[Liblas-commits] hg-main-tree: removed bounds from read() calls
liblas-commits at liblas.org
Thu Mar 17 15:26:53 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/274b836e6540
changeset: 347:274b836e6540
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Mar 17 15:26:33 2011 -0400
description:
diffstat:
include/libpc/Stage.hpp | 4 ++--
include/libpc/drivers/faux/Reader.hpp | 2 +-
include/libpc/drivers/las/Reader.hpp | 2 +-
include/libpc/drivers/liblas/Reader.hpp | 2 +-
include/libpc/filters/CacheFilter.hpp | 2 +-
include/libpc/filters/ColorFilter.hpp | 2 +-
include/libpc/filters/CropFilter.hpp | 2 +-
include/libpc/filters/DecimationFilter.hpp | 2 +-
include/libpc/filters/MosaicFilter.hpp | 2 +-
src/Chipper.cpp | 3 +--
src/Stage.cpp | 4 ++--
src/Writer.cpp | 4 +---
src/drivers/faux/Reader.cpp | 4 ++--
src/drivers/las/Reader.cpp | 5 ++---
src/drivers/liblas/Reader.cpp | 2 +-
src/filters/CacheFilter.cpp | 6 +++---
src/filters/ColorFilter.cpp | 4 ++--
src/filters/CropFilter.cpp | 6 +++---
src/filters/DecimationFilter.cpp | 6 +++---
src/filters/MosaicFilter.cpp | 4 ++--
test/unit/CacheFilterTest.cpp | 8 +++-----
test/unit/DecimationFilterTest.cpp | 4 +---
test/unit/FauxReaderTest.cpp | 8 ++------
test/unit/FauxWriterTest.cpp | 18 +++++++++---------
test/unit/LiblasReaderTest.cpp | 7 +++----
test/unit/MosaicFilterTest.cpp | 4 +---
26 files changed, 51 insertions(+), 66 deletions(-)
diffs (truncated from 484 to 300 lines):
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/Stage.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -70,7 +70,7 @@
// readBuffer function below, not this one.
// Returns the number of valid points read.
- boost::uint32_t read(PointData&, const Bounds<double>& bounds);
+ boost::uint32_t read(PointData&);
// advance (or retreat) to the Nth point in the file (absolute,
// not relative). In some cases, this might be a very slow, painful
@@ -92,7 +92,7 @@
protected:
// Implement this to do the actual work to fill in a buffer of points.
- virtual boost::uint32_t readBuffer(PointData& pointData, const Bounds<double>& bounds) = 0;
+ virtual boost::uint32_t readBuffer(PointData& pointData) = 0;
// Each concrete stage is repsonsible for managing its own current
// point index when a read or seek occurs. Call this function to set
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/faux/Reader.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -72,7 +72,7 @@
Iterator* createIterator(const Bounds<double>& bounds);
private:
- boost::uint32_t readBuffer(PointData&, const Bounds<double>& bounds);
+ boost::uint32_t readBuffer(PointData&);
Mode m_mode;
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/las/Reader.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -59,7 +59,7 @@
protected:
- boost::uint32_t readBuffer(PointData& data, const Bounds<double>& bounds);
+ boost::uint32_t readBuffer(PointData& data);
LasHeader& getLasHeader();
void setLasHeader(const LasHeader&);
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/drivers/liblas/Reader.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -67,7 +67,7 @@
private:
- virtual boost::uint32_t readBuffer(PointData& data, const Bounds<double>& bounds);
+ virtual boost::uint32_t readBuffer(PointData& data);
LiblasHeader& getLiblasHeader();
void setLiblasHeader(const LiblasHeader&);
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/filters/CacheFilter.hpp
--- a/include/libpc/filters/CacheFilter.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/CacheFilter.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -80,7 +80,7 @@
private:
boost::uint64_t m_numPointsRequested;
boost::uint64_t m_numPointsRead;
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/filters/ColorFilter.hpp
--- a/include/libpc/filters/ColorFilter.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/ColorFilter.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -54,7 +54,7 @@
private:
void checkImpedance();
void getColor(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue);
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/filters/CropFilter.hpp
--- a/include/libpc/filters/CropFilter.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/CropFilter.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -55,7 +55,7 @@
private:
Bounds<double> m_bounds;
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/filters/DecimationFilter.hpp
--- a/include/libpc/filters/DecimationFilter.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/DecimationFilter.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -55,7 +55,7 @@
private:
int m_step;
diff -r c0f0c4b82e52 -r 274b836e6540 include/libpc/filters/MosaicFilter.hpp
--- a/include/libpc/filters/MosaicFilter.hpp Thu Mar 17 15:11:02 2011 -0400
+++ b/include/libpc/filters/MosaicFilter.hpp Thu Mar 17 15:26:33 2011 -0400
@@ -54,7 +54,7 @@
private:
std::vector<Stage*> m_prevStages;
diff -r c0f0c4b82e52 -r 274b836e6540 src/Chipper.cpp
--- a/src/Chipper.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Chipper.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -136,8 +136,7 @@
PointData buffer(schema, num_to_read);
- const Bounds<double>& bounds = Bounds<double>::getDefaultSpatialExtent();
- boost::uint32_t num_read = m_stage.read(buffer, bounds);
+ boost::uint32_t num_read = m_stage.read(buffer);
if (num_read == 0) break;
assert(num_read <= num_to_read);
diff -r c0f0c4b82e52 -r 274b836e6540 src/Stage.cpp
--- a/src/Stage.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Stage.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -91,9 +91,9 @@
-boost::uint32_t Stage::read(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t Stage::read(PointData& data)
- const boost::uint32_t numPointsRead = readBuffer(data, bounds);
+ const boost::uint32_t numPointsRead = readBuffer(data);
return numPointsRead;
diff -r c0f0c4b82e52 -r 274b836e6540 src/Writer.cpp
--- a/src/Writer.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/Writer.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -73,8 +73,6 @@
boost::uint64_t Writer::write(std::size_t targetNumPointsToWrite)
- const Bounds<double>& maxBounds = Bounds<double>::getDefaultSpatialExtent();
m_targetNumPointsToWrite = targetNumPointsToWrite;
m_actualNumPointsWritten = 0;
@@ -87,7 +85,7 @@
PointData buffer(m_prevStage.getHeader().getSchema(), numPointsToReadThisChunk);
- boost::uint32_t numPointsReadThisChunk = m_prevStage.read(buffer, maxBounds);
+ boost::uint32_t numPointsReadThisChunk = m_prevStage.read(buffer);
assert(numPointsReadThisChunk <= numPointsToReadThisChunk);
boost::uint32_t numPointsWrittenThisChunk = writeBuffer(buffer);
diff -r c0f0c4b82e52 -r 274b836e6540 src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/faux/Reader.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -94,7 +94,7 @@
-boost::uint32_t Reader::readBuffer(PointData& data, const Bounds<double>& userBounds)
+boost::uint32_t Reader::readBuffer(PointData& data)
if (data.getSchemaLayout().getSchema().getDimensions().size() != 4)
throw not_yet_implemented("need to add ability to read from arbitrary fields");
@@ -166,7 +166,7 @@
-Iterator* Reader::createIterator(const Bounds<double>& bounds)
+Iterator* Reader::createIterator(const Bounds<double>&)
throw not_yet_implemented("iterator");
diff -r c0f0c4b82e52 -r 274b836e6540 src/drivers/las/Reader.cpp
--- a/src/drivers/las/Reader.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/las/Reader.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -81,15 +81,14 @@
// BUG: we can move the stream a constant amount
PointData pointData(getHeader().getSchema(), chunk);
- read(pointData, maxBounds);
+ read(pointData);
// just drop the points on the floor and return
return;
-boost::uint32_t LasReader::readBuffer(PointData& pointData, const Bounds<double>&)
+boost::uint32_t LasReader::readBuffer(PointData& pointData)
boost::uint32_t numPoints = pointData.getCapacity();
diff -r c0f0c4b82e52 -r 274b836e6540 src/drivers/liblas/Reader.cpp
--- a/src/drivers/liblas/Reader.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/drivers/liblas/Reader.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -233,7 +233,7 @@
-boost::uint32_t LiblasReader::readBuffer(PointData& pointData, const Bounds<double>&)
+boost::uint32_t LiblasReader::readBuffer(PointData& pointData)
boost::uint32_t i = 0;
diff -r c0f0c4b82e52 -r 274b836e6540 src/filters/CacheFilter.cpp
--- a/src/filters/CacheFilter.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/filters/CacheFilter.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -113,7 +113,7 @@
-boost::uint32_t CacheFilter::readBuffer(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t CacheFilter::readBuffer(PointData& data)
const boost::uint64_t currentPointIndex = getCurrentPointIndex();
@@ -122,7 +122,7 @@
// cached block to satisfy it)
if (data.getCapacity() != 1)
- const boost::uint32_t numRead = m_prevStage.read(data, bounds);
+ const boost::uint32_t numRead = m_prevStage.read(data);
// if they asked for a full block and we got a full block,
// and the block we got is properly aligned and not already cached,
@@ -161,7 +161,7 @@
// Not in the cache, so do a normal read :-(
m_numPointsRead += numRead;
m_numPointsRequested += numRead;
incrementCurrentPointIndex(numRead);
diff -r c0f0c4b82e52 -r 274b836e6540 src/filters/ColorFilter.cpp
--- a/src/filters/ColorFilter.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/filters/ColorFilter.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -87,9 +87,9 @@
-boost::uint32_t ColorFilter::readBuffer(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t ColorFilter::readBuffer(PointData& data)
- m_prevStage.read(data, bounds);
+ m_prevStage.read(data);
boost::uint32_t numPoints = data.getNumPoints();
diff -r c0f0c4b82e52 -r 274b836e6540 src/filters/CropFilter.cpp
--- a/src/filters/CropFilter.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/filters/CropFilter.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -62,10 +62,10 @@
-boost::uint32_t CropFilter::readBuffer(PointData& data, const Bounds<double>& bounds)
+boost::uint32_t CropFilter::readBuffer(PointData& data)
PointData srcData(data.getSchemaLayout(), data.getCapacity());
- boost::uint32_t numSrcPointsRead = m_prevStage.read(srcData, bounds);
+ boost::uint32_t numSrcPointsRead = m_prevStage.read(srcData);
const SchemaLayout& schemaLayout = data.getSchemaLayout();
const Schema& schema = schemaLayout.getSchema();
@@ -103,7 +103,7 @@
-Iterator* CropFilter::createIterator(const Bounds<double>& bounds)
+Iterator* CropFilter::createIterator(const Bounds<double>&)
diff -r c0f0c4b82e52 -r 274b836e6540 src/filters/DecimationFilter.cpp
--- a/src/filters/DecimationFilter.cpp Thu Mar 17 15:11:02 2011 -0400
+++ b/src/filters/DecimationFilter.cpp Thu Mar 17 15:26:33 2011 -0400
@@ -62,11 +62,11 @@
-boost::uint32_t DecimationFilter::readBuffer(PointData& dstData, const Bounds<double>& bounds)
+boost::uint32_t DecimationFilter::readBuffer(PointData& dstData)
More information about the Liblas-commits
