[Liblas-commits] laszip: more LAZ and formatting
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Mar 23 05:28:32 EDT 2011
details:   http://hg.liblas.orglaszip/rev/0e51d121331b
changeset: 197:0e51d121331b
user:      isenburg
date:      Wed Mar 23 02:40:29 2011 -0700
description:
diffstat:
 docs/source/index.rst |  23 ++++++++++++++---------
 1 files changed, 14 insertions(+), 9 deletions(-)
diffs (43 lines):
diff -r ecf77a491a50 -r 0e51d121331b docs/source/index.rst
--- a/docs/source/index.rst	Tue Mar 22 14:20:22 2011 -0700
+++ b/docs/source/index.rst	Wed Mar 23 02:40:29 2011 -0700
@@ -60,17 +60,14 @@
 * laszip lidar.laz lidar_copy.las
 LASzip compression can be many times smaller and many times faster than
-`bz2`_, `gzip`_, and `rar`_ because it takes advantage of knowing what the
-different bytes in a LAS file represent.
-Another advantage of LASzip over generic compressors is that it allows you to
-treat the compressed LAZ files just like standard LAS files and load them
-directly from compressed form into your application without the need to
-decompress and write out the data in an uncompressed form. The availability of
-the two APIs `libLAS`_ and `lasLIB`_ with LASzip capability makes it easy to
+generic compressors like `bz2`_, `gzip`_, and `rar`_ because it knows what
+the different bytes in a LAS file represent. Another advantage of LASzip
+is that it allows you to treat compressed LAZ files just like standard LAS
+files. You can load them directly from compressed form into your application
+without needing to decompress them onto disk first. The availability of two
+APIs, `libLAS`_ and `lasLIB`_, with LASzip capability makes it very easy to
 add native LAZ support to your own software package.
 Download LAZ data
@@ -80,7 +77,15 @@
 * ftp://lidar.dnr.state.mn.us/data/raw/county/faribault/laz/
 * ftp://lidar.dnr.state.mn.us/data/raw/county/fillmore/laz/
 * ftp://lidar.dnr.state.mn.us/data/raw/county/freeborn/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/houston/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/mower/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/olmsted/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/pine/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/pope/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/steele/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/wabasha/laz/
 * ftp://lidar.dnr.state.mn.us/data/raw/county/waseca/laz/
+* ftp://lidar.dnr.state.mn.us/data/raw/county/winona/laz/
 * http://liblas.org/samples/
 .. toctree::
More information about the Liblas-commits mailing list
