[Liblas-commits] hg-main-tree: iterator work checkpoint
liblas-commits at liblas.org
Tue Mar 22 10:34:11 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/64e82ef08e5d
changeset: 379:64e82ef08e5d
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Mar 18 19:10:08 2011 -0400
description:
Subject: hg-main-tree: iterator work checkpoint -stage-based read methods now gone
details: http://hg.libpc.orghg-main-tree/rev/dcfcf8c78bca
changeset: 380:dcfcf8c78bca
date: Fri Mar 18 20:54:29 2011 -0400
description:
Subject: hg-main-tree: put the Iters into their own files
details: http://hg.libpc.orghg-main-tree/rev/7cbd8049b2aa
changeset: 381:7cbd8049b2aa
date: Fri Mar 18 18:46:41 2011 -0700
description:
Subject: hg-main-tree: made Stages be const wrt other stages and iterators
details: http://hg.libpc.orghg-main-tree/rev/48371a0708d3
changeset: 382:48371a0708d3
date: Fri Mar 18 19:26:41 2011 -0700
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/771da57f961e
changeset: 383:771da57f961e
date: Tue Mar 22 07:34:07 2011 -0700
description:
merge
diffstat:
CMakeLists.txt | 1 +
apps/pc2pc.cpp | 3 -
apps/pcinfo.cpp | 4 +
doc/_static/files/2011_Codesprint_libpc_design.pdf | 0
doc/_static/files/2011_Codesprint_libpc_implementation.pdf | 0
doc/sprint/libpc-design.pptx | 0
doc/sprint/libpc-implementation.pptx | 0
doc/sprint/notes.txt | 59 ---
include/libpc/Filter.hpp | 6 +-
include/libpc/FilterIterator.hpp | 7 +-
include/libpc/Iterator.hpp | 9 +-
include/libpc/Stage.hpp | 42 +--
include/libpc/drivers/faux/Iterator.hpp | 62 +++
include/libpc/drivers/faux/Reader.hpp | 10 +-
include/libpc/drivers/las/Iterator.hpp | 64 +++
include/libpc/drivers/las/Reader.hpp | 13 +-
include/libpc/drivers/liblas/Iterator.hpp | 71 +++
include/libpc/drivers/liblas/Reader.hpp | 11 +-
include/libpc/filters/CacheFilter.hpp | 14 +-
include/libpc/filters/CacheFilterIterator.hpp | 65 +++
include/libpc/filters/ColorFilter.hpp | 12 +-
include/libpc/filters/ColorFilterIterator.hpp | 64 +++
include/libpc/filters/CropFilter.hpp | 12 +-
include/libpc/filters/CropFilterIterator.hpp | 63 +++
include/libpc/filters/DecimationFilter.hpp | 13 +-
include/libpc/filters/DecimationFilterIterator.hpp | 63 +++
include/libpc/filters/MosaicFilter.hpp | 22 +-
include/libpc/filters/MosaicFilterIterator.hpp | 67 +++
mpg-config.bat | 16 +-
src/CMakeLists.txt | 25 +-
src/Chipper.cpp | 7 +-
src/Filter.cpp | 4 +-
src/FilterIterator.cpp | 14 +-
src/Iterator.cpp | 5 +-
src/Stage.cpp | 31 -
src/Writer.cpp | 10 +-
src/drivers/faux/Iterator.cpp | 133 +++++++
src/drivers/faux/Reader.cpp | 76 +---
src/drivers/las/Iterator.cpp | 235 +++++++++++++
src/drivers/las/Reader.cpp | 185 +----------
src/drivers/liblas/Iterator.cpp | 173 +++++++++
src/drivers/liblas/Reader.cpp | 118 +------
src/filters/CacheFilter.cpp | 71 +---
src/filters/CacheFilterIterator.cpp | 117 ++++++
src/filters/ColorFilter.cpp | 40 +-
src/filters/ColorFilterIterator.cpp | 92 +++++
src/filters/CropFilter.cpp | 55 +--
src/filters/CropFilterIterator.cpp | 102 +++++
src/filters/DecimationFilter.cpp | 34 +-
src/filters/DecimationFilterIterator.cpp | 83 ++++
src/filters/MosaicFilter.cpp | 86 +---
src/filters/MosaicFilterIterator.cpp | 126 ++++++
test/unit/CacheFilterTest.cpp | 14 +-
test/unit/DecimationFilterTest.cpp | 7 +-
test/unit/FauxReaderTest.cpp | 17 +-
test/unit/LiblasReaderTest.cpp | 14 +-
test/unit/MosaicFilterTest.cpp | 12 +-
57 files changed, 1816 insertions(+), 843 deletions(-)
diffs (truncated from 3714 to 300 lines):
diff -r fa468a10815f -r 771da57f961e CMakeLists.txt
--- a/CMakeLists.txt Fri Mar 18 11:03:09 2011 -0500
+++ b/CMakeLists.txt Tue Mar 22 07:34:07 2011 -0700
@@ -342,6 +342,7 @@
if(MRSID_FOUND)
set(CMAKE_REQUIRED_LIBRARIES ${MRSID_LIBRARY})
include_directories(${MRSID_INCLUDE_DIR})
+ add_definitions(-DHAVE_MRSID=1)
endif()
endif()
diff -r fa468a10815f -r 771da57f961e apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Fri Mar 18 11:03:09 2011 -0500
+++ b/apps/pc2pc.cpp Tue Mar 22 07:34:07 2011 -0700
@@ -122,8 +122,6 @@
writer.write(np);
-#ifdef HAVE_ORACLE
else if (hasOption("oracle"))
#ifdef HAVE_ORACLE
@@ -155,7 +153,6 @@
throw configuration_error("libPC not compiled with Oracle support");
#endif
-#endif
else
libpc::drivers::liblas::LiblasReader reader(*ifs);
diff -r fa468a10815f -r 771da57f961e apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Fri Mar 18 11:03:09 2011 -0500
+++ b/apps/pcinfo.cpp Tue Mar 22 07:34:07 2011 -0700
@@ -12,7 +12,9 @@
#include <libpc/drivers/las/Reader.hpp>
#include <libpc/drivers/liblas/Reader.hpp>
+#ifdef HAVE_MRSID
#include <libpc/drivers/mrsid/Reader.hpp>
+#endif
#include <iostream>
@@ -92,10 +94,12 @@
else
reader = new libpc::drivers::liblas::LiblasReader(*ifs);
+#ifdef HAVE_MRSID
else if (!m_inputFile.substr(ext).compare("sid"))
reader = new libpc::drivers::mrsid::Reader(m_inputFile.c_str());
+#endif
else
diff -r fa468a10815f -r 771da57f961e doc/_static/files/2011_Codesprint_libpc_design.pdf
Binary file doc/_static/files/2011_Codesprint_libpc_design.pdf has changed
diff -r fa468a10815f -r 771da57f961e doc/_static/files/2011_Codesprint_libpc_implementation.pdf
Binary file doc/_static/files/2011_Codesprint_libpc_implementation.pdf has changed
diff -r fa468a10815f -r 771da57f961e doc/sprint/libpc-design.pptx
Binary file doc/sprint/libpc-design.pptx has changed
diff -r fa468a10815f -r 771da57f961e doc/sprint/libpc-implementation.pptx
Binary file doc/sprint/libpc-implementation.pptx has changed
diff -r fa468a10815f -r 771da57f961e doc/sprint/notes.txt
--- a/doc/sprint/notes.txt Fri Mar 18 11:03:09 2011 -0500
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,59 +0,0 @@
-.. _sprint_notes:
-Montreal Sprint Notes
-* website
-* documentation format for headers
-* unit tests for CL apps
-* pcinfo tool - basic support
-* CL mssgs to stdout or stderr? usage/help/error
-* platform macros -- LIBPC_OS_WIN32, etc
-* dump routines -- every class needs oper<<, dump()
-* build swig bindings from CMake
-* typedef boost::uint32_t uint32_t ?
-* isolate strings for error messages (anywhere else?)
-* implement Signaller support in Stage
-* the "Capabilities" issue
-* the PointData templating issue
-* the sequential-or-random-reads issue
-* do we need Header class?
-* does Boost give math class support for Range, Vector, Bounds?
-* bitfields in Dimensions?
-* MG4/Lidar driver support, inc. CMake detection
-* Text driver
-* BAG driver
-* octtree for libpc::Stage
-* finish native las and liblas drivers
-* implement metadata/VLR support
-* implement spatial referencing support
-* update Notes to match realities
-* discuss funding opportunities
-* in-place writer ability, breaks model
diff -r fa468a10815f -r 771da57f961e include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp Fri Mar 18 11:03:09 2011 -0500
+++ b/include/libpc/Filter.hpp Tue Mar 22 07:34:07 2011 -0700
@@ -45,12 +45,12 @@
class LIBPC_DLL Filter : public Stage
public:
- Filter(Stage& prevStage);
+ Filter(const Stage& prevStage);
- Stage& getPrevStage() const;
+ const Stage& getPrevStage() const;
protected:
- Stage& m_prevStage;
+ const Stage& m_prevStage;
private:
Filter& operator=(const Filter&); // not implemented
diff -r fa468a10815f -r 771da57f961e include/libpc/FilterIterator.hpp
--- a/include/libpc/FilterIterator.hpp Fri Mar 18 11:03:09 2011 -0500
+++ b/include/libpc/FilterIterator.hpp Tue Mar 22 07:34:07 2011 -0700
@@ -44,10 +44,13 @@
class FilterIterator : public Iterator
public:
- FilterIterator(Filter&, const Bounds<double>& bounds);
+ FilterIterator(const Filter&);
+protected:
+ Iterator& getPrevIterator();
private:
- Filter& m_stageAsFilter;
+ const Filter& m_stageAsFilter;
Iterator* m_prevIterator;
diff -r fa468a10815f -r 771da57f961e include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp Fri Mar 18 11:03:09 2011 -0500
+++ b/include/libpc/Iterator.hpp Tue Mar 22 07:34:07 2011 -0700
@@ -45,9 +45,9 @@
class LIBPC_DLL Iterator
public:
- Iterator(Stage& stage, const Bounds<double>& bounds);
+ Iterator(const Stage& stage);
- Stage& getStage();
+ const Stage& getStage() const;
// This reads a set of points at the current position in the file.
@@ -81,7 +81,7 @@
virtual boost::uint32_t readBuffer(PointData&) = 0;
// Each concrete stage is repsonsible for managing its own current
- // point index when a read or seek occurs. Call this function to set
+ // point index when a read or seek occurs. Call this function t o set
// the value.
void setCurrentPointIndex(boost::uint64_t delta);
@@ -89,9 +89,8 @@
void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
private:
- Stage& m_stage;
+ const Stage& m_stage;
boost::uint64_t m_currentPointIndex;
- const Bounds<double> m_bounds;
Iterator& operator=(const Iterator&); // not implemented
Iterator(const Iterator&); // not implemented
diff -r fa468a10815f -r 771da57f961e include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Fri Mar 18 11:03:09 2011 -0500
+++ b/include/libpc/Stage.hpp Tue Mar 22 07:34:07 2011 -0700
@@ -59,60 +59,20 @@
// words. The last word should generally be "Reader" or "Filter".
virtual const std::string& getName() const = 0;
- // This reads a set of points at the current position in the file.
- // The schema of the PointData buffer we are given here might
- // not match our own header's schema. That's okay, though: all
- // that matters is that the buffer we are given has the fields
- // we need to write into.
- // This is NOT virtual. Derived classes should override the
- // readBuffer function below, not this one.
- // Returns the number of valid points read.
- boost::uint32_t read(PointData&);
- // advance (or retreat) to the Nth point in the file (absolute,
- // not relative). In some cases, this might be a very slow, painful
- // function to call.
- virtual void seekToPoint(boost::uint64_t pointNum) = 0;
// returns the number of points this stage has available
// (actually a convenience function that gets it from the header)
boost::uint64_t getNumPoints() const;
- // returns true after we've read all the points available to this stage
- // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
- bool atEnd() const;
const Header& getHeader() const;
Header& getHeader();
- virtual Iterator* createIterator(const Bounds<double>& bounds) = 0;
+ virtual Iterator* createIterator() const = 0;
protected:
- // Implement this to do the actual work to fill in a buffer of points.
- virtual boost::uint32_t readBuffer(PointData& pointData) = 0;
- // Each concrete stage is repsonsible for managing its own current
- // the value.
- void setCurrentPointIndex(boost::uint64_t delta);
- // this is easier than saying setCurrentPointIndex(getCurrentPointIndex()+n)
- void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
void setHeader(Header*); // stage takes ownership
- // Returns the current point number. The first point is 0.
- // If this number if > getNumPoints(), then no more points
- // may be read (and atEnd() should be true).
- boost::uint64_t getCurrentPointIndex() const;
private:
Header* m_header;
- boost::uint64_t m_currentPointIndex;
Stage& operator=(const Stage&); // not implemented
Stage(const Stage&); // not implemented
diff -r fa468a10815f -r 771da57f961e include/libpc/drivers/faux/Iterator.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/faux/Iterator.hpp Tue Mar 22 07:34:07 2011 -0700
@@ -0,0 +1,62 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
More information about the Liblas-commits
