[Liblas-commits] hg-main-tree: Use epsilon compares instead of == for doubles
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 16 09:58:03 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/91a079935d63
changeset: 261:91a079935d63
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Mar 16 08:57:57 2011 -0500
description:
diffstat:
 src/Dimension.cpp         |  12 ++++++++----
 test/unit/ChipperTest.cpp |  10 ++++++----
 test/unit/UtilsTest.cpp   |   2 +-
 3 files changed, 15 insertions(+), 9 deletions(-)
diffs (69 lines):
diff -r 38ad6c913ea5 -r 91a079935d63 src/Dimension.cpp
--- a/src/Dimension.cpp	Wed Mar 16 08:47:42 2011 -0500
+++ b/src/Dimension.cpp	Wed Mar 16 08:57:57 2011 -0500
@@ -44,6 +44,7 @@
 #include <libpc/Utils.hpp>
 #include <iostream>
+#include <limits>
 using namespace boost;
@@ -108,11 +109,14 @@
         m_field == other.m_field &&
         m_byteSize == other.m_byteSize &&
         m_description == other.m_description &&
-        m_min == other.m_min &&
-        m_max == other.m_max &&
+        Utils::compare_approx(m_min, other.m_min, (std::numeric_limits<double>::min)()) &&
+        Utils::compare_approx(m_max, other.m_max, (std::numeric_limits<double>::min)()) &&
         m_precise == other.m_precise &&
-        m_numericScale == other.m_numericScale &&
-        m_numericOffset == other.m_numericOffset)
+        Utils::compare_approx(m_numericScale, other.m_numericScale, (std::numeric_limits<double>::min)()) &&
+        Utils::compare_approx(m_numericOffset, other.m_numericOffset, (std::numeric_limits<double>::min)())
         return true;
diff -r 38ad6c913ea5 -r 91a079935d63 test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp	Wed Mar 16 08:47:42 2011 -0500
+++ b/test/unit/ChipperTest.cpp	Wed Mar 16 08:57:57 2011 -0500
@@ -41,6 +41,8 @@
 #include "support.hpp"
+#include <limits>
 using namespace libpc;
 BOOST_AUTO_TEST_SUITE(ChipperTest)
@@ -72,10 +74,10 @@
         libpc::Range<double> x = ranges[0];
         libpc::Range<double> y = ranges[1];
-        BOOST_CHECK(Utils::compare_approx(x.getMinimum(), (double)635674, (double) 1) == true);
-        BOOST_CHECK(Utils::compare_approx(x.getMaximum(), (double)635994, (double) 1) == true);
-        BOOST_CHECK(Utils::compare_approx(y.getMinimum(), (double)848992, (double) 1) == true);
-        BOOST_CHECK(Utils::compare_approx(y.getMaximum(), (double)849427, (double) 1) == true);
+        BOOST_CHECK(Utils::compare_approx(x.getMinimum(), (double)635674, (std::numeric_limits<double>::min)()) == true);
+        BOOST_CHECK(Utils::compare_approx(x.getMaximum(), (double)635994, (std::numeric_limits<double>::min)()) == true);
+        BOOST_CHECK(Utils::compare_approx(y.getMinimum(), (double)848992, (std::numeric_limits<double>::min)()) == true);
+        BOOST_CHECK(Utils::compare_approx(y.getMaximum(), (double)849427, (std::numeric_limits<double>::min)()) == true);
         std::vector<boost::uint32_t> ids = chipper.GetBlock(70).GetIDs();
diff -r 38ad6c913ea5 -r 91a079935d63 test/unit/UtilsTest.cpp
--- a/test/unit/UtilsTest.cpp	Wed Mar 16 08:47:42 2011 -0500
+++ b/test/unit/UtilsTest.cpp	Wed Mar 16 08:57:57 2011 -0500
@@ -138,7 +138,7 @@
     double y = Utils::read_field<double>(p);
     BOOST_CHECK(x==one);
-    BOOST_CHECK(Utils::compare_approx(y, two, (double) 0.00001) == true);
+    BOOST_CHECK(Utils::compare_approx(y, two, std::numeric_limits<double>::min()) == true);
     return;
More information about the Liblas-commits mailing list
