[Liblas-commits] libpc: very simple cache filter
liblas-commits at liblas.org
Mon Mar 7 17:44:56 EST 2011
details: http://hg.liblas.orglibpc/rev/dacbbd3a3288
changeset: 183:dacbbd3a3288
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Mar 07 14:44:33 2011 -0800
description:
diffstat:
include/libpc/CacheFilter.hpp | 79 ++++++++++++++++++++++++
src/CMakeLists.txt | 2 +
src/CacheFilter.cpp | 135 ++++++++++++++++++++++++++++++++++++++++++
test/unit/CMakeLists.txt | 1 +
test/unit/CacheFilterTest.cpp | 98 ++++++++++++++++++++++++++++++
5 files changed, 315 insertions(+), 0 deletions(-)
diffs (truncated from 354 to 300 lines):
diff -r 52486659a751 -r dacbbd3a3288 include/libpc/CacheFilter.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/CacheFilter.hpp Mon Mar 07 14:44:33 2011 -0800
@@ -0,0 +1,79 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_CACHEFILTER_HPP
+#define INCLUDED_CACHEFILTER_HPP
+#include "libpc/Filter.hpp"
+namespace libpc
+// this is just a very simple MRU filter -- future versions will be smarter
+class LIBPC_DLL CacheFilter : public Filter
+public:
+ CacheFilter(Stage& prevStage);
+ ~CacheFilter();
+ const std::string& getName() const;
+ // number of points requested from this filter via read()
+ boost::uint64_t getNumPointsRequested() const;
+ // num points this filter read from the previous stage
+ boost::uint64_t getNumPointsRead() const;
+ // override
+ boost::uint64_t getCurrentPointIndex() const;
+ // override
+ void seekToPoint(boost::uint64_t index);
+private:
+ boost::uint32_t readBuffer(PointData&);
+ boost::uint64_t m_currentPointIndex;
+ boost::uint64_t m_storedPointIndex;
+ PointData* m_storedPointData;
+ boost::uint64_t m_numPointsRequested;
+ boost::uint64_t m_numPointsRead;
+ CacheFilter& operator=(const CacheFilter&); // not implemented
+ CacheFilter(const CacheFilter&); // not implemented
+} // namespace libpc
+#endif
diff -r 52486659a751 -r dacbbd3a3288 src/CMakeLists.txt
--- a/src/CMakeLists.txt Mon Mar 07 14:37:14 2011 -0600
+++ b/src/CMakeLists.txt Mon Mar 07 14:44:33 2011 -0800
@@ -24,6 +24,7 @@
${LIBPC_HEADERS_DIR}/export.hpp
${LIBPC_HEADERS_DIR}/libpc_config.hpp
${LIBPC_HEADERS_DIR}/Bounds.hpp
+ ${LIBPC_HEADERS_DIR}/CacheFilter.hpp
${LIBPC_HEADERS_DIR}/Color.hpp
${LIBPC_HEADERS_DIR}/ColorFilter.hpp
${LIBPC_HEADERS_DIR}/CropFilter.hpp
@@ -63,6 +64,7 @@
${LIBPC_SOURCES}
Bounds.cpp
chipper.cpp
+ CacheFilter.cpp
Color.cpp
ColorFilter.cpp
CropFilter.cpp
diff -r 52486659a751 -r dacbbd3a3288 src/CacheFilter.cpp
+++ b/src/CacheFilter.cpp Mon Mar 07 14:44:33 2011 -0800
@@ -0,0 +1,135 @@
+* OF SUCH DAMAGE.
+#include "libpc/CacheFilter.hpp"
+namespace libpc
+CacheFilter::CacheFilter(Stage& prevStage)
+ : Filter(prevStage)
+ , m_currentPointIndex(0)
+ , m_storedPointIndex(0)
+ , m_storedPointData(NULL)
+ , m_numPointsRequested(0)
+ , m_numPointsRead(0)
+ return;
+CacheFilter::~CacheFilter()
+ delete m_storedPointData;
+const std::string& CacheFilter::getName() const
+ static std::string name("Cache Filter");
+ return name;
+boost::uint64_t CacheFilter::getCurrentPointIndex() const
+ return m_currentPointIndex;
+void CacheFilter::seekToPoint(boost::uint64_t index)
+ m_currentPointIndex = index;
+ m_prevStage.seekToPoint(index);
+boost::uint64_t CacheFilter::getNumPointsRequested() const
+ return m_numPointsRequested;
+boost::uint64_t CacheFilter::getNumPointsRead() const
+ return m_numPointsRead;
+boost::uint32_t CacheFilter::readBuffer(PointData& data)
+ m_numPointsRequested += data.getNumPoints();
+ boost::uint64_t pointToRead = getCurrentPointIndex();
+ // do we meet the cache-checking criteria?
+ if (data.getNumPoints() == 1 && m_storedPointData != NULL)
+ // do we have the point we want in the cache?
+ if (pointToRead >= m_storedPointIndex &&
+ pointToRead < m_storedPointIndex + m_storedPointData->getNumPoints())
+ // the cache has the data we want
+ boost::uint32_t index = (boost::uint32_t)(pointToRead - m_storedPointIndex);
+ data.copyPointFast(0, index, *m_storedPointData);
+ m_currentPointIndex += 1;
+ return 1;
+ // not cached, so read a full block and replace cache with it
+ int chunkSize = 1024;
+ m_storedPointData = new PointData(data.getSchemaLayout(), chunkSize);
+ m_prevStage.read(*m_storedPointData);
+ m_numPointsRead += chunkSize;
+ data.copyPointFast(0, 0, *m_storedPointData);
+ m_storedPointIndex = getCurrentPointIndex();
+ return 1;
diff -r 52486659a751 -r dacbbd3a3288 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Mon Mar 07 14:37:14 2011 -0600
+++ b/test/unit/CMakeLists.txt Mon Mar 07 14:44:33 2011 -0800
@@ -9,6 +9,7 @@
SET(LIBPC_UNIT_TEST_SRC
BoundsTest.cpp
+ CacheFilterTest.cpp
ChipperTest.cpp
ColorTest.cpp
ConfigTest.cpp
diff -r 52486659a751 -r dacbbd3a3288 test/unit/CacheFilterTest.cpp
+++ b/test/unit/CacheFilterTest.cpp Mon Mar 07 14:44:33 2011 -0800
@@ -0,0 +1,98 @@
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <boost/cstdint.hpp>
+#include "libpc/FauxReader.hpp"
+using namespace libpc;
+BOOST_AUTO_TEST_SUITE(CacheFilterTest)
More information about the Liblas-commits
