[Liblas-commits] hg-main-tree: second try at the global data path
liblas-commits at liblas.org
Thu Mar 17 12:38:25 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/fcf3cc21be42
changeset: 331:fcf3cc21be42
user: Kirk McKelvey <kirkoman at gmail.com>
date: Thu Mar 17 11:38:16 2011 -0500
description:
diffstat:
test/unit/ChipperTest.cpp | 4 +--
test/unit/LiblasReaderTest.cpp | 5 +--
test/unit/LiblasWriterTest.cpp | 10 +++-----
test/unit/main.cpp | 47 +++--------------------------------------
test/unit/support.cpp | 13 +++++++++++
test/unit/support.hpp | 5 ++++
6 files changed, 29 insertions(+), 55 deletions(-)
diffs (189 lines):
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/ChipperTest.cpp Thu Mar 17 11:38:16 2011 -0500
@@ -44,14 +44,12 @@
using namespace libpc;
using namespace libpc::drivers::liblas;
-extern std::string g_data_path;
BOOST_AUTO_TEST_SUITE(ChipperTest)
BOOST_AUTO_TEST_CASE(test_construction)
- std::istream* ifs = Utils::openFile(g_data_path + "1.2-with-color.las");
+ std::istream* ifs = Utils::openFile(TestConfig::g_data_path + "1.2-with-color.las");
LiblasReader reader(*ifs);
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/LiblasReaderTest.cpp
--- a/test/unit/LiblasReaderTest.cpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/LiblasReaderTest.cpp Thu Mar 17 11:38:16 2011 -0500
@@ -36,13 +36,12 @@
#include <boost/cstdint.hpp>
#include <libpc/drivers/liblas/reader.hpp>
+#include "support.hpp"
BOOST_AUTO_TEST_SUITE(LiblasReaderTest)
@@ -71,7 +70,7 @@
BOOST_AUTO_TEST_CASE(test_1)
BOOST_CHECK(reader.getName() == "Liblas Reader");
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/LiblasWriterTest.cpp Thu Mar 17 11:38:16 2011 -0500
@@ -45,8 +45,6 @@
BOOST_AUTO_TEST_SUITE(LiblasWriterTest)
BOOST_AUTO_TEST_CASE(test_simple_las)
@@ -54,7 +52,7 @@
// remove file from earlier run, if needed
Utils::deleteFile("temp.las");
std::ostream* ofs = Utils::createFile("temp.las");
@@ -80,7 +78,7 @@
Utils::closeFile(ofs);
Utils::closeFile(ifs);
- bool filesSame = compare_files("temp.las", g_data_path + "simple.las");
+ bool filesSame = compare_files("temp.las", TestConfig::g_data_path + "simple.las");
BOOST_CHECK(filesSame);
if (filesSame)
@@ -96,7 +94,7 @@
std::ostream* ofs = Utils::createFile("temp.laz");
@@ -121,7 +119,7 @@
- bool filesSame = compare_files("temp.laz", g_data_path + "simple.laz");
+ bool filesSame = compare_files("temp.laz", TestConfig::g_data_path + "simple.laz");
if (filesSame)
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/main.cpp
--- a/test/unit/main.cpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/main.cpp Thu Mar 17 11:38:16 2011 -0500
@@ -32,16 +32,11 @@
* OF SUCH DAMAGE.
-#include <string>
+#define BOOST_TEST_MODULE Main
+#include <boost/test/unit_test.hpp>
-#ifndef BOOST_TEST_DYN_LINK
-#define BOOST_TEST_MODULE Main
-#endif
-#include <boost/test/unit_test.hpp>
-#include <boost/test/utils/assign_op.hpp>
-std::string g_data_path;
+BOOST_GLOBAL_FIXTURE(TestConfig)
// Testing macros:
// BOOST_TEST_MESSAGE("...")
@@ -62,37 +57,3 @@
// <path> # path to data (default=../test/data)
-#ifdef BOOST_TEST_ALTERNATIVE_INIT_API
-bool
-libpc_init_unit_test()
-#else
-::boost::unit_test::test_suite*
-libpc_init_unit_test_suite( int, char* [] )
-#endif
- ::boost::unit_test::assign_op( ::boost::unit_test::framework::master_test_suite().p_name.value, "Main", 0 );
- int argc = ::boost::unit_test::framework::master_test_suite().argc;
- char **argv = ::boost::unit_test::framework::master_test_suite().argv;
- if (argc > 1)
- g_data_path = argv[1];
- else
- g_data_path = "../test/data";
- if (g_data_path[g_data_path.size()-1] != '/')
- g_data_path += "/";
- return true;
-#else
- return 0;
-#endif
-#if defined(BOOST_TEST_DYN_LINK)
-int
-main( int argc, char* argv[] )
- return ::boost::unit_test::unit_test_main( &libpc_init_unit_test, argc, argv );
-#endif // BOOST_TEST_DYN_LINK
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/support.cpp
--- a/test/unit/support.cpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/support.cpp Thu Mar 17 11:38:16 2011 -0500
@@ -87,3 +87,16 @@
return true;
+std::string TestConfig::g_data_path = "../test/data";
+TestConfig::TestConfig()
+ int argc = ::boost::unit_test::framework::master_test_suite().argc;
+ char **argv = ::boost::unit_test::framework::master_test_suite().argv;
+ if (argc > 1)
+ g_data_path = argv[1];
+ if (g_data_path[g_data_path.size() - 1] != '/')
+ g_data_path += "/";
diff -r 84c592526b99 -r fcf3cc21be42 test/unit/support.hpp
--- a/test/unit/support.hpp Thu Mar 17 10:16:35 2011 -0500
+++ b/test/unit/support.hpp Thu Mar 17 11:38:16 2011 -0500
@@ -43,4 +43,9 @@
// verify if two files are the same
extern bool compare_files(const std::string& file1, const std::string& file2);
+struct TestConfig {
+ TestConfig();
+ static std::string g_data_path;
#endif
More information about the Liblas-commits
