[Liblas-commits] hg-main-tree: use BOOST_CHECK_EQUAL and
BOOST_CHECK_CLOSE and fr...
liblas-commits at liblas.org
Fri Mar 25 10:55:38 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/8ba6c2f564e0
changeset: 444:8ba6c2f564e0
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Mar 25 09:55:29 2011 -0500
description:
use BOOST_CHECK_EQUAL and BOOST_CHECK_CLOSE and friends from http://www.boost.org/doc/libs/1_46_0/libs/test/doc/html/utf/testing-tools/reference.html so we get better output instead of merely using BOOST_CHECK
diffstat:
test/unit/FauxReaderTest.cpp | 118 ++++++++++++++++++++++++------------------
1 files changed, 66 insertions(+), 52 deletions(-)
diffs (248 lines):
diff -r a2666b518cdb -r 8ba6c2f564e0 test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp Fri Mar 25 08:07:44 2011 -0500
+++ b/test/unit/FauxReaderTest.cpp Fri Mar 25 09:55:29 2011 -0500
@@ -50,7 +50,7 @@
Bounds<double> bounds(1.0, 2.0, 3.0, 101.0, 102.0, 103.0);
libpc::drivers::faux::Reader reader(bounds, 1000, libpc::drivers::faux::Reader::Constant);
- BOOST_CHECK(reader.getName() == "Faux Reader");
+ BOOST_CHECK_EQUAL(reader.getName(), "Faux Reader");
const Schema& schema = reader.getHeader().getSchema();
SchemaLayout layout(schema);
@@ -60,7 +60,7 @@
SequentialIterator* iter = reader.createSequentialIterator();
boost::uint32_t numRead = iter->read(data);
- BOOST_CHECK(numRead == 750);
+ BOOST_CHECK_EQUAL(numRead, 750);
int offsetX = schema.getDimensionIndex(Dimension::Field_X);
int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
@@ -74,10 +74,10 @@
double z = data.getField<double>(i, offsetZ);
boost::uint64_t t = data.getField<boost::uint64_t>(i, offsetT);
- BOOST_CHECK(Utils::compare_approx<double>(x, 1.0, (std::numeric_limits<double>::min)()) == true);
- BOOST_CHECK(Utils::compare_approx<double>(y, 2.0, (std::numeric_limits<double>::min)()) == true);
- BOOST_CHECK(Utils::compare_approx<double>(z, 3.0, (std::numeric_limits<double>::min)()) == true);
- BOOST_CHECK(t==i);
+ BOOST_CHECK_CLOSE(x, 2.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(y, 2.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(z, 3.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_EQUAL(t, i);
delete iter;
@@ -91,7 +91,7 @@
@@ -106,7 +106,7 @@
RandomIterator* iter = reader.createRandomIterator();
- BOOST_CHECK(numRead == 10);
+ BOOST_CHECK_EQUAL(numRead, 10);
for (boost::uint32_t i=0; i<numRead; i++)
@@ -116,15 +116,15 @@
+ BOOST_CHECK_CLOSE(x, 1.0, (std::numeric_limits<double>::min)());
@@ -134,17 +134,17 @@
- BOOST_CHECK(t==i+10);
+ BOOST_CHECK_EQUAL(t, i+10);
boost::uint64_t newPos = iter->seek(99);
- BOOST_CHECK(newPos == 99);
+ BOOST_CHECK_EQUAL(newPos, 99);
@@ -154,17 +154,18 @@
- BOOST_CHECK(t==i+99);
+ BOOST_CHECK_EQUAL(t, i+99);
newPos = iter->seek(7);
- BOOST_CHECK(newPos == 7);
+ BOOST_CHECK_EQUAL(newPos, 7);
@@ -174,10 +175,11 @@
- BOOST_CHECK(t==i+7);
+ BOOST_CHECK_EQUAL(t, i+7);
@@ -200,7 +202,7 @@
@@ -213,11 +215,21 @@
double y = data.getField<double>(i, offsetY);
- BOOST_CHECK(x >= 1.0 && x <= 101.0);
- BOOST_CHECK(y >= 2.0 && y <= 102.0);
- BOOST_CHECK(z >= 3.0 && z <= 103.0);
- BOOST_CHECK(t == i);
+ BOOST_CHECK_GE(x, 1.0);
+ BOOST_CHECK_LE(x, 101.0);
+ BOOST_CHECK_GE(y, 2.0);
+ BOOST_CHECK_LE(y, 102.0);
+ BOOST_CHECK_GE(z, 3.0);
+ BOOST_CHECK_LE(z, 103.0);
+ // BOOST_CHECK(x >= 1.0 && x <= 101.0);
+ // BOOST_CHECK(y >= 2.0 && y <= 102.0);
+ // BOOST_CHECK(z >= 3.0 && z <= 103.0);
+ // BOOST_CHECK(t == i);
delete iter;
@@ -238,7 +250,7 @@
- BOOST_CHECK(numRead == 2);
+ BOOST_CHECK_EQUAL(numRead, 2);
const int offsetX = schema.getDimensionIndex(Dimension::Field_X);
const int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
@@ -255,15 +267,16 @@
const double z1 = data.getField<double>(1, offsetZ);
const boost::uint64_t t1 = data.getField<boost::uint64_t>(1, offsetT);
- BOOST_CHECK(Utils::compare_approx<double>(x0, 0, 0.000001));
- BOOST_CHECK(Utils::compare_approx<double>(y0, 0, 0.000001));
- BOOST_CHECK(Utils::compare_approx<double>(z0, 0, 0.000001));
- BOOST_CHECK(t0 == 0);
+ BOOST_CHECK_CLOSE(x0, 0.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(y0, 0.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(z0, 0.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_EQUAL(t0, 0);
- BOOST_CHECK(Utils::compare_approx<double>(x1, 4, 0.000001));
- BOOST_CHECK(Utils::compare_approx<double>(y1, 4, 0.000001));
- BOOST_CHECK(Utils::compare_approx<double>(z1, 4, 0.000001));
- BOOST_CHECK(t1 == 1);
+ BOOST_CHECK_CLOSE(x1, 4.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(y1, 4.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(z1, 4.0, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_EQUAL(t1, 1);
delete iter;
@@ -284,7 +297,7 @@
+ BOOST_CHECK_EQUAL(numRead,750);
@@ -302,10 +315,11 @@
- BOOST_CHECK(Utils::compare_approx<double>(x, 1.0 + delX*i, 0.0001));
- BOOST_CHECK(Utils::compare_approx<double>(y, 2.0 + delY*i, 0.0001));
- BOOST_CHECK(Utils::compare_approx<double>(z, 3.0 + delZ*i, 0.0001));
+ BOOST_CHECK_CLOSE(x, 1.0 + delX*i, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(y, 2.0 + delY*i, (std::numeric_limits<double>::min)());
+ BOOST_CHECK_CLOSE(z, 3.0 + delZ*i, (std::numeric_limits<double>::min)());
delete iter;
@@ -327,9 +341,9 @@
libpc::drivers::faux::Reader reader(bounds, 1000, libpc::drivers::faux::Reader::Random, dims);
- BOOST_CHECK(schema.getDimensions().size() == 2);
- BOOST_CHECK(schema.getDimension(0).getField() == Dimension::Field_Y);
- BOOST_CHECK(schema.getDimension(1).getField() == Dimension::Field_X);
+ BOOST_CHECK_EQUAL(schema.getDimensions().size(), 2);
+ BOOST_CHECK_EQUAL(schema.getDimension(0).getField(), Dimension::Field_Y);
+ BOOST_CHECK_EQUAL(schema.getDimension(1).getField(), Dimension::Field_X);
return;
More information about the Liblas-commits
