[Liblas-commits] libpc: fix up GDAL CPL_DEBUG output so it at least
works (leaks ...
liblas-commits at liblas.org
Thu Mar 10 18:04:12 EST 2011
details: http://hg.liblas.orglibpc/rev/2e5420d71219
changeset: 202:2e5420d71219
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Mar 10 17:04:03 2011 -0600
description:
fix up GDAL CPL_DEBUG output so it at least works (leaks a putenv string right now). start on an oci example
diffstat:
CMakeLists.txt | 2 +-
apps/Application.cpp | 28 ++++++------
apps/pc2pc.cpp | 31 ++++++++++++++
src/chipper.cpp | 2 +
src/drivers/oci/writer.cpp | 97 ++++++++++++++++++++++++++++-----------------
src/drivers/oci/writer.hpp | 8 ++-
6 files changed, 114 insertions(+), 54 deletions(-)
diffs (truncated from 321 to 300 lines):
diff -r 25fdd984e99d -r 2e5420d71219 CMakeLists.txt
--- a/CMakeLists.txt Thu Mar 10 14:56:29 2011 -0800
+++ b/CMakeLists.txt Thu Mar 10 17:04:03 2011 -0600
@@ -355,7 +355,7 @@
# installation commands
-install(FILES AUTHORS COPYING INSTALL LICENSE.txt README.txt
+install(FILES AUTHORS.txt LICENSE.txt
DESTINATION ${LIBPC_DATA_DIR}/doc)
diff -r 25fdd984e99d -r 2e5420d71219 apps/Application.cpp
--- a/apps/Application.cpp Thu Mar 10 14:56:29 2011 -0800
+++ b/apps/Application.cpp Thu Mar 10 17:04:03 2011 -0600
@@ -90,21 +90,21 @@
// call derived function
int status = 0;
- try
+ // try
status = execute();
- catch (std::exception e)
- const std::string s(e.what());
- runtimeError("Caught exception: " + s);
- status = 1;
- catch (...)
- runtimeError("Caught unknown exception");
- status = 1;
+ // catch (std::exception e)
+ // const std::string s(e.what());
+ // runtimeError("Caught exception: " + s);
+ // status = 1;
+ // catch (...)
+ // runtimeError("Caught unknown exception");
+ // status = 1;
if (status == 0 && hasOption("timer"))
diff -r 25fdd984e99d -r 2e5420d71219 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Mar 10 14:56:29 2011 -0800
+++ b/apps/pc2pc.cpp Thu Mar 10 17:04:03 2011 -0600
@@ -26,10 +26,13 @@
#include "libpc/LasReader.hpp"
//#include "libpc/LasHeader.hpp"
#include "libpc/LasWriter.hpp"
+#include "libpc/CacheFilter.hpp"
#include "libpc/../../src/drivers/liblas/writer.hpp"
#include "libpc/../../src/drivers/liblas/reader.hpp"
+#include "libpc/../../src/drivers/oci/writer.hpp"
#include "Application.hpp"
@@ -84,6 +87,7 @@
("input,i", po::value<std::string>(&m_inputFile), "input file name")
("output,o", po::value<std::string>(&m_outputFile), "output file name")
("native", "use native LAS classes (not liblas)")
+ ("oracle", "oracle test")
addOptionSet(file_options);
@@ -116,6 +120,33 @@
assert(numPoints == np); // BUG
writer.write(np);
+ else if (hasOption("oracle"))
+ LasReader reader(*ifs);
+ const boost::uint64_t numPoints = reader.getHeader().getNumPoints();
+ libpc::driver::oci::Options options;
+ boost::property_tree::ptree& tree = options.GetPTree();
+ tree.put("capacity", 15);
+ tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
+ tree.put("debug", true);
+ tree.put("verbose", true);
+ CacheFilter cache(reader);
+ libpc::driver::oci::Writer writer(cache, options);
+ //BUG: handle laz writer.setCompressed(false);
+ //writer.setPointFormat( reader.getPointFormatNumber() );
+ size_t np = (size_t)numPoints;
+ assert(numPoints == np); // BUG
+ writer.write(np);
else
LiblasReader reader(*ifs);
diff -r 25fdd984e99d -r 2e5420d71219 src/chipper.cpp
--- a/src/chipper.cpp Thu Mar 10 14:56:29 2011 -0800
+++ b/src/chipper.cpp Thu Mar 10 17:04:03 2011 -0600
@@ -142,6 +142,7 @@
for (boost::uint32_t j = 0; j < m_threshold; j++)
+ if (j == num_to_read) break; // we're outta here
// (v * m_header->GetScaleX()) + m_header->GetOffsetX();
const double x = (buffer.getField<boost::int32_t>(j, indexX) * xscale) + xoffset;
const double y = (buffer.getField<boost::int32_t>(j, indexY) * yscale) + yoffset;
@@ -153,6 +154,7 @@
ref.m_pos = y;
yvec.push_back(ref);
counter++;
num_points_loaded += num_read;
diff -r 25fdd984e99d -r 2e5420d71219 src/drivers/oci/writer.cpp
--- a/src/drivers/oci/writer.cpp Thu Mar 10 14:56:29 2011 -0800
+++ b/src/drivers/oci/writer.cpp Thu Mar 10 17:04:03 2011 -0600
@@ -277,7 +277,6 @@
if (srid == 0) {
s_srid << "NULL";
- // bUse3d = true;
else {
s_srid << srid;
@@ -287,6 +286,7 @@
libpc::Bounds<double> e = m_bounds;
if (IsGeographic(srid)) {
+ // FIXME: This should be overrideable
e.setMinimum(0,-180.0); e.setMaximum(0,180.0);
e.setMinimum(1,-90.0); e.setMaximum(1,90.0);
e.setMinimum(2,0.0); e.setMaximum(2,20000.0);
@@ -327,9 +327,10 @@
// Because of OCIGDALErrorHandler, this is going to throw if there is a
// problem. When it does, the statement should go out of scope and
// be destroyed without leaking.
+ statement->Define(szTable);
statement->Execute();
- statement->Define(szTable);
try {
@@ -434,8 +435,18 @@
std::ostringstream oss;
std::string sql = m_options.GetPTree().get<std::string>(filename);
- oss << sql;
+ if (!sql.size()) return;
+ if (!Utils::fileExists(sql))
+ oss << sql;
+ } else {
+ oss << LoadSQLData(sql); // Our "sql" is really the filename in the ptree
if (m_options.IsDebug())
std::cout << "running "<< filename << " ..." <<std::endl;
@@ -648,6 +659,8 @@
for ( boost::uint32_t i = 0; i < m_chipper.GetBlockCount(); ++i )
const chipper::Block& b = m_chipper.GetBlock(i);
+ // FIXME: This only gets called once!
if (m_bounds.empty()) // If the user already set the bounds for this writer, we're using that
m_bounds.grow(b.GetBounds());
@@ -804,12 +817,6 @@
bool debug = m_options.IsDebug();
- const char* gdal_debug = getenv("CPL_DEBUG");
- if (gdal_debug == 0)
- char d[20] = "CPL_DEBUG=ON";
- putenv(d);
if (debug)
@@ -817,37 +824,30 @@
CPLPopErrorHandler();
if (debug)
+ const char* gdal_debug = getenv("CPL_DEBUG");
+ if (gdal_debug == 0)
+ // FIXME: this leaks
+ const std::string* d = new std::string("CPL_DEBUG=ON");
+ putenv(const_cast<char*>(d->c_str()));
+ const char* gdal_debug2 = getenv("CPL_DEBUG");
+ std::cout << "Setting GDAL debug handler CPL_DEBUG=" << gdal_debug2 << std::endl;
CPLPushErrorHandler(OCIGDALDebugErrorHandler);
- else
- CPLPushErrorHandler(OCIGDALErrorHandler);
-void CPL_STDCALL OCIGDALDebugErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
- std::ostringstream oss;
- if (eErrClass == CE_Failure || eErrClass == CE_Fatal) {
- oss <<"GDAL Failure number=" << err_no << ": " << msg;
- throw libpc_error(oss.str());
- } else if (eErrClass == CE_Debug) {
- std::cout <<"GDAL Debug: " << msg << std::endl;
- } else {
- return;
+ else
+ CPLPushErrorHandler(OCIGDALErrorHandler);
-void CPL_STDCALL OCIGDALErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
- } else {
- return;
std::string to_upper(const std::string& input)
@@ -861,3 +861,28 @@
}}} // namespace libpc::driver::oci
+void CPL_STDCALL OCIGDALErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
+ std::ostringstream oss;
+ if (eErrClass == CE_Failure || eErrClass == CE_Fatal) {
+ oss <<"GDAL Failure number=" << err_no << ": " << msg;
+ throw libpc::libpc_error(oss.str());
+ } else {
+ return;
+void CPL_STDCALL OCIGDALDebugErrorHandler(CPLErr eErrClass, int err_no, const char *msg)
+ } else if (eErrClass == CE_Debug) {
+ std::cout <<"GDAL Debug: " << msg << std::endl;
+ } else {
+ return;
diff -r 25fdd984e99d -r 2e5420d71219 src/drivers/oci/writer.hpp
--- a/src/drivers/oci/writer.hpp Thu Mar 10 14:56:29 2011 -0800
+++ b/src/drivers/oci/writer.hpp Thu Mar 10 17:04:03 2011 -0600
@@ -47,6 +47,10 @@
#include <cpl_port.h>
+void CPL_STDCALL OCIGDALErrorHandler(CPLErr eErrClass, int err_no, const char *msg);
+void CPL_STDCALL OCIGDALDebugErrorHandler(CPLErr eErrClass, int err_no, const char *msg);
More information about the Liblas-commits
