[Liblas-commits] hg-main-tree: fix up CacheFilter in light of
changes to PointDat...
liblas-commits at liblas.org
Thu Mar 17 09:57:19 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/44eb8b8885ee
changeset: 312:44eb8b8885ee
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Mar 17 08:56:45 2011 -0500
description:
fix up CacheFilter in light of changes to PointData wrt capacity vs. count
Subject: hg-main-tree: fix up PointDataTest in light of changes to PointData wrt capacity vs. count
details: http://hg.libpc.orghg-main-tree/rev/5d0067fe2896
changeset: 313:5d0067fe2896
date: Thu Mar 17 08:57:04 2011 -0500
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/0ee55bbcac4b
changeset: 314:0ee55bbcac4b
date: Thu Mar 17 08:57:14 2011 -0500
description:
merge
diffstat:
include/libpc/Schema.hpp | 16 +++++++++-
include/libpc/exceptions.hpp | 11 ++++++-
include/libpc/filters/ColorFilter.hpp | 2 +-
src/filters/CacheFilter.cpp | 6 +-
src/filters/ColorFilter.cpp | 36 +++++++++++++++++++++--
test/unit/CMakeLists.txt | 1 +
test/unit/ColorFilterTest.cpp | 53 +++++++++++++++++++++++++++++++++++
test/unit/PointDataTest.cpp | 15 ++++++---
test/unit/SchemaTest.cpp | 8 +++++
9 files changed, 133 insertions(+), 15 deletions(-)
diffs (285 lines):
diff -r c12273525164 -r 0ee55bbcac4b include/libpc/Schema.hpp
--- a/include/libpc/Schema.hpp Wed Mar 16 16:55:46 2011 -0400
+++ b/include/libpc/Schema.hpp Thu Mar 17 08:57:14 2011 -0500
@@ -97,7 +97,21 @@
return index != -1;
- // returns -1 if the index not found
+ bool hasDimension(Dimension::Field field, Dimension::DataType datatype) const
+ int index = m_indexTable[field];
+ if (index == -1) return false;
+ const Dimension& dim = m_dimensions[index];
+ if (dim.getDataType() != datatype) return false;
+ return true;
+ bool hasDimension(const Dimension& dim) const
+ return hasDimension(dim.getField(), dim.getDataType());
+ // assumes the index does, in fact, exist
int getDimensionIndex(Dimension::Field field) const
diff -r c12273525164 -r 0ee55bbcac4b include/libpc/exceptions.hpp
--- a/include/libpc/exceptions.hpp Wed Mar 16 16:55:46 2011 -0400
+++ b/include/libpc/exceptions.hpp Thu Mar 17 08:57:14 2011 -0500
@@ -73,7 +73,7 @@
/// Flags are composed with composed with Point::DataMemberFlag.
/// Testing flags example: bool timeValid = e.who() & Point::eTime;
unsigned int who() const
return m_who;
@@ -101,6 +101,15 @@
+// for when a stage doesn't get the schema it expects
+class impedance_invalid : public libpc_error
+public:
+ impedance_invalid(std::string const& msg)
+ : libpc_error(msg)
// use this for attempts to use a feature not compiled in, e.g. laszip or gdal
class configuration_error : public libpc_error
diff -r c12273525164 -r 0ee55bbcac4b include/libpc/filters/ColorFilter.hpp
--- a/include/libpc/filters/ColorFilter.hpp Wed Mar 16 16:55:46 2011 -0400
+++ b/include/libpc/filters/ColorFilter.hpp Thu Mar 17 08:57:14 2011 -0500
@@ -53,7 +53,7 @@
private:
boost::uint32_t readBuffer(PointData&);
+ void checkImpedance();
void getColor(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue);
ColorFilter& operator=(const ColorFilter&); // not implemented
diff -r c12273525164 -r 0ee55bbcac4b src/filters/CacheFilter.cpp
--- a/src/filters/CacheFilter.cpp Wed Mar 16 16:55:46 2011 -0400
+++ b/src/filters/CacheFilter.cpp Thu Mar 17 08:57:14 2011 -0500
@@ -119,14 +119,14 @@
// for now, we only read from the cache if they are asking for one point
// (this avoids the problem of an N-point request needing more than one
// cached block to satisfy it)
- if (data.getNumPoints() != 1)
+ if (data.getCapacity() != 1)
const boost::uint32_t numRead = m_prevStage.read(data);
// if they asked for a full block and we got a full block,
// and the block we got is properly aligned and not already cached,
// then let's cache it!
- if (data.getNumPoints() == m_cacheBlockSize && numRead == m_cacheBlockSize &&
+ if (data.getCapacity() == m_cacheBlockSize && numRead == m_cacheBlockSize &&
(currentPointIndex % m_cacheBlockSize == 0) &&
m_cache->lookup(currentPointIndex) == NULL)
@@ -137,7 +137,7 @@
incrementCurrentPointIndex(numRead);
- m_numPointsRead += data.getNumPoints();
+ m_numPointsRead += numRead;
m_numPointsRequested += data.getCapacity();
return numRead;
diff -r c12273525164 -r 0ee55bbcac4b src/filters/ColorFilter.cpp
--- a/src/filters/ColorFilter.cpp Wed Mar 16 16:55:46 2011 -0400
+++ b/src/filters/ColorFilter.cpp Thu Mar 17 08:57:14 2011 -0500
@@ -33,6 +33,7 @@
#include <cassert>
+#include <libpc/exceptions.hpp>
#include <libpc/Color.hpp>
#include <libpc/filters/ColorFilter.hpp>
@@ -41,12 +42,39 @@
ColorFilter::ColorFilter(Stage& prevStage)
: Filter(prevStage)
+ checkImpedance();
+ return;
+void ColorFilter::checkImpedance()
Schema& schema = getHeader().getSchema();
- // add the three u8 fields
- schema.addDimension(Dimension(Dimension::Field_Red, Dimension::Uint8));
- schema.addDimension(Dimension(Dimension::Field_Green, Dimension::Uint8));
- schema.addDimension(Dimension(Dimension::Field_Blue, Dimension::Uint8));
+ Dimension dimZ(Dimension::Field_Z, Dimension::Uint8);
+ if (schema.hasDimension(dimZ) == false)
+ throw impedance_invalid("color filter does not have Z/uint8 field");
+ Dimension dimRed(Dimension::Field_Red, Dimension::Uint8);
+ Dimension dimGreen(Dimension::Field_Green, Dimension::Uint8);
+ Dimension dimBlue(Dimension::Field_Blue, Dimension::Uint8);
+ // are there already u8 fields for color?
+ if (!schema.hasDimension(dimRed))
+ schema.addDimension(dimRed);
+ if (!schema.hasDimension(dimGreen))
+ schema.addDimension(dimGreen);
+ if (!schema.hasDimension(dimBlue))
+ schema.addDimension(dimBlue);
return;
diff -r c12273525164 -r 0ee55bbcac4b test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Wed Mar 16 16:55:46 2011 -0400
+++ b/test/unit/CMakeLists.txt Thu Mar 17 08:57:14 2011 -0500
@@ -13,6 +13,7 @@
ChipperTest.cpp
ColorTest.cpp
ConfigTest.cpp
+ ColorFilterTest.cpp
CropFilterTest.cpp
DecimationFilterTest.cpp
DimensionTest.cpp
diff -r c12273525164 -r 0ee55bbcac4b test/unit/ColorFilterTest.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/ColorFilterTest.cpp Thu Mar 17 08:57:14 2011 -0500
@@ -0,0 +1,53 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <boost/cstdint.hpp>
+#include <libpc/drivers/faux/Reader.hpp>
+#include <libpc/drivers/faux/Writer.hpp>
+#include <libpc/filters/ColorFilter.hpp>
+using namespace libpc;
+BOOST_AUTO_TEST_SUITE(ColorFilter)
+BOOST_AUTO_TEST_CASE(test1)
+ // BUG: tbd
+ return;
+BOOST_AUTO_TEST_SUITE_END()
diff -r c12273525164 -r 0ee55bbcac4b test/unit/PointDataTest.cpp
--- a/test/unit/PointDataTest.cpp Wed Mar 16 16:55:46 2011 -0400
+++ b/test/unit/PointDataTest.cpp Thu Mar 17 08:57:14 2011 -0500
@@ -53,7 +53,7 @@
PointData data(layout, 10);
- BOOST_CHECK(data.getNumPoints() == 10);
+ BOOST_CHECK(data.getCapacity() == 10);
BOOST_CHECK(data.getSchemaLayout() == layout);
return;
@@ -78,10 +78,12 @@
std::size_t offZ = layout.getDimensionLayout(2).getByteOffset();
BOOST_CHECK(offZ==5);
- PointData* data = new PointData(layout, 17);
+ boost::uint32_t capacity = 17;
+ PointData* data = new PointData(layout, capacity);
+ BOOST_CHECK(data->getCapacity() == capacity);
// write the data into the buffer
- for (int i=0; i<17; i++)
+ for (int i=0; i<data->getCapacity(); i++)
const boost::uint8_t x = static_cast<boost::uint8_t>(i)+1;
const boost::int32_t y = i*10;
@@ -90,8 +92,11 @@
data->setField(i, 0, x);
data->setField(i, 1, y);
data->setField(i, 2, z);
+ data->setNumPoints(i+1);
+ BOOST_CHECK(data->getCapacity() ==17);
+ BOOST_CHECK(data->getNumPoints() ==17);
return data;
@@ -163,7 +168,7 @@
int ii = 11;
BOOST_CHECK(x == ii+1);
BOOST_CHECK(y == ii*10);
- BOOST_CHECK(Utils::compare_approx(z, ii+100.0, (std::numeric_limits<double>::min)()) == true);
+ BOOST_CHECK(Utils::compare_approx(z, ii*100.0, (std::numeric_limits<double>::min)()) == true);
delete data;
diff -r c12273525164 -r 0ee55bbcac4b test/unit/SchemaTest.cpp
--- a/test/unit/SchemaTest.cpp Wed Mar 16 16:55:46 2011 -0400
+++ b/test/unit/SchemaTest.cpp Thu Mar 17 08:57:14 2011 -0500
@@ -63,6 +63,14 @@
s4.addDimension(d1);
BOOST_CHECK(s1!=s4);
BOOST_CHECK(s4!=s1);
+ BOOST_CHECK(s1.hasDimension(Dimension::Field_X));
+ BOOST_CHECK(s1.hasDimension(Dimension::Field_X, Dimension::Uint32));
+ BOOST_CHECK(!s1.hasDimension(Dimension::Field_X, Dimension::Uint16));
+ Dimension dx32(Dimension::Field_X, Dimension::Uint32);
+ Dimension dx16(Dimension::Field_X, Dimension::Uint16);
+ BOOST_CHECK(s1.hasDimension(dx32));
+ BOOST_CHECK(!s1.hasDimension(dx16));
More information about the Liblas-commits
