[Liblas-commits] hg-main-tree: remove IsValid et. al. from PointData
liblas-commits at liblas.org
Wed Mar 16 15:37:33 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/01a57657d746
changeset: 294:01a57657d746
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Mar 16 14:14:56 2011 -0500
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/724c1ec91b06
changeset: 295:724c1ec91b06
date: Wed Mar 16 14:15:10 2011 -0500
description:
merge
Subject: hg-main-tree: add capacity arg to pointData
details: http://hg.libpc.orghg-main-tree/rev/8cb96fc090bf
changeset: 296:8cb96fc090bf
date: Wed Mar 16 14:33:34 2011 -0500
description:
details: http://hg.libpc.orghg-main-tree/rev/51b7dd6c8a17
changeset: 297:51b7dd6c8a17
date: Wed Mar 16 14:33:44 2011 -0500
description:
merge
Subject: hg-main-tree: fix namespaced liblas reader
details: http://hg.libpc.orghg-main-tree/rev/2bf8231103da
changeset: 298:2bf8231103da
date: Wed Mar 16 14:37:25 2011 -0500
description:
diffstat:
apps/pc2pc.cpp | 10 +-
apps/pcinfo.cpp | 4 +-
include/libpc/Filter.hpp | 5 -
include/libpc/Iterator.hpp | 52 ++++++++++++++++++
include/libpc/PointData.hpp | 17 +----
include/libpc/Reader.hpp | 4 -
include/libpc/drivers/las/Header.hpp | 6 +-
include/libpc/drivers/las/Reader.hpp | 6 +-
include/libpc/drivers/las/Writer.hpp | 6 +-
include/libpc/drivers/liblas/Header.hpp | 6 +-
include/libpc/drivers/liblas/Reader.hpp | 7 +-
include/libpc/drivers/liblas/Writer.hpp | 9 +-
include/libpc/drivers/oci/Reader.hpp | 2 +
include/libpc/filters/CropFilter.hpp | 2 +
include/libpc/filters/DecimationFilter.hpp | 2 +
include/libpc/filters/MosaicFilter.hpp | 2 +-
src/CMakeLists.txt | 3 +-
src/Filter.cpp | 6 --
src/Iterator.cpp | 85 ++++++++++++++++++++++++++++++
src/PointData.cpp | 65 +++-------------------
src/Reader.cpp | 19 ------
src/drivers/faux/Reader.cpp | 2 -
src/drivers/faux/Writer.cpp | 31 ++++------
src/drivers/las/Header.cpp | 9 +--
src/drivers/las/LasHeaderReader.cpp | 5 +-
src/drivers/las/LasHeaderReader.hpp | 6 +-
src/drivers/las/LasHeaderWriter.cpp | 9 +--
src/drivers/las/LasHeaderWriter.hpp | 6 +-
src/drivers/las/Reader.cpp | 8 +-
src/drivers/las/Writer.cpp | 7 +-
src/drivers/liblas/Header.cpp | 11 +--
src/drivers/liblas/Reader.cpp | 22 +++---
src/drivers/liblas/Writer.cpp | 32 +++++-----
src/drivers/oci/Reader.cpp | 20 +++++++
src/filters/ColorFilter.cpp | 22 ++----
src/filters/CropFilter.cpp | 51 +++++++++--------
src/filters/DecimationFilter.cpp | 6 ++
src/filters/MosaicFilter.cpp | 16 ++---
test/unit/CMakeLists.txt | 2 +-
test/unit/ChipperTest.cpp | 5 +-
test/unit/CropFilterTest.cpp | 20 +++---
test/unit/LiblasReaderTest.cpp | 6 +-
test/unit/LiblasWriterTest.cpp | 12 ++-
test/unit/main.cpp | 56 +++++++++++++++---
44 files changed, 390 insertions(+), 292 deletions(-)
diffs (truncated from 1501 to 300 lines):
diff -r e42e3d5bfd7e -r 2bf8231103da apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Mar 16 12:11:43 2011 -0500
+++ b/apps/pc2pc.cpp Wed Mar 16 14:37:25 2011 -0500
@@ -107,11 +107,11 @@
if (hasOption("native"))
- LasReader reader(*ifs);
+ libpc::drivers::las::LasReader reader(*ifs);
const boost::uint64_t numPoints = reader.getHeader().getNumPoints();
- LasWriter writer(reader, *ofs);
+ libpc::drivers::las::LasWriter writer(reader, *ofs);
//BUG: handle laz writer.setCompressed(false);
@@ -127,7 +127,7 @@
else if (hasOption("oracle"))
#ifdef HAVE_ORACLE
- LiblasReader reader(*ifs);
+ libpc::drivers::liblas::LiblasReader reader(*ifs);
@@ -158,11 +158,11 @@
#endif
else
- LiblasWriter writer(reader, *ofs);
+ libpc::drivers::liblas::LiblasWriter writer(reader, *ofs);
diff -r e42e3d5bfd7e -r 2bf8231103da apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Wed Mar 16 12:11:43 2011 -0500
+++ b/apps/pcinfo.cpp Wed Mar 16 14:37:25 2011 -0500
@@ -81,11 +81,11 @@
libpc::Reader* reader = NULL;
- reader = new LasReader(*ifs);
+ reader = new libpc::drivers::las::LasReader(*ifs);
else
- reader = new LiblasReader(*ifs);
+ reader = new libpc::drivers::liblas::LiblasReader(*ifs);
boost::uint64_t numPoints = reader->getNumPoints();
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Filter.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -48,11 +48,6 @@
Filter(Stage& prevStage);
protected:
- // advance (or retreat) to the Nth point in the file (absolute,
- // default behaviour for filters is just to call seek on the previous stage
- virtual void seekToPoint(boost::uint64_t pointNum);
-protected:
Stage& m_prevStage;
private:
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Iterator.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -40,7 +40,59 @@
namespace libpc
+class LIBPC_DLL Iterator
+public:
+ Iterator(const Stage& stage);
+ const Stage& getStage() const;
+ // This reads a set of points at the current position in the file.
+ // The schema of the PointData buffer we are given here might
+ // not match our own header's schema. That's okay, though: all
+ // that matters is that the buffer we are given has the fields
+ // we need to write into.
+ // This is NOT virtual. Derived classes should override the
+ // readBuffer function below, not this one.
+ // Returns the number of valid points read.
+ boost::uint32_t read(PointData&);
+ // advance (or retreat) to the Nth point in the file (absolute,
+ // not relative). In some cases, this might be a very slow, painful
+ // function to call.
+ virtual void seekToPoint(boost::uint64_t pointNum) = 0;
+ // Returns the current point number. The first point is 0.
+ // If this number if > getNumPoints(), then no more points
+ // may be read (and atEnd() should be true).
+ boost::uint64_t getCurrentPointIndex() const;
+ // returns true after we've read all the points available to this stage
+ // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
+ bool atEnd() const;
+protected:
+ // Implement this to do the actual work to fill in a buffer of points.
+ virtual boost::uint32_t readBuffer(PointData&) = 0;
+ // Each concrete stage is repsonsible for managing its own current
+ // point index when a read or seek occurs. Call this function to set
+ // the value.
+ void setCurrentPointIndex(boost::uint64_t delta);
+ // this is easier than saying setCurrentPointIndex(getCurrentPointIndex()+n)
+ void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
+private:
+ const Stage& m_stage;
+ boost::uint64_t m_currentPointIndex;
+ Iterator& operator=(const Iterator&); // not implemented
+ Iterator(const Iterator&); // not implemented
} // namespace libpc
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/PointData.hpp
--- a/include/libpc/PointData.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/PointData.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -58,21 +58,22 @@
public:
- typedef std::vector<boost::uint8_t> valid_mask_type;
// note that when we make a PointData object all the fields are initialized to inactive,
// regardless of what the passed-in schema says -- this is because the field object
// represents the state within the owning object, which in this case is a completely
// empty buffer (similarly, all the points in the buffer are marked "invalid")
- PointData(const SchemaLayout&, boost::uint32_t numPoints);
+ PointData(const SchemaLayout&, boost::uint32_t capacity);
~PointData();
// number of points in this buffer
boost::uint32_t getNumPoints() const;
+ inline void setNumPoints(boost::uint32_t v) { m_numPoints = v; }
// number of points in this buffer that have legit data; initially will be zero,
// and after a read() call it will be in the range 0 to getNumPoints()-1
- boost::uint32_t getNumValidPoints();
+ boost::uint32_t getCapacity();
// schema (number and kinds of fields) for a point in this buffer
const SchemaLayout& getSchemaLayout() const
@@ -86,13 +87,6 @@
return m_schemaLayout.getSchema();
- // "valid" means the data for the point can be used; if invalid, the point should
- // be ignored or skipped. (This is done for efficiency; we don't want to have to
- // modify the buffer's size just to "delete" a point.)
- bool isValid(valid_mask_type::size_type pointIndex) const;
- bool allValid() const;
- void setValid(valid_mask_type::size_type pointIndex, bool value=true);
// accessors to a particular field of a particular point in this buffer
template<class T> T getField(std::size_t pointIndex, std::size_t fieldIndex) const;
@@ -114,8 +108,7 @@
boost::uint8_t* m_data;
std::size_t m_pointSize;
boost::uint32_t m_numPoints;
- valid_mask_type m_isValid; // one byte for each point
+ boost::uint32_t m_capacity;
PointData(const PointData&); // not implemented
PointData& operator=(const PointData&); // not implemented
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/Reader.hpp
--- a/include/libpc/Reader.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/Reader.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -46,10 +46,6 @@
public:
Reader();
- // default is to read N points manually
- // override this if you can
private:
Reader& operator=(const Reader&); // not implemented
Reader(const Reader&); // not implemented
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/drivers/las/Header.hpp
--- a/include/libpc/drivers/las/Header.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/las/Header.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -51,8 +51,8 @@
#include <libpc/Header.hpp>
-namespace libpc
+namespace libpc { namespace drivers { namespace las {
class LIBPC_DLL LasHeader : public Header
@@ -409,6 +409,6 @@
LIBPC_DLL std::ostream& operator<<(std::ostream& ostr, const LasHeader&);
-} // namespace libpc
+} } } // namespace
#endif
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/las/Reader.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -40,8 +40,8 @@
#include <libpc/Reader.hpp>
#include <libpc/drivers/las/Header.hpp>
-namespace libpc
class LIBPC_DLL LasReader : public Reader
@@ -69,6 +69,6 @@
LasReader(const LasReader&); // not implemented
+} } } // namespaces
#endif
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/drivers/las/Writer.hpp
--- a/include/libpc/drivers/las/Writer.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/las/Writer.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -38,8 +38,8 @@
#include <libpc/Writer.hpp>
-namespace libpc
class LIBPC_DLL LasWriter : public Writer
@@ -66,6 +66,6 @@
LasWriter(const LasWriter&); // not implemented
#endif
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/drivers/liblas/Header.hpp
--- a/include/libpc/drivers/liblas/Header.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/liblas/Header.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -43,8 +43,8 @@
#include "libpc/Header.hpp"
-namespace libpc
+namespace libpc { namespace drivers { namespace liblas {
class LIBPC_DLL LiblasHeader : public Header
@@ -58,6 +58,6 @@
LIBPC_DLL std::ostream& operator<<(std::ostream& ostr, const LiblasHeader&);
#endif
diff -r e42e3d5bfd7e -r 2bf8231103da include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp Wed Mar 16 12:11:43 2011 -0500
+++ b/include/libpc/drivers/liblas/Reader.hpp Wed Mar 16 14:37:25 2011 -0500
@@ -47,9 +47,8 @@
class Reader;
-namespace libpc
More information about the Liblas-commits
