleft, boost::uint32_t pcenter);
+ void Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
+ RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax );
+ // Reader *m_reader;
+ Stage& m_stage;
+ boost::uint32_t m_threshold;
+ std::vector<Block> m_blocks;
+ std::vector<boost::uint32_t> m_partitions;
+ RefList m_xvec;
+ RefList m_yvec;
+ RefList m_spare;
+} // namespace chipper
+} // namespace liblas
+#endif
diff -r 598d3126a001 -r 946a47f1de74 src/CMakeLists.txt
--- a/src/CMakeLists.txt Thu Mar 03 10:09:26 2011 -0800
+++ b/src/CMakeLists.txt Thu Mar 03 12:16:04 2011 -0800
@@ -62,6 +62,7 @@
set(LIBPC_CPP
${LIBPC_SOURCES}
Bounds.cpp
+ chipper.cpp
Color.cpp
ColorFilter.cpp
CropFilter.cpp
diff -r 598d3126a001 -r 946a47f1de74 src/PointData.cpp
--- a/src/PointData.cpp Thu Mar 03 10:09:26 2011 -0800
+++ b/src/PointData.cpp Thu Mar 03 12:16:04 2011 -0800
@@ -54,7 +54,7 @@
m_data = new boost::uint8_t[m_pointSize * m_numPoints];
// the points will all be set to invalid here
- m_isValid.assign(0, m_isValid.size());
+ m_isValid.assign(m_isValid.size(), 0);
return;
diff -r 598d3126a001 -r 946a47f1de74 src/chipper.cpp
+++ b/src/chipper.cpp Thu Mar 03 12:16:04 2011 -0800
@@ -0,0 +1,371 @@
+ * $Id$
+ * Project: libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose: Point Partitioning/blocking for OPC
+ * Author: Andrew Bell andrew.bell.ia at gmail.com
+ * Copyright (c) 2010, Andrew Bell
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ * * Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * * Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided
+ * with the distribution.
+ * * Neither the name of the Andrew Bell or libLAS nor the names of
+ * its contributors may be used to endorse or promote products derived
+ * from this software without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#include <libpc/chipper.hpp>
+#include <libpc/Utils.hpp>
+// boost
+#include <boost/cstdint.hpp>
+// std
+#include <cmath>
+using namespace std;
+The objective is to split the region into non-overlapping blocks, each
+containing approximately the same number of points, as specified by the
+user.
+First, the points are read into arrays - one for the x direction, and one for
+the y direction. The arrays are sorted and are initialized with indices into
+the other array of the location of the other coordinate of the same point.
+Partitions are created that place the maximum number of points in a
+block, subject to the user-defined threshold, using a cumulate and round
+procedure.
+The distance of the point-space is checked in each direction and the
+wider dimension is chosen for splitting at an appropriate partition point.
+The points in the narrower direction are copied to locations in the spare
+array at one side or the other of the chosen partition, and that portion
+of the spare array then becomes the active array for the narrow direction.
+This avoids resorting of the arrays, which are already sorted.
+This procedure is then recursively applied to the created blocks until
+they contains only one or two partitions. In the case of one partition,
+we are done, and we simply store away the contents of the block. If there are
+two partitions in a block, we avoid the recopying the narrow array to the
+spare since the wide array already contains the desired points partitioned
+into two blocks. We simply need to locate the maximum and minimum values
+from the narrow array so that the approriate extrema of the block can
+be stored.
+namespace libpc { namespace chipper {
+vector<boost::uint32_t> Block::GetIDs() const
+ vector<boost::uint32_t> ids;
+ for (boost::uint32_t i = m_left; i <= m_right; ++i)
+ ids.push_back((*m_list_p)[i].m_ptindex);
+ return ids;
+void Chipper::Chip()
+ Load(m_xvec, m_yvec, m_spare);
+ Partition(m_xvec.size());
+ DecideSplit(m_xvec, m_yvec, m_spare, 0, m_partitions.size() - 1);
+void Chipper::Load(RefList& xvec, RefList& yvec, RefList& spare )
+ PtRef ref;
+ boost::uint32_t idx;
+ vector<PtRef>::iterator it;
+ libpc::Header const& header = m_stage.getHeader();
+ libpc::Schema const& schema = header.getSchema();
+ boost::uint64_t count = header.getNumPoints();
More information about the Liblas-commits
