[Liblas-commits] hg-main-tree: move chipper down into filters
namespace
liblas-commits at liblas.org
Fri Mar 25 14:59:50 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/74b6643fd5f1
changeset: 466:74b6643fd5f1
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Mar 25 13:36:06 2011 -0500
description:
move chipper down into filters namespace
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/d89cb904fccb
changeset: 467:d89cb904fccb
date: Fri Mar 25 13:36:15 2011 -0500
description:
merge
Subject: hg-main-tree: move chipper down into filters and namespace appropriately
details: http://hg.libpc.orghg-main-tree/rev/5f62edc05de5
changeset: 468:5f62edc05de5
date: Fri Mar 25 13:58:59 2011 -0500
description:
diffstat:
apps/pc2pc.cpp | 12 +-
include/libpc/Chipper.hpp | 204 -------------
include/libpc/ChipperIterator.hpp | 68 ----
include/libpc/FilterIterator.hpp | 19 +
include/libpc/Iterator.hpp | 3 +
include/libpc/drivers/oci/Writer.hpp | 8 +-
include/libpc/filters/Chipper.hpp | 209 +++++++++++++
include/libpc/filters/ChipperIterator.hpp | 66 ++++
src/CMakeLists.txt | 8 +-
src/Chipper.cpp | 454 -----------------------------
src/ChipperIterator.cpp | 115 -------
src/drivers/las/LasHeaderWriter.hpp | 2 +-
src/drivers/liblas/Iterator.cpp | 34 +-
src/drivers/oci/Writer.cpp | 8 +-
src/filters/Chipper.cpp | 455 ++++++++++++++++++++++++++++++
src/filters/ChipperIterator.cpp | 114 +++++++
test/unit/ChipperTest.cpp | 4 +-
test/unit/LiblasWriterTest.cpp | 8 +-
18 files changed, 913 insertions(+), 878 deletions(-)
diffs (truncated from 2020 to 300 lines):
diff -r b86cf9014e60 -r 5f62edc05de5 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Fri Mar 25 11:10:15 2011 -0700
+++ b/apps/pc2pc.cpp Fri Mar 25 13:58:59 2011 -0500
@@ -116,9 +116,7 @@
//writer.setPointFormat( reader.getPointFormatNumber() );
- size_t np = (size_t)numPoints;
- assert(numPoints == np); // BUG
- writer.write(np);
+ writer.write(numPoints);
else if (hasOption("oracle"))
@@ -145,9 +143,7 @@
- writer.write(np);
#else
throw configuration_error("libPC not compiled with Oracle support");
#endif
@@ -164,9 +160,7 @@
- writer.write(np);
Utils::closeFile(ofs);
diff -r b86cf9014e60 -r 5f62edc05de5 include/libpc/Chipper.hpp
--- a/include/libpc/Chipper.hpp Fri Mar 25 11:10:15 2011 -0700
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,204 +0,0 @@
- * $Id$
- * Project: libPC - http://libpc.org - A BSD library for point cloud data.
- * Purpose: libPC chipper class
- * Author: Howard Butler, hobu.inc at gmail.com
- * Copyright (c) 2011, Howard Butler
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following
- * conditions are met:
- * * Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided
- * with the distribution.
- * * Neither the name of the Martin Isenburg or Iowa Department
- * of Natural Resources nor the names of its contributors may be
- * used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
- * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
- * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
- * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
- * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
- * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
- * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
- * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
- * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
- * OF SUCH DAMAGE.
-#ifndef LIBPC_CHIPPER_H
-#define LIBPC_CHIPPER_H
-#include <libpc/libpc.hpp>
-#include <vector>
-#include <libpc/Filter.hpp>
-#include <libpc/Bounds.hpp>
-#include <libpc/PointBuffer.hpp>
-namespace libpc
-class Stage;
-namespace chipper
-enum Direction
- DIR_X,
- DIR_Y,
- DIR_NONE
-class LIBPC_DLL PtRef
-public:
- double m_pos;
- boost::uint32_t m_ptindex;
- boost::uint32_t m_oindex;
- bool operator < (const PtRef& pt) const
- { return m_pos < pt.m_pos; }
-struct LIBPC_DLL RefList
-public:
- std::vector<PtRef> m_vec;
- Direction m_dir;
- RefList(Direction dir = DIR_NONE) : m_dir(dir)
- std::vector<PtRef>::size_type size() const
- { return m_vec.size(); }
- void reserve(std::vector<PtRef>::size_type n)
- { m_vec.reserve(n); }
- void resize(std::vector<PtRef>::size_type n)
- { m_vec.resize(n); }
- void push_back(const PtRef& ref)
- { m_vec.push_back(ref); }
- std::vector<PtRef>::iterator begin()
- { return m_vec.begin(); }
- std::vector<PtRef>::iterator end()
- { return m_vec.end(); }
- PtRef& operator[](boost::uint32_t pos)
- { return m_vec[pos]; }
- std::string Dir()
- if (m_dir == DIR_X)
- return "X";
- else if (m_dir == DIR_Y)
- return "Y";
- else
- return "NONE";
-class LIBPC_DLL Chipper;
-class LIBPC_DLL Block
- friend class Chipper;
-private:
- RefList *m_list_p;
- boost::uint32_t m_left;
- boost::uint32_t m_right;
- libpc::Bounds<double> m_bounds;
- // double m_xmin;
- // double m_ymin;
- // double m_xmax;
- // double m_ymax;
-public:
- std::vector<boost::uint32_t> GetIDs() const;
- libpc::Bounds<double> const& GetBounds() const {return m_bounds;}
- void SetBounds(libpc::Bounds<double> const& bounds) {m_bounds = bounds;}
- PointBuffer GetBuffer( Stage& stage) const;
- // double GetXmin() const
- // { return m_xmin; }
- // double GetYmin() const
- // { return m_ymin; }
- // double GetXmax() const
- // { return m_xmax; }
- // double GetYmax() const
- // { return m_ymax; }
-class LIBPC_DLL Chipper : public libpc::Filter
-public:
- Chipper(Stage& prevStage, boost::uint32_t max_partition_size) :
- libpc::Filter(prevStage), m_stage(prevStage), m_threshold(max_partition_size),
- m_xvec(DIR_X), m_yvec(DIR_Y), m_spare(DIR_NONE)
- void Chip();
- std::vector<Block>::size_type GetBlockCount()
- { return m_blocks.size(); }
- const Block& GetBlock(std::vector<Block>::size_type i)
- { return m_blocks[i]; }
- const std::string& getName() const ;
- inline boost::uint8_t getIteratorSupport () const
- // FIXME: make this represent what this reader actually supports!
- boost::uint8_t mask(0);
- mask |= StageIterator_Block;
- return mask;
- bool supportsSequentialIterator() const { return true; }
- bool supportsRandomIterator() const { return false; }
- libpc::SequentialIterator* createSequentialIterator() const;
- libpc::RandomIterator* createRandomIterator() const;
-private:
- void Load(RefList& xvec, RefList& yvec, RefList& spare);
- void Partition(boost::uint32_t size);
- void Split(RefList& xvec, RefList& yvec, RefList& spare);
- void DecideSplit(RefList& v1, RefList& v2, RefList& spare,
- boost::uint32_t left, boost::uint32_t right);
- void Split(RefList& wide, RefList& narrow, RefList& spare,
- void FinalSplit(RefList& wide, RefList& narrow,
- boost::uint32_t pleft, boost::uint32_t pcenter);
- void Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
- RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax );
- void ConstructBuffers();
- // Reader *m_reader;
- Stage& m_stage;
- boost::uint32_t m_threshold;
- std::vector<Block> m_blocks;
- std::vector<boost::uint32_t> m_partitions;
- RefList m_xvec;
- RefList m_yvec;
- RefList m_spare;
- Chipper& operator=(const Chipper&); // not implemented
- Chipper(const Chipper&); // not implemented
-} // namespace chipper
-} // namespace liblas
-#endif
diff -r b86cf9014e60 -r 5f62edc05de5 include/libpc/ChipperIterator.hpp
--- a/include/libpc/ChipperIterator.hpp Fri Mar 25 11:10:15 2011 -0700
@@ -1,68 +0,0 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
-* All rights reserved.
-* Redistribution and use in source and binary forms, with or without
-* modification, are permitted provided that the following
-* conditions are met:
-* * Redistributions of source code must retain the above copyright
-* notice, this list of conditions and the following disclaimer.
-* * Redistributions in binary form must reproduce the above copyright
-* notice, this list of conditions and the following disclaimer in
-* the documentation and/or other materials provided
-* with the distribution.
-* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
-* names of its contributors may be used to endorse or promote
-* products derived from this software without specific prior
-* written permission.
-* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
-* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
-* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
-* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_CHIPPERITERATOR_HPP
-#define INCLUDED_CHIPPERITERATOR_HPP
-#include <libpc/FilterIterator.hpp>
-namespace libpc {
-namespace chipper
- class Chipper;
-namespace filters {
-class ChipperSequentialIterator : public libpc::FilterSequentialIterator
More information about the Liblas-commits
