[Liblas-commits] hg-main-tree: fix up float->double in FauxReader/Writer
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 16 13:11:51 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/e42e3d5bfd7e
changeset: 281:e42e3d5bfd7e
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Mar 16 12:11:43 2011 -0500
description:
diffstat:
 src/drivers/faux/Reader.cpp  |  30 +++++++++++++++---------------
 test/unit/FauxReaderTest.cpp |  12 ++++++------
 test/unit/PointDataTest.cpp  |   7 +++----
 3 files changed, 24 insertions(+), 25 deletions(-)
diffs (119 lines):
diff -r f39615782b97 -r e42e3d5bfd7e src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp	Wed Mar 16 11:22:48 2011 -0500
+++ b/src/drivers/faux/Reader.cpp	Wed Mar 16 12:11:43 2011 -0500
@@ -52,9 +52,9 @@
     Header* header = new Header;
     Schema& schema = header->getSchema();
-    schema.addDimension(Dimension(Dimension::Field_X, Dimension::Float));
-    schema.addDimension(Dimension(Dimension::Field_Y, Dimension::Float));
-    schema.addDimension(Dimension(Dimension::Field_Z, Dimension::Float));
+    schema.addDimension(Dimension(Dimension::Field_X, Dimension::Double));
+    schema.addDimension(Dimension(Dimension::Field_Y, Dimension::Double));
+    schema.addDimension(Dimension(Dimension::Field_Z, Dimension::Double));
     schema.addDimension(Dimension(Dimension::Field_Time, Dimension::Uint64));
     header->setNumPoints(numPoints);
@@ -126,27 +126,27 @@
     for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
-        float x;
-        float y;
-        float z;
+        double x;
+        double y;
+        double z;
         if (m_mode == Random)
-            x = (float)Utils::random(minX, maxX);
-            y = (float)Utils::random(minY, maxY);
-            z = (float)Utils::random(minZ, maxZ);
+            x = (double)Utils::random(minX, maxX);
+            y = (double)Utils::random(minY, maxY);
+            z = (double)Utils::random(minZ, maxZ);
         else
-            x = (float)minX;
-            y = (float)minY;
-            z = (float)minZ;
+            x = (double)minX;
+            y = (double)minY;
+            z = (double)minZ;
         data.setValid(pointIndex);
-        data.setField<float>(pointIndex, offsetX, x);
-        data.setField<float>(pointIndex, offsetY, y);
-        data.setField<float>(pointIndex, offsetZ, z);
+        data.setField<double>(pointIndex, offsetX, x);
+        data.setField<double>(pointIndex, offsetY, y);
+        data.setField<double>(pointIndex, offsetZ, z);
         data.setField<boost::uint64_t>(pointIndex, offsetT, time);
         ++time;
diff -r f39615782b97 -r e42e3d5bfd7e test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp	Wed Mar 16 11:22:48 2011 -0500
+++ b/test/unit/FauxReaderTest.cpp	Wed Mar 16 12:11:43 2011 -0500
@@ -63,9 +63,9 @@
     for (boost::uint32_t i=0; i<numRead; i++)
-        float x = data.getField<float>(i, offsetX);
-        float y = data.getField<float>(i, offsetY);
-        float z = data.getField<float>(i, offsetZ);
+        double x = data.getField<double>(i, offsetX);
+        double y = data.getField<double>(i, offsetY);
+        double z = data.getField<double>(i, offsetZ);
         boost::uint64_t t = data.getField<boost::uint64_t>(i, offsetT);
         BOOST_CHECK( Utils::compare_approx( (double)x, 1.0, (std::numeric_limits<double>::min)()) == true);
@@ -99,9 +99,9 @@
         BOOST_CHECK(x >= 1.0 && x <= 101.0);
diff -r f39615782b97 -r e42e3d5bfd7e test/unit/PointDataTest.cpp
--- a/test/unit/PointDataTest.cpp	Wed Mar 16 11:22:48 2011 -0500
+++ b/test/unit/PointDataTest.cpp	Wed Mar 16 12:11:43 2011 -0500
@@ -139,11 +139,10 @@
       int ii = 10;
-      BOOST_CHECK(Utils::compare_approx(z, ii+100.0, (std::numeric_limits<double>::min)()) == true);
       BOOST_CHECK(x == ii+1);
       BOOST_CHECK(y == ii*10);
-      BOOST_CHECK(z == ii*100);
+      BOOST_CHECK(Utils::compare_approx(z, ii*100.0, (std::numeric_limits<double>::min)()) == true);
     for (int i=1; i<18; i++)
@@ -154,7 +153,7 @@
       int ii = i-1;
       const boost::uint8_t x = d2.getField<boost::uint8_t>(18, 0);
@@ -164,7 +163,7 @@
       int ii = 11;
+      BOOST_CHECK(Utils::compare_approx(z, ii+100.0, (std::numeric_limits<double>::min)()) == true);
     delete data;
More information about the Liblas-commits mailing list
