[Liblas-commits] hg-main-tree: banish vile const_cast
liblas-commits at liblas.org
Wed Mar 23 12:18:43 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/7487a3b19bc0
changeset: 397:7487a3b19bc0
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Mar 22 16:05:20 2011 -0700
description:
Subject: hg-main-tree: iter work
details: http://hg.libpc.orghg-main-tree/rev/e5d4d5519e3f
changeset: 398:e5d4d5519e3f
date: Wed Mar 23 08:01:47 2011 -0700
description:
iter work
Subject: hg-main-tree: iter work - tests passing now
details: http://hg.libpc.orghg-main-tree/rev/9b398706f6f1
changeset: 399:9b398706f6f1
date: Wed Mar 23 08:36:31 2011 -0700
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/8cb5d9abf57a
changeset: 400:8cb5d9abf57a
date: Wed Mar 23 08:36:43 2011 -0700
description:
merge
Subject: hg-main-tree: rename some iter functions
details: http://hg.libpc.orghg-main-tree/rev/f96012950314
changeset: 401:f96012950314
date: Wed Mar 23 08:48:01 2011 -0700
description:
Subject: hg-main-tree: iter work - hiding the point count management
details: http://hg.libpc.orghg-main-tree/rev/b505d7fc67af
changeset: 402:b505d7fc67af
date: Wed Mar 23 09:10:20 2011 -0700
description:
details: http://hg.libpc.orghg-main-tree/rev/7dd22518e8a2
changeset: 403:7dd22518e8a2
date: Wed Mar 23 09:10:46 2011 -0700
description:
merge
diffstat:
include/libpc/Chipper.hpp | 22 +---
include/libpc/FilterIterator.hpp | 6 +
include/libpc/Iterator.hpp | 45 +++++-----
include/libpc/PointBuffer.hpp | 7 +-
include/libpc/drivers/faux/Iterator.hpp | 6 +-
include/libpc/drivers/las/Iterator.hpp | 6 +-
include/libpc/drivers/liblas/Iterator.hpp | 6 +-
include/libpc/filters/CacheFilterIterator.hpp | 6 +-
include/libpc/filters/ColorFilter.hpp | 2 +
include/libpc/filters/ColorFilterIterator.hpp | 10 +-
include/libpc/filters/CropFilter.hpp | 4 +
include/libpc/filters/CropFilterIterator.hpp | 10 +-
include/libpc/filters/DecimationFilter.hpp | 2 +
include/libpc/filters/DecimationFilterIterator.hpp | 6 +-
include/libpc/filters/MosaicFilterIterator.hpp | 11 +-
include/libpc/types.hpp | 5 +-
src/Chipper.cpp | 15 +--
src/FilterIterator.cpp | 6 +
src/Iterator.cpp | 60 +++++++++++--
src/PointBuffer.cpp | 6 +-
src/Stage.cpp | 1 -
src/Utils.cpp | 2 +-
src/drivers/faux/Iterator.cpp | 30 +++++--
src/drivers/faux/Reader.cpp | 2 +
src/drivers/las/Iterator.cpp | 18 ++-
src/drivers/liblas/Iterator.cpp | 21 +++-
src/drivers/oci/Reader.cpp | 2 +-
src/filters/CacheFilterIterator.cpp | 22 ++--
src/filters/ColorFilter.cpp | 30 +++++++
src/filters/ColorFilterIterator.cpp | 46 +++-------
src/filters/CropFilter.cpp | 42 ++++++++++
src/filters/CropFilterIterator.cpp | 90 ++++++++++++---------
src/filters/DecimationFilter.cpp | 23 +++++
src/filters/DecimationFilterIterator.cpp | 67 +++++++++++----
src/filters/MosaicFilterIterator.cpp | 16 ++-
test/unit/CacheFilterTest.cpp | 23 +++--
test/unit/LiblasReaderTest.cpp | 20 ++--
37 files changed, 455 insertions(+), 241 deletions(-)
diffs (truncated from 1336 to 300 lines):
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/Chipper.hpp
--- a/include/libpc/Chipper.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/Chipper.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -29,13 +29,13 @@
public:
- PtRef() :m_data(0) {};
+ PtRef(PointBuffer& buffer) :m_data(buffer) {};
// PtRef(PointBuffer const& data) : m_data(0), m_pointSize(data.getSchemaLayout().getByteSize()) {};
double m_pos;
boost::uint32_t m_ptindex;
boost::uint32_t m_oindex;
- boost::uint8_t* m_data;
+ PointBuffer m_data;
boost::uint32_t m_pointSize;
bool operator < (const PtRef& pt) const
@@ -46,13 +46,7 @@
m_ptindex(other.m_ptindex),
m_oindex(other.m_oindex),
m_data(other.m_data)
- if (other.m_data)
- m_data = new boost::uint8_t[m_pointSize * 1];
- memcpy(m_data, other.m_data, m_pointSize*1);
PtRef& operator=(const PtRef& rhs)
@@ -61,11 +55,7 @@
m_pos = rhs.m_pos;
m_ptindex = rhs.m_ptindex;
m_oindex = rhs.m_oindex;
- if (rhs.m_data)
- m_data = new boost::uint8_t [m_pointSize * 1];
- memcpy(m_data, rhs.m_data, m_pointSize*1);
+ m_data = rhs.m_data;
return *this;
@@ -84,8 +74,8 @@
{ return m_vec.size(); }
void reserve(std::vector<PtRef>::size_type n)
{ m_vec.reserve(n); }
- void resize(std::vector<PtRef>::size_type n)
- { m_vec.resize(n); }
+ // void resize(std::vector<PtRef>::size_type n)
+ // { m_vec.resize(n); }
void push_back(const PtRef& ref)
{ m_vec.push_back(ref); }
std::vector<PtRef>::iterator begin()
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/FilterIterator.hpp
--- a/include/libpc/FilterIterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/FilterIterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -48,7 +48,13 @@
virtual ~FilterIterator();
protected:
+ // from Iterator
+ virtual boost::uint32_t readImpl(PointBuffer&) = 0;
+ virtual boost::uint64_t skipImpl(boost::uint64_t pointNum) = 0;
+ virtual bool atEndImpl() const = 0;
Iterator& getPrevIterator();
+ const Iterator& getPrevIterator() const;
private:
const Filter& m_stageAsFilter;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/Iterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -57,41 +57,44 @@
// that matters is that the buffer we are given has the fields
// we need to write into.
- // This is NOT virtual. Derived classes should override the
- // readBuffer function below, not this one.
// Returns the number of valid points read.
boost::uint32_t read(PointBuffer&);
- // advance (or retreat) to the Nth point in the file (absolute,
- // not relative). In some cases, this might be a very slow, painful
- // function to call.
- virtual void seekToPoint(boost::uint64_t pointNum) = 0;
+ // advance N points ahead in the file
+ // In some cases, this might be a very slow, painful function to call because
+ // it might entail physically reading the N points (and dropping the data on the
+ // floor)
+ // Returns the number actually skipped (which might be less than count, if the
+ // end of the stage was reached first).
+ boost::uint64_t skip(boost::uint64_t count);
// returns true after we've read all the points available to this stage
- // (actually a convenience function that compares getCurrentPointIndex and getNumPoints)
- bool atEnd();
+ bool atEnd() const;
-protected:
// Returns the current point number. The first point is 0.
// If this number if > getNumPoints(), then no more points
// may be read (and atEnd() should be true).
- boost::uint64_t getCurrentPointIndex() const;
+ // All stages have the notion of a current point number, even for stages
+ // that are not really "oredered", in that the index just starts at zero
+ // and increments by N every time another N points are read
+ boost::uint64_t getIndex() const;
- // Implement this to do the actual work to fill in a buffer of points.
- virtual boost::uint32_t readBuffer(PointBuffer&) = 0;
+ // used to control intermediate buffering needed by some stages
+ void setChunkSize(boost::uint32_t size);
+ boost::uint32_t getChunkSize() const;
- // Each concrete stage is repsonsible for managing its own current
- // point index when a read or seek occurs. Call this function t o set
- // the value.
- void setCurrentPointIndex(boost::uint64_t delta);
- // this is easier than saying setCurrentPointIndex(getCurrentPointIndex()+n)
- void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
+protected:
private:
const Stage& m_stage;
- boost::uint64_t m_currentPointIndex;
+ boost::uint64_t m_index;
+ boost::uint32_t m_chunkSize;
Iterator& operator=(const Iterator&); // not implemented
Iterator(const Iterator&); // not implemented
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/PointBuffer.hpp
--- a/include/libpc/PointBuffer.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/PointBuffer.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -74,15 +74,16 @@
const Bounds<double>& getSpatialBounds() const;
void setSpatialBounds(const Bounds<double>& bounds);
- // number of points in this buffer
+ // This is the number of points in this buffer that actually have valid data. This number
+ // will be less than or equal to the getCapacity() value.
boost::uint32_t getNumPoints() const;
inline void setNumPoints(boost::uint32_t v) { assert(v <= m_capacity);m_numPoints = v; }
inline boost::uint32_t& getNumPointsRef() {assert(m_numPoints <= m_capacity);return m_numPoints; }
- // number of points in this buffer that have legit data; initially will be zero,
- // and after a read() call it will be in the range 0 to getNumPoints()-1
+ // This is the number of points that this buffer is allocated to be able to store.
+ // This is a fixed constant, set at ctor time by the person constructing the buffer.
inline boost::uint32_t getCapacity() const { return m_capacity; }
// schema (number and kinds of fields) for a point in this buffer
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/drivers/faux/Iterator.hpp
--- a/include/libpc/drivers/faux/Iterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/drivers/faux/Iterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -48,10 +48,10 @@
public:
Iterator(const Reader& reader);
- void seekToPoint(boost::uint64_t);
private:
- boost::uint32_t readBuffer(PointBuffer&);
+ boost::uint64_t skipImpl(boost::uint64_t);
+ boost::uint32_t readImpl(PointBuffer&);
+ bool atEndImpl() const;
const Reader& m_stageAsDerived;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/drivers/las/Iterator.hpp
--- a/include/libpc/drivers/las/Iterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/drivers/las/Iterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -50,10 +50,10 @@
public:
Iterator(const LasReader& reader);
private:
const LasReader& m_stageAsDerived;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/drivers/liblas/Iterator.hpp
--- a/include/libpc/drivers/liblas/Iterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/drivers/liblas/Iterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -58,10 +58,10 @@
public:
Iterator(const LiblasReader& reader);
private:
const LiblasReader& m_stageAsDerived;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/filters/CacheFilterIterator.hpp
--- a/include/libpc/filters/CacheFilterIterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/filters/CacheFilterIterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -51,10 +51,10 @@
public:
CacheFilterIterator(const CacheFilter& filter);
private:
const CacheFilter& m_stageAsDerived;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/filters/ColorFilter.hpp
--- a/include/libpc/filters/ColorFilter.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/filters/ColorFilter.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -58,6 +58,8 @@
Iterator* createIterator() const;
+ void processBuffer(PointBuffer& data) const;
private:
void checkImpedance();
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/filters/ColorFilterIterator.hpp
--- a/include/libpc/filters/ColorFilterIterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/filters/ColorFilterIterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -50,12 +50,12 @@
public:
ColorFilterIterator(const ColorFilter& filter);
+private:
-private:
- const ColorFilter& m_stageAsDerived;
+ const ColorFilter& m_colorFilter;
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/filters/CropFilter.hpp
--- a/include/libpc/filters/CropFilter.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/filters/CropFilter.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -55,6 +55,10 @@
+ // returns number of points accepted into the data buffer (which may be less than data.getNumPoints(),
+ // if we're calling this routine multiple times with the same buffer
+ boost::uint32_t processBuffer(PointBuffer& dstData, const PointBuffer& srcData) const;
const Bounds<double>& getBounds() const;
private:
diff -r b19b24391fd1 -r 7dd22518e8a2 include/libpc/filters/CropFilterIterator.hpp
--- a/include/libpc/filters/CropFilterIterator.hpp Tue Mar 22 15:55:30 2011 -0700
+++ b/include/libpc/filters/CropFilterIterator.hpp Wed Mar 23 09:10:46 2011 -0700
@@ -49,12 +49,12 @@
public:
CropFilterIterator(const CropFilter& filter);
+private:
-private:
- const CropFilter& m_stageAsDerived;
+ const CropFilter& m_cropFilter;
More information about the Liblas-commits
