[Liblas-commits] hg-main-tree: group files for IDE explorer
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 16 10:06:49 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/e6b7fed437fd
changeset: 263:e6b7fed437fd
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Mar 16 10:06:33 2011 -0400
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/a915ac4a897e
changeset: 264:a915ac4a897e
date:      Wed Mar 16 10:06:46 2011 -0400
description:
merge
diffstat:
 apps/Application.cpp              |    4 +-
 src/CMakeLists.txt                |  241 +++++++++++++++++++++++++++++--------
 src/Dimension.cpp                 |   12 +-
 src/Writer.cpp                    |    4 +-
 src/drivers/faux/CMakeLists.txt   |   19 --
 src/drivers/las/CMakeLists.txt    |   24 ---
 src/drivers/liblas/CMakeLists.txt |   16 --
 src/drivers/oci/CMakeLists.txt    |   23 ---
 src/drivers/oci/Writer.cpp        |    2 +-
 src/filters/CMakeLists.txt        |   23 ---
 test/unit/ChipperTest.cpp         |   10 +-
 test/unit/UtilsTest.cpp           |    2 +-
 12 files changed, 204 insertions(+), 176 deletions(-)
diffs (truncated from 519 to 300 lines):
diff -r 161feb02282f -r a915ac4a897e apps/Application.cpp
--- a/apps/Application.cpp	Wed Mar 16 02:35:32 2011 -0400
+++ b/apps/Application.cpp	Wed Mar 16 10:06:46 2011 -0400
@@ -45,10 +45,10 @@
 Application::Application(int argc, char* argv[], const std::string& appName)
-    : m_argc(argc)
+    : m_isVerbose(false)
+    , m_argc(argc)
     , m_argv(argv)
     , m_appName(appName)
-    , m_isVerbose(false)
     return;
diff -r 161feb02282f -r a915ac4a897e src/CMakeLists.txt
--- a/src/CMakeLists.txt	Wed Mar 16 02:35:32 2011 -0400
+++ b/src/CMakeLists.txt	Wed Mar 16 10:06:46 2011 -0400
@@ -14,12 +14,24 @@
     tifvsi.cpp)
 endif()
 # Source files specification
+# Naming format:
+#   LIBPC_CPP - all the .cpp files
+#   LIBPC_HPP - all the .hpp files
+#   LIBPC_<dirname>_CPP - all the .cpp files for the given subdir/namespace
 set(LIBPC_HEADERS_DIR ../include/libpc)
+set(LIBPC_HPP "")
+set(LIBPC_CPP "")
-set(LIBPC_HPP
+# base
+set(LIBPC_BASE_HPP
   ${LIBPC_HEADERS_DIR}/exceptions.hpp
   ${LIBPC_HEADERS_DIR}/export.hpp
   ${LIBPC_HEADERS_DIR}/libpc_config.hpp
@@ -42,60 +54,9 @@
   ${LIBPC_HEADERS_DIR}/Stage.hpp
   ${LIBPC_HEADERS_DIR}/Utils.hpp
   ${LIBPC_HEADERS_DIR}/Writer.hpp
-set(LIBPC_DRIVERS_FAUX_HPP
-  ${LIBPC_HEADERS_DIR}/drivers/faux/Writer.hpp
-  ${LIBPC_HEADERS_DIR}/drivers/faux/Reader.hpp
-FOREACH(file ${LIBPC_DRIVERS_FAUX_HPP})
-        SET(LIBPC_HPP "${LIBPC_HPP};${file}" CACHE INTERNAL "source files for foo")
-ENDFOREACH(file)
-set(LIBPC_DRIVERS_LAS_HPP
- ${LIBPC_HEADERS_DIR}/drivers/las/Header.hpp
-  ${LIBPC_HEADERS_DIR}/drivers/las/Writer.hpp
-  ${LIBPC_HEADERS_DIR}/drivers/las/Reader.hpp
-FOREACH(file ${LIBPC_DRIVERS_LAS_HPP})
-ENDFOREACH(file)
-set(LIBPC_DRIVERS_LIBLAS_HPP
-  ${LIBPC_HEADERS_DIR}/drivers/liblas/Writer.hpp
-  ${LIBPC_HEADERS_DIR}/drivers/liblas/Reader.hpp
-FOREACH(file ${LIBPC_DRIVERS_LIBLAS_HPP})
-ENDFOREACH(file)
-set(LIBPC_DRIVERS_OCI_HPP
-  ${LIBPC_HEADERS_DIR}/drivers/oci/Writer.hpp
-  ${LIBPC_HEADERS_DIR}/drivers/oci/Reader.hpp
-FOREACH(file ${LIBPC_DRIVERS_OCI_HPP})
-ENDFOREACH(file)
-set(LIBPC_FILTERS_HPP
-  ${LIBPC_HEADERS_DIR}/filters/CacheFilter.hpp
-  ${LIBPC_HEADERS_DIR}/filters/ColorFilter.hpp
-  ${LIBPC_HEADERS_DIR}/filters/CropFilter.hpp
-  ${LIBPC_HEADERS_DIR}/filters/DecimationFilter.hpp
-  ${LIBPC_HEADERS_DIR}/filters/MosaicFilter.hpp
-FOREACH(file ${LIBPC_FILTERS_HPP})
-ENDFOREACH(file)
-set (LIBPC_SOURCES "libpc_config.cpp" CACHE INTERNAL "sources to compile")
-set (APPS_CPP_DEPENDENCIES "${LIBPC_LIB_NAME}" CACHE INTERNAL "libraries to link")
-add_subdirectory(drivers)
-add_subdirectory(filters)
-set(LIBPC_CPP
-  ${LIBPC_SOURCES}
+set(LIBPC_BASE_CPP
   Bounds.cpp
   Chipper.cpp
   Color.cpp
@@ -114,13 +75,177 @@
   SpatialReference.cpp
   Stage.cpp
   Utils.cpp
-  Writer.cpp)
+  Writer.cpp
+FOREACH(file ${LIBPC_BASE_HPP})
+        SET(LIBPC_HPP "${LIBPC_HPP};${file}" CACHE INTERNAL "source files for foo")
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_BASE_CPP})
+        SET(LIBPC_CPP "${LIBPC_CPP};${file}" CACHE INTERNAL "source files for foo")
+ENDFOREACH(file)
+# drivers/faux
+set(LIBPC_DRIVERS_FAUX_HPP
+  ${LIBPC_HEADERS_DIR}/drivers/faux/Writer.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/faux/Reader.hpp
+set (LIBPC_DRIVERS_FAUX_CPP
+  ./drivers/faux/Reader.cpp
+  ./drivers/faux/Writer.cpp
+FOREACH(file ${LIBPC_DRIVERS_FAUX_HPP})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_DRIVERS_FAUX_CPP})
+ENDFOREACH(file)
+# drivers/las
+set (LIBPC_DRIVERS_LAS_HPP
+  ${LIBPC_HEADERS_DIR}/drivers/las/Header.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/las/Writer.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/las/Reader.hpp
+  ./drivers/las/LasHeaderReader.hpp
+  ./drivers/las/LasHeaderWriter.hpp
+set (LIBPC_DRIVERS_LAS_CPP
+  ./drivers/las/LasHeaderReader.cpp
+  ./drivers/las/LasHeaderWriter.cpp
+  ./drivers/las/Header.cpp
+  ./drivers/las/Reader.cpp
+  ./drivers/las/Writer.cpp
+FOREACH(file ${LIBPC_DRIVERS_LAS_HPP})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_DRIVERS_LAS_CPP})
+ENDFOREACH(file)
+# drivers/liblas
+set (LIBPC_DRIVERS_LIBLAS_HPP
+  ${LIBPC_HEADERS_DIR}/drivers/liblas/Writer.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/liblas/Reader.hpp
+set (LIBPC_DRIVERS_LIBLAS_CPP
+  ./drivers/liblas/header.cpp
+  ./drivers/liblas/Reader.cpp
+  ./drivers/liblas/Writer.cpp
+FOREACH(file ${LIBPC_DRIVERS_LIBLAS_HPP})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_DRIVERS_LIBLAS_CPP})
+ENDFOREACH(file)
+# drivers/oci
+if (WITH_ORACLE)
+set(LIBPC_DRIVERS_OCI_HPP
+  ${LIBPC_HEADERS_DIR}/drivers/oci/Writer.hpp
+  ${LIBPC_HEADERS_DIR}/drivers/oci/Reader.hpp
+set (LIBPC_DRIVERS_OCI_CPP
+  ./drivers/oci/oci_wrapper.cpp
+  ./drivers/oci/common.cpp
+  ./drivers/oci/header.cpp
+  ./drivers/oci/Reader.cpp
+  ./drivers/oci/Writer.cpp
+FOREACH(file ${LIBPC_DRIVERS_OCI_HPP})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_DRIVERS_OCI_CPP})
+ENDFOREACH(file)
+endif()
+# filters
+set(LIBPC_FILTERS_HPP
+  ${LIBPC_HEADERS_DIR}/filters/CacheFilter.hpp
+  ${LIBPC_HEADERS_DIR}/filters/ColorFilter.hpp
+  ${LIBPC_HEADERS_DIR}/filters/CropFilter.hpp
+  ${LIBPC_HEADERS_DIR}/filters/DecimationFilter.hpp
+  ${LIBPC_HEADERS_DIR}/filters/MosaicFilter.hpp
+set (LIBPC_FILTERS_HPP
+  ./filters/CacheFilter.cpp
+  ./filters/ColorFilter.cpp
+  ./filters/CropFilter.cpp
+  ./filters/DecimationFilter.cpp
+  ./filters/MosaicFilter.cpp
+FOREACH(file ${LIBPC_FILTERS_HPP})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_FILTERS_CPP})
+ENDFOREACH(file)
+# misc
+set (LIBPC_MISC_CPP "libpc_config.cpp" CACHE INTERNAL "sources to compile")
+FOREACH(file ${LIBPC_MISC_CPP})
+ENDFOREACH(file)
 # Group source files for IDE source explorers (e.g. Visual Studio)
 source_group("CMake Files" FILES CMakeLists.txt)
-source_group("Header Files" FILES ${LIBPC_HPP})
-source_group("Source Files" FILES ${LIBPC_CPP})
+source_group("Header Files" FILES ${LIBPC_BASE_HPP})
+source_group("Header Files\\drivers\\faux" FILES ${LIBPC_DRIVERS_FAUX_HPP})
+source_group("Header Files\\drivers\\las" FILES ${LIBPC_DRIVERS_LAS_HPP})
+source_group("Header Files\\drivers\\liblas" FILES ${LIBPC_DRIVERS_LIBLAS_HPP})
+source_group("Header Files\\drivers\\oci" FILES ${LIBPC_DRIVERS_OCI_HPP})
+source_group("Header Files\\filters" FILES ${LIBPC_FILTERS_HPP})
+source_group("Source Files" FILES ${LIBPC_BASE_CPP})
+source_group("Source Files\\misc" FILES ${LIBPC_MISC_CPP})
+source_group("Source Files\\filter" FILES ${LIBPC_FILTERS_CPP})
+source_group("Source Files\\drivers\\faux" FILES ${LIBPC_DRIVERS_FAUX_CPP})
+source_group("Source Files\\drivers\\las" FILES ${LIBPC_DRIVERS_LAS_CPP})
+source_group("Source Files\\drivers\\liblas" FILES ${LIBPC_DRIVERS_LIBLAS_CPP})
+source_group("Source Files\\drivers\\oci" FILES ${LIBPC_DRIVERS_OCI_CPP})
+# rest of stuff
 if(GDAL_FOUND)
     source_group("Source Files\\gdal" FILES ${LIBPC_GDAL_CPP})
 endif()
@@ -128,6 +253,8 @@
 # Standard include directory of libPC library
 include_directories(../include)
+set (APPS_CPP_DEPENDENCIES "${LIBPC_LIB_NAME}" CACHE INTERNAL "libraries to link")
 # Targets settings
diff -r 161feb02282f -r a915ac4a897e src/Dimension.cpp
--- a/src/Dimension.cpp	Wed Mar 16 02:35:32 2011 -0400
More information about the Liblas-commits mailing list
