[Liblas-commits] hg-main-tree: refactor for const-correctness and
	to unfriend the...
    liblas-commits at liblas.org
    Wed Mar 23 13:54:33 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/55dde853abae
changeset: 410:55dde853abae
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Mar 23 10:54:26 2011 -0700
description:
refactor for const-correctness and to unfriend the Iter
diffstat:
 include/libpc/drivers/faux/Reader.hpp |   6 +-
 src/drivers/faux/Iterator.cpp         |  69 +---------------------------------
 src/drivers/faux/Reader.cpp           |  71 +++++++++++++++++++++++++++++++++++
 3 files changed, 76 insertions(+), 70 deletions(-)
diffs (182 lines):
diff -r 8404b7fd80ce -r 55dde853abae include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp	Wed Mar 23 10:47:37 2011 -0700
+++ b/include/libpc/drivers/faux/Reader.hpp	Wed Mar 23 10:54:26 2011 -0700
@@ -40,8 +40,6 @@
 namespace libpc { namespace drivers { namespace faux {
-class Iterator;
 // The FauxReader doesn't read from disk, but instead just makes up data for its
 // points.  The reader is constructed with a given bounding box and a given
 // number of points.
@@ -74,7 +72,11 @@
     libpc::Iterator* createIterator() const;
+    // this is called by the stage's iterator
+    boost::uint32_t processBuffer(PointBuffer& data, boost::uint64_t index) const;
 private:
     Mode m_mode;
     Reader& operator=(const Reader&); // not implemented
diff -r 8404b7fd80ce -r 55dde853abae src/drivers/faux/Iterator.cpp
--- a/src/drivers/faux/Iterator.cpp	Wed Mar 23 10:47:37 2011 -0700
+++ b/src/drivers/faux/Iterator.cpp	Wed Mar 23 10:54:26 2011 -0700
@@ -72,74 +72,7 @@
 boost::uint32_t Iterator::readImpl(PointBuffer& data)
-    Reader& reader = const_cast<Reader&>(m_reader);       // BUG BUG BUG
-    if (data.getSchemaLayout().getSchema().getDimensions().size() != 4)
-        throw not_yet_implemented("need to add ability to read from arbitrary fields");
-    // make up some data and put it into the buffer
-    const SchemaLayout& schemaLayout = data.getSchemaLayout();
-    const Schema& schema = schemaLayout.getSchema();
-    Header& header = reader.getHeader();
-    // how many are they asking for?
-    boost::uint64_t numPointsWanted = data.getCapacity();
-    // we can only give them as many as we have left
-    boost::uint64_t numPointsAvailable = header.getNumPoints() - getIndex();
-    if (numPointsAvailable < numPointsWanted)
-        numPointsWanted = numPointsAvailable;
-    const Bounds<double>& bounds = header.getBounds();
-    const std::vector< Range<double> >& dims = bounds.dimensions();
-    const double minX = dims[0].getMinimum();
-    const double maxX = dims[0].getMaximum();
-    const double minY = dims[1].getMinimum();
-    const double maxY = dims[1].getMaximum();
-    const double minZ = dims[2].getMinimum();
-    const double maxZ = dims[2].getMaximum();
-    const int offsetT = schema.getDimensionIndex(Dimension::Field_Time);
-    const int offsetX = schema.getDimensionIndex(Dimension::Field_X);
-    const int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
-    const int offsetZ = schema.getDimensionIndex(Dimension::Field_Z);
-    boost::uint64_t time = getIndex();
-    const Reader::Mode mode = reader.getMode();
-    boost::uint32_t& cnt = data.getNumPointsRef();
-    cnt = 0;
-    for (boost::uint32_t pointIndex=0; pointIndex<numPointsWanted; pointIndex++)
-        double x;
-        double y;
-        double z;
-        if (mode == Reader::Random)
-            x = (double)Utils::random(minX, maxX);
-            y = (double)Utils::random(minY, maxY);
-            z = (double)Utils::random(minZ, maxZ);
-        else
-            x = (double)minX;
-            y = (double)minY;
-            z = (double)minZ;
-        data.setField<double>(pointIndex, offsetX, x);
-        data.setField<double>(pointIndex, offsetY, y);
-        data.setField<double>(pointIndex, offsetZ, z);
-        data.setField<boost::uint64_t>(pointIndex, offsetT, time);
-        ++time;
-        ++cnt;
-        assert(cnt <= data.getCapacity());
-    return cnt;
+    return m_reader.processBuffer(data, getIndex());
 } } } // namespaces
diff -r 8404b7fd80ce -r 55dde853abae src/drivers/faux/Reader.cpp
--- a/src/drivers/faux/Reader.cpp	Wed Mar 23 10:47:37 2011 -0700
+++ b/src/drivers/faux/Reader.cpp	Wed Mar 23 10:54:26 2011 -0700
@@ -110,4 +110,75 @@
+boost::uint32_t Reader::processBuffer(PointBuffer& data, boost::uint64_t index) const
+    const SchemaLayout& schemaLayout = data.getSchemaLayout();
+    const Schema& schema = schemaLayout.getSchema();
+    const Header& header = getHeader();
+    if (schema.getDimensions().size() != 4)
+        throw not_yet_implemented("need to add ability to read from arbitrary fields");
+    // make up some data and put it into the buffer
+    // how many are they asking for?
+    boost::uint64_t numPointsWanted = data.getCapacity();
+    // we can only give them as many as we have left
+    boost::uint64_t numPointsAvailable = header.getNumPoints() - index;
+    if (numPointsAvailable < numPointsWanted)
+        numPointsWanted = numPointsAvailable;
+    const Bounds<double>& bounds = header.getBounds();
+    const std::vector< Range<double> >& dims = bounds.dimensions();
+    const double minX = dims[0].getMinimum();
+    const double maxX = dims[0].getMaximum();
+    const double minY = dims[1].getMinimum();
+    const double maxY = dims[1].getMaximum();
+    const double minZ = dims[2].getMinimum();
+    const double maxZ = dims[2].getMaximum();
+    const int offsetT = schema.getDimensionIndex(Dimension::Field_Time);
+    const int offsetX = schema.getDimensionIndex(Dimension::Field_X);
+    const int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
+    const int offsetZ = schema.getDimensionIndex(Dimension::Field_Z);
+    boost::uint64_t time = index;
+    const Reader::Mode mode = getMode();
+    boost::uint32_t& cnt = data.getNumPointsRef();
+    cnt = 0;
+    for (boost::uint32_t pointIndex=0; pointIndex<numPointsWanted; pointIndex++)
+        double x;
+        double y;
+        double z;
+        if (mode == Reader::Random)
+            x = (double)Utils::random(minX, maxX);
+            y = (double)Utils::random(minY, maxY);
+            z = (double)Utils::random(minZ, maxZ);
+        else
+            x = (double)minX;
+            y = (double)minY;
+            z = (double)minZ;
+        data.setField<double>(pointIndex, offsetX, x);
+        data.setField<double>(pointIndex, offsetY, y);
+        data.setField<double>(pointIndex, offsetZ, z);
+        data.setField<boost::uint64_t>(pointIndex, offsetT, time);
+        ++time;
+        ++cnt;
+        assert(cnt <= data.getCapacity());
+    return cnt;
 } } } // namespaces
More information about the Liblas-commits
