[Liblas-commits] hg-main-tree: provide pessimistic defaults for
iter creation
liblas-commits at liblas.org
Thu Mar 24 13:55:04 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/5db06e2fd8bf
changeset: 429:5db06e2fd8bf
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Mar 24 10:54:33 2011 -0700
description:
provide pessimistic defaults for iter creation
Subject: hg-main-tree: merg
details: http://hg.libpc.orghg-main-tree/rev/ea942f2e7393
changeset: 430:ea942f2e7393
date: Thu Mar 24 10:54:51 2011 -0700
description:
merg
diffstat:
include/libpc/Chipper.hpp | 21 +++-
include/libpc/ChipperIterator.hpp | 64 ++++++++++++++
include/libpc/Stage.hpp | 8 +-
src/CMakeLists.txt | 3 +
src/Chipper.cpp | 61 +++++++++++++
src/ChipperIterator.cpp | 116 +++++++++++++++++++++++++
src/drivers/oci/Writer.cpp | 173 +++++--------------------------------
7 files changed, 289 insertions(+), 157 deletions(-)
diffs (truncated from 569 to 300 lines):
diff -r 1848afbdad4d -r ea942f2e7393 include/libpc/Chipper.hpp
--- a/include/libpc/Chipper.hpp Thu Mar 24 10:38:30 2011 -0700
+++ b/include/libpc/Chipper.hpp Thu Mar 24 10:54:51 2011 -0700
@@ -2,10 +2,11 @@
#define LIBLAS_CHIPPER_H
#include <libpc/Stage.hpp>
+#include <libpc/Filter.hpp>
#include <libpc/Bounds.hpp>
#include <libpc/export.hpp>
-#include <libpc/Dimension.hpp>
#include <libpc/Iterator.hpp>
+#include <libpc/FilterIterator.hpp>
#include <boost/scoped_ptr.hpp>
@@ -88,6 +89,7 @@
std::vector<boost::uint32_t> GetIDs() const;
libpc::Bounds<double> const& GetBounds() const {return m_bounds;}
void SetBounds(libpc::Bounds<double> const& bounds) {m_bounds = bounds;}
+ PointBuffer GetBuffer( Stage& stage) const;
// double GetXmin() const
// { return m_xmin; }
// double GetYmin() const
@@ -98,12 +100,12 @@
// { return m_ymax; }
-class LIBPC_DLL Chipper
+class LIBPC_DLL Chipper : public libpc::Filter
public:
Chipper(Stage& prevStage, boost::uint32_t max_partition_size) :
- m_stage(prevStage), m_threshold(max_partition_size),
- m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
+ libpc::Filter(prevStage), m_stage(prevStage), m_threshold(max_partition_size),
+ m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
void Chip();
@@ -112,6 +114,13 @@
const Block& GetBlock(std::vector<Block>::size_type i)
{ return m_blocks[i]; }
+ const std::string& getName() const ;
+ bool supportsSequentialIterator() const { return true; }
+ bool supportsRandomIterator() const { return false; }
+ libpc::SequentialIterator* createSequentialIterator() const;
+ libpc::RandomIterator* createRandomIterator() const;
private:
void Load(RefList& xvec, RefList& yvec, RefList& spare);
void Partition(boost::uint32_t size);
@@ -124,7 +133,9 @@
boost::uint32_t pleft, boost::uint32_t pcenter);
void Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax );
+ void ConstructBuffers();
// Reader *m_reader;
Stage& m_stage;
boost::uint32_t m_threshold;
diff -r 1848afbdad4d -r ea942f2e7393 include/libpc/ChipperIterator.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/ChipperIterator.hpp Thu Mar 24 10:54:51 2011 -0700
@@ -0,0 +1,64 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_CHIPPERITERATOR_HPP
+#define INCLUDED_CHIPPERITERATOR_HPP
+namespace libpc {
+class chipper::Chipper;
+namespace filters {
+class ChipperSequentialIterator : public libpc::FilterSequentialIterator
+public:
+ ChipperSequentialIterator(const chipper::Chipper& chipper);
+private:
+ boost::uint64_t skipImpl(boost::uint64_t);
+ boost::uint32_t readImpl(PointBuffer&);
+ bool atEndImpl() const;
+ const chipper::Chipper& m_chipper;
+} } // namespaces
+#endif
diff -r 1848afbdad4d -r ea942f2e7393 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Thu Mar 24 10:38:30 2011 -0700
+++ b/include/libpc/Stage.hpp Thu Mar 24 10:54:51 2011 -0700
@@ -67,10 +67,10 @@
const Header& getHeader() const;
Header& getHeader();
- virtual bool supportsSequentialIterator() const = 0;
- virtual bool supportsRandomIterator() const = 0;
- virtual SequentialIterator* createSequentialIterator() const = 0;
- virtual RandomIterator* createRandomIterator() const = 0;
+ virtual bool supportsSequentialIterator() const { return false; }
+ virtual bool supportsRandomIterator() const { return false; }
+ virtual SequentialIterator* createSequentialIterator() const { return NULL; }
+ virtual RandomIterator* createRandomIterator() const { return NULL; }
protected:
void setHeader(Header*); // stage takes ownership
diff -r 1848afbdad4d -r ea942f2e7393 src/CMakeLists.txt
--- a/src/CMakeLists.txt Thu Mar 24 10:38:30 2011 -0700
+++ b/src/CMakeLists.txt Thu Mar 24 10:54:51 2011 -0700
@@ -39,6 +39,8 @@
${LIBPC_HEADERS_DIR}/types.hpp
${LIBPC_HEADERS_DIR}/Bounds.hpp
${LIBPC_HEADERS_DIR}/Color.hpp
+ ${LIBPC_HEADERS_DIR}/Chipper.hpp
+ ${LIBPC_HEADERS_DIR}/ChipperIterator.hpp
${LIBPC_HEADERS_DIR}/Dimension.hpp
${LIBPC_HEADERS_DIR}/DimensionLayout.hpp
${LIBPC_HEADERS_DIR}/Filter.hpp
@@ -62,6 +64,7 @@
set(LIBPC_BASE_CPP
Bounds.cpp
Chipper.cpp
+ ChipperIterator.cpp
Color.cpp
Dimension.cpp
DimensionLayout.cpp
diff -r 1848afbdad4d -r ea942f2e7393 src/Chipper.cpp
--- a/src/Chipper.cpp Thu Mar 24 10:38:30 2011 -0700
+++ b/src/Chipper.cpp Thu Mar 24 10:54:51 2011 -0700
@@ -40,6 +40,8 @@
#include <libpc/chipper.hpp>
#include <libpc/Utils.hpp>
+#include <libpc/ChipperIterator.hpp>
+#include <libpc/exceptions.hpp>
// boost
#include <boost/cstdint.hpp>
// std
@@ -88,6 +90,46 @@
return ids;
+PointBuffer Block::GetBuffer( Stage& stage) const
+ libpc::Header const& header = stage.getHeader();
+ libpc::Schema const& schema = header.getSchema();
+ boost::int32_t size = m_right - m_left + 1;
+ if (size < 0)
+ throw libpc_error("m_right - m_left + 1 was less than 0 in Block::GetBuffer()!");
+ PointBuffer buffer(schema, size);
+ if (!stage.supportsRandomIterator())
+ throw libpc_error("Chipper GetBuffer is unable to read data source randomly!");
+ boost::scoped_ptr<RandomIterator> iter(stage.createRandomIterator());
+ std::vector<boost::uint32_t> ids = GetIDs();
+ libpc::PointBuffer one_point(schema, 1);
+ std::vector<boost::uint32_t>::const_iterator it;
+ boost::uint32_t count = 0;
+ for (it = ids.begin(); it != ids.end(); it++)
+ iter->seek(*it);
+ iter->read(one_point);
+ // m_stage.seekToPoint(*it);
+ // FIXME: Use a user bounds here instead of reading everything
+ // m_stage.read(buffer);
+ buffer.copyPointsFast(static_cast<std::size_t>(count), static_cast<std::size_t>(0), one_point, 1);
+ // // put single point onto our block
+ count++;
+ return buffer;
void Chipper::Chip()
Load(m_xvec, m_yvec, m_spare);
@@ -95,6 +137,25 @@
DecideSplit(m_xvec, m_yvec, m_spare, 0, m_partitions.size() - 1);
+const std::string& Chipper::getName() const
+ static std::string name("Chipper");
+ return name;
+libpc::SequentialIterator* Chipper::createSequentialIterator() const
+ return new filters::ChipperSequentialIterator(*this);
+libpc::RandomIterator* Chipper::createRandomIterator() const
+ return 0;
void Chipper::Load(RefList& xvec, RefList& yvec, RefList& spare )
PtRef ref;
diff -r 1848afbdad4d -r ea942f2e7393 src/ChipperIterator.cpp
+++ b/src/ChipperIterator.cpp Thu Mar 24 10:54:51 2011 -0700
@@ -0,0 +1,116 @@
+* OF SUCH DAMAGE.
+#include <libpc/Chipper.hpp>
+namespace libpc { namespace filters {
More information about the Liblas-commits
