[Liblas-commits] laszip: new test for variable chunking
liblas-commits at liblas.org
Mon May 16 10:58:57 EDT 2011
details: http://hg.liblas.orglaszip/rev/941aca17929a
changeset: 236:941aca17929a
user: isenburg
date: Mon May 16 08:00:05 2011 -0700
description:
Subject: laszip: compressed chunking information and better GPS time compression
details: http://hg.liblas.orglaszip/rev/846198906775
changeset: 237:846198906775
user: isenburg
date: Mon May 16 08:01:23 2011 -0700
description:
diffstat:
src/lasreaditemcompressed_v2.cpp | 90 +++-
src/lasreaditemcompressed_v2.hpp | 7 +-
src/lasreadpoint.cpp | 30 +-
src/laswriteitemcompressed_v2.cpp | 124 ++++--
src/laswriteitemcompressed_v2.hpp | 7 +-
src/laswritepoint.cpp | 22 +-
tools/laszippertest.cpp | 673 +++++++++++++++++++++++--------------
7 files changed, 593 insertions(+), 360 deletions(-)
diffs (truncated from 1344 to 300 lines):
diff -r 484b68b9d852 -r 846198906775 src/lasreaditemcompressed_v2.cpp
--- a/src/lasreaditemcompressed_v2.cpp Wed May 11 16:38:59 2011 -0700
+++ b/src/lasreaditemcompressed_v2.cpp Mon May 16 08:01:23 2011 -0700
@@ -240,7 +240,7 @@
-#define LASZIP_GPSTIME_MULTI 512
+#define LASZIP_GPSTIME_MULTI 500
#define LASZIP_GPSTIME_MULTI_1024 (LASZIP_GPSTIME_MULTI + 0)
#define LASZIP_GPSTIME_MULTI_2048 (LASZIP_GPSTIME_MULTI + 1)
#define LASZIP_GPSTIME_MULTI_4096 (LASZIP_GPSTIME_MULTI + 2)
@@ -248,11 +248,10 @@
#define LASZIP_GPSTIME_MULTI_MINUS_5500 (LASZIP_GPSTIME_MULTI + 4)
#define LASZIP_GPSTIME_MULTI_MINUS_550 (LASZIP_GPSTIME_MULTI + 5)
#define LASZIP_GPSTIME_MULTI_MINUS_55 (LASZIP_GPSTIME_MULTI + 6)
-#define LASZIP_GPSTIME_MULTI_MINUS_5 (LASZIP_GPSTIME_MULTI + 7)
-#define LASZIP_GPSTIME_MULTI_UNCHANGED (LASZIP_GPSTIME_MULTI + 8)
-#define LASZIP_GPSTIME_MULTI_DOUBLE (LASZIP_GPSTIME_MULTI + 9)
+#define LASZIP_GPSTIME_MULTI_UNCHANGED (LASZIP_GPSTIME_MULTI + 17)
+#define LASZIP_GPSTIME_MULTI_DOUBLE (LASZIP_GPSTIME_MULTI + 18)
-#define LASZIP_GPSTIME_MULTI_TOTAL (LASZIP_GPSTIME_MULTI + 10)
+#define LASZIP_GPSTIME_MULTI_TOTAL (LASZIP_GPSTIME_MULTI + 22)
LASreadItemCompressed_GPSTIME11_v2::LASreadItemCompressed_GPSTIME11_v2(EntropyDecoder* dec)
@@ -261,7 +260,7 @@
this->dec = dec;
/* create entropy models and integer compressors */
m_gpstime_multi = dec->createSymbolModel(LASZIP_GPSTIME_MULTI_TOTAL);
- m_gpstime_0diff = dec->createSymbolModel(3);
+ m_gpstime_0diff = dec->createSymbolModel(6);
ic_gpstime = new IntegerCompressor(dec, 32, 7); // 32 bits, 7 contexts
@@ -275,8 +274,15 @@
BOOL LASreadItemCompressed_GPSTIME11_v2::init(const U8* item)
/* init state */
- last_gpstime_diff = 0;
- multi_extreme_counter = 0;
+ last = 0, next = 0;
+ last_gpstime_diff[0] = 0;
+ last_gpstime_diff[1] = 0;
+ last_gpstime_diff[2] = 0;
+ last_gpstime_diff[3] = 0;
+ multi_extreme_counter[0] = 0;
+ multi_extreme_counter[1] = 0;
+ multi_extreme_counter[2] = 0;
+ multi_extreme_counter[3] = 0;
/* init models and integer compressors */
dec->initSymbolModel(m_gpstime_multi);
@@ -284,24 +290,37 @@
ic_gpstime->initDecompressor();
/* init last item */
- last_gpstime.u64 = *((U64*)item);
+ last_gpstime[0].u64 = *((U64*)item);
+ last_gpstime[1].u64 = 0;
+ last_gpstime[2].u64 = 0;
+ last_gpstime[3].u64 = 0;
return TRUE;
inline BOOL LASreadItemCompressed_GPSTIME11_v2::read(U8* item)
I32 multi;
- if (last_gpstime_diff == 0) // if the last integer difference was zero
+ if (last_gpstime_diff[last] == 0) // if the last integer difference was zero
multi = dec->decodeSymbol(m_gpstime_0diff);
if (multi == 1) // the difference can be represented with 32 bits
- last_gpstime_diff = ic_gpstime->decompress(0, 0);
- last_gpstime.i64 += last_gpstime_diff;
+ last_gpstime_diff[last] = ic_gpstime->decompress(0, 0);
+ last_gpstime[last].i64 += last_gpstime_diff[last];
+ multi_extreme_counter[last] = 0;
else if (multi == 2) // the difference is huge
- last_gpstime.u64 = dec->readInt64();
+ next = (next+1)&3;
+ last = next;
+ last_gpstime_diff[last] = 0;
+ last_gpstime[last].u64 = dec->readInt64();
+ else if (multi > 2) // we switch to another sequence
+ last = (last+multi-2)&3;
+ return read(item);
else
@@ -309,8 +328,8 @@
multi = dec->decodeSymbol(m_gpstime_multi);
if (multi == 1)
- last_gpstime.i64 += ic_gpstime->decompress(last_gpstime_diff, 1);;
+ last_gpstime[last].i64 += ic_gpstime->decompress(last_gpstime_diff[last], 1);;
else if (multi < LASZIP_GPSTIME_MULTI_UNCHANGED)
@@ -318,19 +337,19 @@
if (multi == 0)
gpstime_diff = ic_gpstime->decompress(0, 6);
- multi_extreme_counter++;
- if (multi_extreme_counter > 3)
+ multi_extreme_counter[last]++;
+ if (multi_extreme_counter[last] > 3)
- last_gpstime_diff = gpstime_diff;
+ last_gpstime_diff[last] = gpstime_diff;
else if (multi < LASZIP_GPSTIME_MULTI)
if (multi < 10)
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 2);
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff[last], 2);
else
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 3);
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff[last], 3);
else if (multi < LASZIP_GPSTIME_MULTI_MINUS_11000)
@@ -340,12 +359,12 @@
multi = 2048;
else
multi = 4096;
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 4);
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff[last], 4);
else
@@ -359,17 +378,26 @@
else if (multi == LASZIP_GPSTIME_MULTI_MINUS_55)
multi = -55;
else
- multi = -5;
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 5);
+ multi = LASZIP_GPSTIME_MULTI_MINUS_55-multi;
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff[last], 5);
- last_gpstime.i64 += gpstime_diff;
+ last_gpstime[last].i64 += gpstime_diff;
else if (multi == LASZIP_GPSTIME_MULTI_DOUBLE)
+ last = next;
+ else if (multi >= LASZIP_GPSTIME_MULTI_DOUBLE)
+ last = (last+multi-LASZIP_GPSTIME_MULTI_DOUBLE)&3;
- *((I64*)item) = last_gpstime.i64;
+ *((I64*)item) = last_gpstime[last].i64;
return TRUE;
diff -r 484b68b9d852 -r 846198906775 src/lasreaditemcompressed_v2.hpp
--- a/src/lasreaditemcompressed_v2.hpp Wed May 11 16:38:59 2011 -0700
+++ b/src/lasreaditemcompressed_v2.hpp Mon May 16 08:01:23 2011 -0700
@@ -81,13 +81,14 @@
private:
EntropyDecoder* dec;
- U64I64F64 last_gpstime;
+ U32 last, next;
+ U64I64F64 last_gpstime[4];
+ I32 last_gpstime_diff[4];
+ I32 multi_extreme_counter[4];
EntropyModel* m_gpstime_multi;
EntropyModel* m_gpstime_0diff;
IntegerCompressor* ic_gpstime;
- I32 multi_extreme_counter;
- I32 last_gpstime_diff;
class LASreadItemCompressed_RGB12_v2 : public LASreadItemCompressed
diff -r 484b68b9d852 -r 846198906775 src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp Wed May 11 16:38:59 2011 -0700
+++ b/src/lasreadpoint.cpp Mon May 16 08:01:23 2011 -0700
@@ -210,7 +210,7 @@
if (!instream) return FALSE;
this->instream = instream;
- // if chunking is enabled
+ // on very first init with chunking enabled
if (number_chunks == U32_MAX)
if (!read_chunk_table())
@@ -218,6 +218,7 @@
return FALSE;
current_chunk = 0;
+ if (chunk_totals) chunk_size = chunk_totals[1];
point_start = instream->position();
@@ -374,6 +375,11 @@
return false;
+ U32 version;
+ if (!instream->get32bitsLE((U8*)&version) || version != 0)
+ return FALSE;
if (!instream->get32bitsLE((U8*)&number_chunks))
return FALSE;
@@ -391,20 +397,18 @@
if (chunk_size == U32_MAX) chunk_totals[0] = 0;
chunk_starts[0] = chunks_start;
U32 i;
+ dec->init(instream);
+ IntegerCompressor ic(dec, 32, 2);
+ ic.initDecompressor();
for (i = 1; i <= number_chunks; i++)
- if (chunk_size == U32_MAX)
- if (!instream->get32bitsLE((U8*)&chunk_totals[i]))
- return FALSE;
- chunk_totals[i] += chunk_totals[i-1];
- if (!instream->get32bitsLE((U8*)&chunk_starts[i]))
- return FALSE;
+ if (chunk_size == U32_MAX) chunk_totals[i] = ic.decompress((i>1 ? chunk_totals[i-1] : 0), 0);
+ chunk_starts[i] = ic.decompress((i>1 ? chunk_starts[i-1] : 0), 1);
+ dec->done();
+ for (i = 1; i <= number_chunks; i++)
+ if (chunk_size == U32_MAX) chunk_totals[i] += chunk_totals[i-1];
chunk_starts[i] += chunk_starts[i-1];
instream->seek(chunks_start);
diff -r 484b68b9d852 -r 846198906775 src/laswriteitemcompressed_v2.cpp
--- a/src/laswriteitemcompressed_v2.cpp Wed May 11 16:38:59 2011 -0700
+++ b/src/laswriteitemcompressed_v2.cpp Mon May 16 08:01:23 2011 -0700
@@ -236,7 +236,7 @@
@@ -244,11 +244,10 @@
LASwriteItemCompressed_GPSTIME11_v2::LASwriteItemCompressed_GPSTIME11_v2(EntropyEncoder* enc)
@@ -257,7 +256,7 @@
this->enc = enc;
m_gpstime_multi = enc->createSymbolModel(LASZIP_GPSTIME_MULTI_TOTAL);
- m_gpstime_0diff = enc->createSymbolModel(3);
More information about the Liblas-commits
