[Liblas-commits] hg-main-tree: make build (but not yet run
correctly) with laszip...
liblas-commits at liblas.org
Wed May 11 15:20:33 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/94d95d2a8197
changeset: 711:94d95d2a8197
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed May 11 12:19:54 2011 -0700
description:
make build (but not yet run correctly) with laszip/liblas changes
diffstat:
include/libpc/drivers/las/Writer.hpp | 2 +
src/drivers/las/LasHeaderWriter.cpp | 4 +-
src/drivers/las/Writer.cpp | 108 +++++++++++++++++------
src/drivers/las/ZipPoint.cpp | 160 +++++++++++++++++-----------------
src/drivers/las/ZipPoint.hpp | 11 +-
5 files changed, 173 insertions(+), 112 deletions(-)
diffs (truncated from 420 to 300 lines):
diff -r 9f91166cbf42 -r 94d95d2a8197 include/libpc/drivers/las/Writer.hpp
--- a/include/libpc/drivers/las/Writer.hpp Wed May 11 12:05:38 2011 -0500
+++ b/include/libpc/drivers/las/Writer.hpp Wed May 11 12:19:54 2011 -0700
@@ -42,6 +42,7 @@
#include <libpc/drivers/las/SummaryData.hpp>
// liblaszip
+class LASzip;
class LASzipper;
namespace libpc { namespace drivers { namespace las {
@@ -90,6 +91,7 @@
boost::uint32_t m_numPointsWritten;
bool m_isCompressed;
SummaryData m_summaryData;
+ LASzip* m_zip;
LASzipper* m_zipper;
ZipPoint* m_zipPoint;
SpatialReference m_spatialReference;
diff -r 9f91166cbf42 -r 94d95d2a8197 src/drivers/las/LasHeaderWriter.cpp
--- a/src/drivers/las/LasHeaderWriter.cpp Wed May 11 12:05:38 2011 -0500
+++ b/src/drivers/las/LasHeaderWriter.cpp Wed May 11 12:19:54 2011 -0700
@@ -116,8 +116,8 @@
if (m_header.Compressed())
#ifdef LIBPC_HAVE_LASZIP
- ZipPoint zpd(m_header.getPointFormat());
- VariableLengthRecord v = zpd.ConstructVLR();
+ ZipPoint zpd(m_header.getPointFormat(), m_header.getVLRs().getAll());
+ VariableLengthRecord v = zpd.ConstructVLR(m_header.getPointFormat());
m_header.getVLRs().add(v);
#else
throw configuration_error("LASzip compression support not enabled in this libLAS configuration.");
diff -r 9f91166cbf42 -r 94d95d2a8197 src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp Wed May 11 12:05:38 2011 -0500
+++ b/src/drivers/las/Writer.cpp Wed May 11 12:19:54 2011 -0700
@@ -57,6 +57,7 @@
, m_ostream(ostream)
, m_numPointsWritten(0)
, m_isCompressed(false)
+ , m_zip(NULL)
, m_zipper(NULL)
, m_zipPoint(NULL)
@@ -70,6 +71,7 @@
delete m_zipper;
delete m_zipPoint;
+ delete m_zip;
@@ -174,40 +176,86 @@
m_zipper = NULL;
m_zipPoint = NULL;
- try
+ if (m_zip==NULL)
- m_zipper = new LASzipper();
- catch(...)
- delete m_zipper;
- m_zipper = NULL;
- throw libpc_error("Error opening compression engine (1)");
+ try
+ m_zip = new LASzip();
+ catch(...)
+ throw libpc_error("Error opening compression core (1)");
+ PointFormat format = m_lasHeader.getPointFormat();
+ delete m_zipPoint;
+ m_zipPoint = new ZipPoint(format, m_lasHeader.getVLRs().getAll());
+ bool ok = false;
+ try
+ ok = m_zip->setup((unsigned char)format, m_lasHeader.GetDataRecordLength());
+ catch(...)
+ throw libpc_error("Error opening compression core (3)");
+ if (!ok)
+ throw libpc_error("Error opening compression core (2)");
+ try
+ ok = m_zip->pack(m_zipPoint->his_vlr_data, m_zipPoint->his_vlr_num);
+ catch(...)
+ if (!ok)
- PointFormat format = m_lasHeader.getPointFormat();
- m_zipPoint = new ZipPoint(format);
+ if (m_zipper == NULL)
+ try
+ m_zipper = new LASzipper();
+ catch(...)
+ delete m_zipper;
+ m_zipper = NULL;
+ throw libpc_error("Error opening compression engine (1)");
- unsigned int stat = 1;
- try
- stat = m_zipper->open(m_ostream, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::DEFAULT_COMPRESSION);
- catch(...)
- delete m_zipper;
- delete m_zipPoint;
- m_zipper = NULL;
- m_zipPoint = NULL;
- throw libpc_error("Error opening compression engine (3)");
- if (stat != 0)
- delete m_zipper;
- m_zipper = NULL;
- throw libpc_error("Error opening compression engine (2)");
+ unsigned int stat = 1;
+ try
+ stat = m_zipper->open(m_ostream, m_zip);
+ catch(...)
+ delete m_zipper;
+ m_zipper = NULL;
+ m_zipPoint = NULL;
+ throw libpc_error("Error opening compression engine (3)");
+ if (stat != 0)
+ delete m_zipper;
+ m_zipper = NULL;
+ throw libpc_error("Error opening compression engine (2)");
diff -r 9f91166cbf42 -r 94d95d2a8197 src/drivers/las/ZipPoint.cpp
--- a/src/drivers/las/ZipPoint.cpp Wed May 11 12:05:38 2011 -0500
+++ b/src/drivers/las/ZipPoint.cpp Wed May 11 12:19:54 2011 -0700
@@ -38,6 +38,9 @@
#include "ZipPoint.hpp"
+#include <laszip/laszip.hpp>
+#include <laszip/laszipper.hpp>
#include <libpc/exceptions.hpp>
#include <libpc/drivers/las/VariableLengthRecord.hpp>
#include <string.h>
@@ -60,14 +63,39 @@
static const char* laszip_description = "encoded for sequential access";
-ZipPoint::ZipPoint(PointFormat format) :
- m_num_items(0),
- m_items(NULL),
- m_lz_point(NULL),
- m_lz_point_data(NULL),
- m_lz_point_size(0)
+ZipPoint::ZipPoint(PointFormat format, const std::vector<VariableLengthRecord>& vlrs)
+ : his_vlr_num(0)
+ , his_vlr_data(0)
+ , our_vlr_num(0)
+ , our_vlr_data(0)
+ , m_num_items(0)
+ , m_items(NULL)
+ , m_lz_point(NULL)
+ , m_lz_point_data(NULL)
+ , m_lz_point_size(0)
ConstructItems(format);
+ const VariableLengthRecord* vlr = NULL;
+ for (unsigned int i=0; i<vlrs.size(); i++)
+ const VariableLengthRecord& p = vlrs[i];
+ if (p.getRecordId() == 22204)
+ vlr = &p;
+ break;
+ if (vlr)
+ our_vlr_num = vlr->getLength();
+ our_vlr_data = new unsigned char[our_vlr_num];
+ for (int i=0; i<our_vlr_num; i++)
+ our_vlr_data[i] = vlr->getBytes()[i];
return;
@@ -80,6 +108,8 @@
delete[] m_lz_point;
delete[] m_lz_point_data;
+ delete[] our_vlr_data;
return;
@@ -90,37 +120,37 @@
case PointFormat0:
m_num_items = 1;
m_items = new LASitem[1];
- m_items[0].set(LASitem::POINT10);
+ m_items[0].type = LASitem::POINT10;
+ m_items[0].size = 20;
break;
case PointFormat1:
m_num_items = 2;
m_items = new LASitem[2];
- m_items[1].set(LASitem::GPSTIME11);
+ m_items[0].size = 8;
+ m_items[1].type = LASitem::GPSTIME11;
+ m_items[1].size = 8;
break;
case PointFormat2:
m_num_items = 2;
- m_items[1].set(LASitem::RGB12);
+ m_items[1].type = LASitem::RGB12;
+ m_items[1].size = 6;
break;
case PointFormat3:
m_num_items = 3;
m_items = new LASitem[3];
- m_items[2].set(LASitem::RGB12);
- break;
- case PointFormat4:
- m_num_items = 3;
- m_items = new LASitem[3];
- m_items[2].set(LASitem::WAVEPACKET13);
+ m_items[2].type = LASitem::RGB12;
+ m_items[2].size = 6;
break;
default:
@@ -148,68 +178,42 @@
-VariableLengthRecord ZipPoint::ConstructVLR() const
+VariableLengthRecord ZipPoint::ConstructVLR(PointFormat format) const
- boost::uint16_t record_length_after_header = (boost::uint16_t)(34+6*m_num_items);
More information about the Liblas-commits
