[Liblas-commits] hg: Fix VLR size bug for instances where so many
points occupy s...
liblas-commits at liblas.org
Mon May 16 19:17:27 EDT 2011
details: http://hg.liblas.orghg/rev/46289289a279
changeset: 2944:46289289a279
user: Gary Huber <gary at garyhuberart.com>
date: Mon May 16 17:15:30 2011 -0600
description:
Fix VLR size bug for instances where so many points occupy such a small space that their index cell overflows a single VLR size limitation.
Subject: hg: Allow array resizing without throwing out of range exception for instances where so many points occupy such a small space that their index cell overflows a single VLR size limitation.
details: http://hg.liblas.orghg/rev/9c6418b585c3
changeset: 2945:9c6418b585c3
date: Mon May 16 17:16:31 2011 -0600
description:
diffstat:
include/liblas/detail/index/indexoutput.hpp | 8 ++++----
src/detail/index/indexoutput.cpp | 2 +-
2 files changed, 5 insertions(+), 5 deletions(-)
diffs (51 lines):
diff -r 993d198e47e0 -r 9c6418b585c3 include/liblas/detail/index/indexoutput.hpp
--- a/include/liblas/detail/index/indexoutput.hpp Mon May 16 12:25:23 2011 -0700
+++ b/include/liblas/detail/index/indexoutput.hpp Mon May 16 17:16:31 2011 -0600
@@ -77,7 +77,7 @@
LIBLAS_SWAP_BYTES_N(src, sizeof(T));
// error if writing past array end
if (static_cast<size_t>(pos) + sizeof(T) > dest.size())
- throw std::out_of_range("liblas::detail::WriteVLRData_n: array index out of range");
+ dest.resize(dest.size() + (std::numeric_limits<unsigned short>::max)());
// copy sizeof(T) bytes to destination
memcpy(&dest[pos], &src, sizeof(T));
// increment the write position to end of written data
@@ -91,7 +91,7 @@
- throw std::out_of_range("liblas::detail::WriteVLRDataNoInc_n: array index out of range");
@@ -103,7 +103,7 @@
std::memcpy(&dest[pos], src, srclen);
if (static_cast<size_t>(pos) + static_cast<size_t>(srclen) > dest.size())
- throw std::out_of_range("liblas::detail::WriteVLRData_str: array index out of range");
pos += srclen;
@@ -113,7 +113,7 @@
- throw std::out_of_range("liblas::detail::WriteVLRDataNoInc_str: array index out of range");
// copy srclen bytes to destination
diff -r 993d198e47e0 -r 9c6418b585c3 src/detail/index/indexoutput.cpp
--- a/src/detail/index/indexoutput.cpp Mon May 16 12:25:23 2011 -0700
+++ b/src/detail/index/indexoutput.cpp Mon May 16 17:16:31 2011 -0600
@@ -295,7 +295,7 @@
boost::uint32_t WritePos = m_DataRecordSize;
// m_TempWritePos is the size of the new data block
// m_DataRecordSize is amount of common data written already
- boost::uint32_t UnwrittenBytes = m_TempWritePos + m_DataRecordSize;
+ boost::uint32_t UnwrittenBytes = m_TempWritePos;
// Make DataRecordSize equal to the total size of the data + common data
m_DataRecordSize += m_TempWritePos;
// write the total size in the common data section
More information about the Liblas-commits
