[Liblas-commits] hg-main-tree: completely back up the chipper in
preparation for ...
liblas-commits at liblas.org
Wed Mar 23 17:37:22 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/9798b3952688
changeset: 416:9798b3952688
user: Howard Butler <hobu.inc at gmail.com>
date: Wed Mar 23 16:37:10 2011 -0500
description:
completely back up the chipper in preparation for random iterators
diffstat:
include/libpc/Chipper.hpp | 23 +++----------
src/Chipper.cpp | 76 ++++++++--------------------------------------
test/unit/ChipperTest.cpp | 32 +++++++++---------
3 files changed, 35 insertions(+), 96 deletions(-)
diffs (275 lines):
diff -r 0475852dc135 -r 9798b3952688 include/libpc/Chipper.hpp
--- a/include/libpc/Chipper.hpp Wed Mar 23 14:27:22 2011 -0500
+++ b/include/libpc/Chipper.hpp Wed Mar 23 16:37:10 2011 -0500
@@ -1,21 +1,19 @@
#ifndef LIBLAS_CHIPPER_H
#define LIBLAS_CHIPPER_H
-#include <libpc/PointBuffer.hpp>
+#include <libpc/Stage.hpp>
#include <libpc/Bounds.hpp>
#include <libpc/export.hpp>
#include <libpc/Dimension.hpp>
-#include <libpc/exceptions.hpp>
+#include <libpc/Iterator.hpp>
+#include <boost/scoped_ptr.hpp>
#include <vector>
namespace libpc
-class Schema;
-class Stage;
-class CacheFilter;
namespace chipper
@@ -28,17 +26,13 @@
class LIBPC_DLL PtRef
public:
double m_pos;
boost::uint32_t m_ptindex;
boost::uint32_t m_oindex;
- boost::uint32_t m_pointSize;
- boost::uint8_t m_data[40];
bool operator < (const PtRef& pt) const
{ return m_pos < pt.m_pos; }
struct LIBPC_DLL RefList
@@ -76,7 +70,7 @@
class LIBPC_DLL Chipper;
-class LIBPC_DLL Block : libpc::PointBuffer
+class LIBPC_DLL Block
friend class Chipper;
@@ -91,13 +85,9 @@
// double m_ymax;
public:
- Block(Schema const& schema, boost::uint32_t capacity);
- Block(Block const& block);
std::vector<boost::uint32_t> GetIDs() const;
libpc::Bounds<double> const& GetBounds() const {return m_bounds;}
void SetBounds(libpc::Bounds<double> const& bounds) {m_bounds = bounds;}
- PointBuffer GetPointBuffer(libpc::SchemaLayout const& layout) const;
// double GetXmin() const
// { return m_xmin; }
// double GetYmin() const
@@ -113,7 +103,7 @@
public:
Chipper(Stage& prevStage, boost::uint32_t max_partition_size) :
m_stage(prevStage), m_threshold(max_partition_size),
- m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE), m_cache(0)
+ m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
void Chip();
@@ -143,7 +133,6 @@
RefList m_xvec;
RefList m_yvec;
RefList m_spare;
- CacheFilter* m_cache;
Chipper& operator=(const Chipper&); // not implemented
Chipper(const Chipper&); // not implemented
diff -r 0475852dc135 -r 9798b3952688 src/Chipper.cpp
--- a/src/Chipper.cpp Wed Mar 23 14:27:22 2011 -0500
+++ b/src/Chipper.cpp Wed Mar 23 16:37:10 2011 -0500
@@ -38,14 +38,10 @@
* OF SUCH DAMAGE.
-#include <libpc/Chipper.hpp>
-#include <libpc/Header.hpp>
-#include <libpc/Stage.hpp>
-#include <libpc/filters/CacheFilter.hpp>
+#include <libpc/chipper.hpp>
#include <libpc/Utils.hpp>
// boost
#include <boost/cstdint.hpp>
-#include <boost/scoped_ptr.hpp>
// std
#include <cmath>
@@ -83,20 +79,6 @@
namespace libpc { namespace chipper {
-Block::Block(Schema const& schema, boost::uint32_t capacity)
- : PointBuffer(schema, capacity)
-Block::Block(Block const& other)
- : PointBuffer(other)
- , m_list_p(other.m_list_p)
- , m_left(other.m_left)
- , m_right(other.m_right)
- , m_bounds(other.m_bounds)
vector<boost::uint32_t> Block::GetIDs() const
vector<boost::uint32_t> ids;
@@ -106,23 +88,6 @@
return ids;
-PointBuffer Block::GetPointBuffer(SchemaLayout const& layout) const
- PointBuffer buffer(layout, m_list_p->size());
- for (boost::uint32_t i = 0; i < m_list_p->size(); ++i)
- boost::uint8_t* data = (*m_list_p)[i].m_data;
- buffer.setData(data, i);
- return buffer;
- // for (boost::uint32_t i = m_left; i <= m_right; ++i)
- // ids.push_back((*m_list_p)[i].m_ptindex);
- // return ids;
void Chipper::Chip()
Load(m_xvec, m_yvec, m_spare);
@@ -132,30 +97,21 @@
void Chipper::Load(RefList& xvec, RefList& yvec, RefList& spare )
+ PtRef ref;
boost::uint32_t idx;
vector<PtRef>::iterator it;
libpc::Header const& header = m_stage.getHeader();
libpc::Schema const& schema = header.getSchema();
- libpc::SchemaLayout const& layout = SchemaLayout(schema);
- PtRef ref;
boost::uint64_t count = header.getNumPoints();
- if (count == 0)
- if (header.getPointCountType() == libpc::PointCount_Unknown)
- throw libpc::indeterminate_count_error("The chipper requires a complete point count");
xvec.reserve(count);
yvec.reserve(count);
spare.resize(count);
+ // boost::uint32_t chunks = count/m_threshold;
- boost::scoped_ptr<Iterator> iter(m_stage.createIterator());
const int indexX = schema.getDimensionIndex(Dimension::Field_X);
const int indexY = schema.getDimensionIndex(Dimension::Field_Y);
@@ -172,6 +128,8 @@
std::size_t num_points_loaded = 0;
std::size_t num_points_to_load = count;
+ boost::scoped_ptr<Iterator> iter(m_stage.createIterator());
boost::uint32_t counter = 0;
while (num_points_loaded < num_points_to_load)
@@ -179,23 +137,15 @@
boost::uint32_t num_to_read = static_cast<boost::uint32_t>(std::min<boost::uint64_t>(num_remaining, m_threshold));
PointBuffer buffer(schema, num_to_read);
- boost::uint32_t num_read = iter->read(buffer);
- if (num_read == 0) break;
+ boost::uint32_t num_read = iter->read(buffer);
assert(num_read <= num_to_read);
- for (boost::uint32_t j = 0; j < m_threshold; j++)
+ for (boost::uint32_t j = 0; j < num_read; j++)
- if (layout.getByteSize() > 40) {
- throw libpc_error("Chipper PtRef size not large enough to hold point data");
- memcpy (ref.m_data, buffer.getData(j), layout.getByteSize());
- // PointBuffer data(buffer.getSchemaLayout(), 1);
- // data.copyPointFast(0, j, buffer);
- if (j == num_to_read) break; // we're outta here
// (v * m_header->GetScaleX()) + m_header->GetOffsetX();
const double x = (buffer.getField<boost::int32_t>(j, indexX) * xscale) + xoffset;
@@ -413,7 +363,7 @@
void Chipper::Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax )
- Block b(m_stage.getHeader().getSchema(), m_threshold);
+ Block b;
b.m_list_p = &wide;
if (wide.m_dir == DIR_X) {
diff -r 0475852dc135 -r 9798b3952688 test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp Wed Mar 23 14:27:22 2011 -0500
+++ b/test/unit/ChipperTest.cpp Wed Mar 23 16:37:10 2011 -0500
@@ -80,22 +80,22 @@
BOOST_CHECK(ids.size() == 15);
BOOST_CHECK(ids[14] == 1050 );
- PointBuffer buffer = chipper.GetBlock(20).GetPointBuffer(libpc::SchemaLayout(reader.getHeader().getSchema()));
- // Check X's of first three points in block 20
- BOOST_CHECK(buffer.getField<boost::int32_t>(0, 0) == 63567405);
- BOOST_CHECK(buffer.getField<boost::int32_t>(1, 0) == 63568054);
- BOOST_CHECK(buffer.getField<boost::int32_t>(2, 0) == 63569865);
- // Check Y's of first three points in block 20
- BOOST_CHECK(buffer.getField<boost::int32_t>(0, 1) == 84901732);
- BOOST_CHECK(buffer.getField<boost::int32_t>(1, 1) == 84936266);
- BOOST_CHECK(buffer.getField<boost::int32_t>(2, 1) == 84941588);
- // Check Z's of first three points in block 20
- BOOST_CHECK(buffer.getField<boost::int32_t>(0, 2) == 42802);
- BOOST_CHECK(buffer.getField<boost::int32_t>(1, 2) == 42156);
- BOOST_CHECK(buffer.getField<boost::int32_t>(2, 2) == 42392);
+ // PointBuffer buffer = chipper.GetBlock(20).GetPointBuffer(libpc::SchemaLayout(reader.getHeader().getSchema()));
+ // // Check X's of first three points in block 20
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(0, 0) == 63567405);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(1, 0) == 63568054);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(2, 0) == 63569865);
+ // // Check Y's of first three points in block 20
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(0, 1) == 84901732);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(1, 1) == 84936266);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(2, 1) == 84941588);
+ // // Check Z's of first three points in block 20
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(0, 2) == 42802);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(1, 2) == 42156);
+ // BOOST_CHECK(buffer.getField<boost::int32_t>(2, 2) == 42392);
More information about the Liblas-commits
