[Liblas-commits] hg-main-tree: non-const fetches of SchemaLayout
and Schema to su...
liblas-commits at liblas.org
Wed May 25 18:05:03 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/5153948c3c05
changeset: 740:5153948c3c05
user: Howard Butler <hobu.inc at gmail.com>
date: Wed May 25 14:51:25 2011 -0500
description:
non-const fetches of SchemaLayout and Schema to support changing a PointBuffer's schema on-the-fly
Subject: hg-main-tree: use standard sequential iterator verbage
details: http://hg.libpc.orghg-main-tree/rev/0fa58981104e
changeset: 741:0fa58981104e
date: Wed May 25 14:52:04 2011 -0500
description:
Subject: hg-main-tree: add non-const getData method to all someone to fiddle with the data directly (like byte swapping it :)
details: http://hg.libpc.orghg-main-tree/rev/69ff8b3ef58c
changeset: 742:69ff8b3ef58c
date: Wed May 25 17:03:20 2011 -0500
description:
Subject: hg-main-tree: add the generic swap variants as well
details: http://hg.libpc.orghg-main-tree/rev/c2d70b9b6ef4
changeset: 743:c2d70b9b6ef4
date: Wed May 25 17:04:16 2011 -0500
description:
Subject: hg-main-tree: ByteSwapFilter now seems to work (with tests\!)
details: http://hg.libpc.orghg-main-tree/rev/b7891eaf18fe
changeset: 744:b7891eaf18fe
date: Wed May 25 17:04:51 2011 -0500
description:
diffstat:
include/libpc/Endian.hpp | 20 ++++++++
include/libpc/PointBuffer.hpp | 17 +++++++
include/libpc/SchemaLayout.hpp | 5 ++
src/filters/ByteSwapFilter.cpp | 56 +++++++++++++++++++----
src/filters/ByteSwapFilterIterator.cpp | 52 +++++++++++-----------
test/unit/ByteSwapFilterTest.cpp | 77 +++++++++++++++++++++++++++++----
6 files changed, 180 insertions(+), 47 deletions(-)
diffs (truncated from 329 to 300 lines):
diff -r a2d1322426b1 -r b7891eaf18fe include/libpc/Endian.hpp
--- a/include/libpc/Endian.hpp Wed May 25 13:58:37 2011 -0500
+++ b/include/libpc/Endian.hpp Wed May 25 17:04:51 2011 -0500
@@ -88,4 +88,24 @@
*first = x; \
}} while(false)
+# define SWAP_ENDIANNESS(p) \
+ do { \
+ char* first = static_cast<char*>(static_cast<void*>(&p)); \
+ char* last = first + sizeof(p) - 1; \
+ for(; first < last; ++first, --last) { \
+ char const x = *last; \
+ *last = *first; \
+ *first = x; \
+ }} while(false)
+# define SWAP_ENDIANNESS_N(p, n) \
+ do { \
+ char* last = first + n - 1; \
+ *last = *first; \
+ *first = x; \
+ }} while(false)
#endif
diff -r a2d1322426b1 -r b7891eaf18fe include/libpc/PointBuffer.hpp
--- a/include/libpc/PointBuffer.hpp Wed May 25 13:58:37 2011 -0500
+++ b/include/libpc/PointBuffer.hpp Wed May 25 17:04:51 2011 -0500
@@ -98,6 +98,18 @@
return m_schemaLayout.getSchema();
+ // schema (number and kinds of fields) for a point in this buffer
+ inline SchemaLayout& getSchemaLayout()
+ return m_schemaLayout;
+ // convenience function
+ Schema& getSchema()
+ return m_schemaLayout.getSchema();
// accessors to a particular field of a particular point in this buffer
template<class T> T getField(std::size_t pointIndex, boost::int32_t fieldIndex) const;
template<class T> void setField(std::size_t pointIndex, boost::int32_t fieldIndex, T value);
@@ -142,6 +154,11 @@
return m_data.get() + m_pointSize * pointIndex;
+ inline boost::uint8_t* getData(std::size_t pointIndex)
+ return m_data.get() + m_pointSize * pointIndex;
// copy in raw data
void setData(boost::uint8_t* data, std::size_t pointIndex);
diff -r a2d1322426b1 -r b7891eaf18fe include/libpc/SchemaLayout.hpp
--- a/include/libpc/SchemaLayout.hpp Wed May 25 13:58:37 2011 -0500
+++ b/include/libpc/SchemaLayout.hpp Wed May 25 17:04:51 2011 -0500
@@ -72,6 +72,11 @@
return m_schema;
+ inline Schema& getSchema()
+ return m_schema;
/// Fetch total byte size -- sum of all dimensions
inline std::size_t getByteSize() const
diff -r a2d1322426b1 -r b7891eaf18fe src/filters/ByteSwapFilter.cpp
--- a/src/filters/ByteSwapFilter.cpp Wed May 25 13:58:37 2011 -0500
+++ b/src/filters/ByteSwapFilter.cpp Wed May 25 17:04:51 2011 -0500
@@ -37,7 +37,8 @@
#include <libpc/filters/ByteSwapFilterIterator.hpp>
#include <libpc/Schema.hpp>
#include <libpc/PointBuffer.hpp>
+#include <libpc/Endian.hpp>
+#include <iostream>
namespace libpc { namespace filters {
@@ -45,9 +46,9 @@
: Filter(prevStage)
- this->setNumPoints(0);
- this->setPointCountType(PointCount_Unknown);
+ this->setNumPoints(prevStage.getNumPoints());
+ this->setPointCountType(prevStage.getPointCountType());
return;
@@ -64,14 +65,46 @@
return name;
-// append all points from src buffer to end of dst buffer, based on the our bounds
boost::uint32_t ByteSwapFilter::processBuffer(PointBuffer& dstData, const PointBuffer& srcData) const
- // const SchemaLayout& schemaLayout = dstData.getSchemaLayout();
- // const Schema& schema = schemaLayout.getSchema();
+ SchemaLayout& dstSchemaLayout = dstData.getSchemaLayout();
+ Schema & dstSchema = dstSchemaLayout.getSchema();
+ libpc::Schema::Dimensions const& dstDims = dstSchema.getDimensions();
+ dstData.copyPointsFast(0, 0, srcData, srcData.getNumPoints());
+ dstData.setNumPoints(srcData.getNumPoints());
+ for (boost::uint32_t i = 0; i != dstData.getNumPoints(); ++i)
+ boost::uint8_t* data = dstData.getData(i);
+ std::size_t position = 0;
+ for (boost::uint32_t n = 0; n < dstDims.size(); ++n)
+ Dimension const& d = dstSchema.getDimension(n);
+ std::size_t size = d.getByteSize();
+ boost::uint8_t* pos = data + position;
+ SWAP_ENDIANNESS_N(*pos, size);
+ position = position + size;
+ for (boost::uint32_t i = 0; i < dstDims.size(); ++i)
+ Dimension& d = dstSchema.getDimension(i);
+ if (d.getEndianness() == Endian_Little)
+ d.setEndianness(Endian_Big);
+ if (d.getEndianness() == Endian_Big)
+ d.setEndianness(Endian_Little);
// int fieldX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Double);
// int fieldY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Double);
@@ -103,7 +136,8 @@
// assert(dstIndex <= dstData.getCapacity());
- return 0;
+ dstData.setNumPoints(dstData.getCapacity());
+ return dstData.getNumPoints();
diff -r a2d1322426b1 -r b7891eaf18fe src/filters/ByteSwapFilterIterator.cpp
--- a/src/filters/ByteSwapFilterIterator.cpp Wed May 25 13:58:37 2011 -0500
+++ b/src/filters/ByteSwapFilterIterator.cpp Wed May 25 17:04:51 2011 -0500
@@ -60,32 +60,34 @@
// We will read from our previous stage until we get that amount (or
// until the previous stage runs out of points).
- // boost::uint32_t numPointsNeeded = dstData.getCapacity();
- // assert(dstData.getNumPoints() == 0);
- // while (numPointsNeeded > 0)
- // // set up buffer to be filled by prev stage
- // PointBuffer srcData(dstData.getSchemaLayout(), numPointsNeeded);
- // // read from prev stage
- // const boost::uint32_t numSrcPointsRead = getPrevIterator().read(srcData);
- // assert(numSrcPointsRead == srcData.getNumPoints());
- // assert(numSrcPointsRead <= numPointsNeeded);
- // // we got no data, and there is no more to get -- exit the loop
- // if (numSrcPointsRead == 0) break;
- // // copy points from src (prev stage) into dst (our stage),
- // // based on the CropFilter's rules (i.e. its bounds)
- // const boost::uint32_t numPointsProcessed = m_cropFilter.processBuffer(dstData, srcData);
- // numPointsNeeded -= numPointsProcessed;
- // const boost::uint32_t numPointsAchieved = dstData.getNumPoints();
+ boost::uint32_t numPointsNeeded = dstData.getCapacity();
+ assert(dstData.getNumPoints() == 0);
+ while (numPointsNeeded > 0)
+ // set up buffer to be filled by prev stage
+ PointBuffer srcData(dstData.getSchemaLayout(), numPointsNeeded);
+ // read from prev stage
+ const boost::uint32_t numSrcPointsRead = getPrevIterator().read(srcData);
+ assert(numSrcPointsRead == srcData.getNumPoints());
+ assert(numSrcPointsRead <= numPointsNeeded);
+ // we got no data, and there is no more to get -- exit the loop
+ if (numSrcPointsRead == 0) break;
+ // copy points from src (prev stage) into dst (our stage),
+ // based on the CropFilter's rules (i.e. its bounds)
+ const boost::uint32_t numPointsProcessed = m_swapFilter.processBuffer(dstData, srcData);
+ numPointsNeeded -= numPointsProcessed;
+ const boost::uint32_t numPointsAchieved = dstData.getNumPoints();
- return 0;
+ return dstData.getCapacity();
diff -r a2d1322426b1 -r b7891eaf18fe test/unit/ByteSwapFilterTest.cpp
--- a/test/unit/ByteSwapFilterTest.cpp Wed May 25 13:58:37 2011 -0500
+++ b/test/unit/ByteSwapFilterTest.cpp Wed May 25 17:04:51 2011 -0500
@@ -34,30 +34,85 @@
#include <boost/test/unit_test.hpp>
#include <boost/cstdint.hpp>
#include <libpc/drivers/faux/Reader.hpp>
#include <libpc/drivers/faux/Writer.hpp>
#include <libpc/filters/ByteSwapFilter.hpp>
+#include <boost/scoped_ptr.hpp>
+#include <libpc/PointBuffer.hpp>
using namespace libpc;
BOOST_AUTO_TEST_SUITE(ByteSwapFilterTest)
-BOOST_AUTO_TEST_CASE(test_crop)
+BOOST_AUTO_TEST_CASE(test_swapping)
Bounds<double> srcBounds(0.0, 0.0, 0.0, 10.0, 100.0, 1000.0);
+ boost::uint32_t buffer_size = 20;
+ libpc::drivers::faux::Reader reader(srcBounds, buffer_size, libpc::drivers::faux::Reader::Ramp);
- // crop the window to 1/3rd the size in each dimension
- Bounds<double> dstBounds(3.33333, 33.33333, 333.33333, 6.66666, 66.66666, 666.66666);
+ libpc::filters::ByteSwapFilter filter(reader);
+ BOOST_CHECK_EQUAL(filter.getName(), "filters.byteswap");
+ boost::scoped_ptr<SequentialIterator> unflipped_iter(reader.createSequentialIterator());
+ boost::scoped_ptr<SequentialIterator> flipped_iter(filter.createSequentialIterator());
+ const Schema& schema = reader.getSchema();
- libpc::drivers::faux::Reader reader(srcBounds, 1000, libpc::drivers::faux::Reader::Ramp);
- // libpc::filters::CropFilter filter(reader, dstBounds);
- // BOOST_CHECK(filter.getDescription() == "Crop Filter");
- // libpc::drivers::faux::Writer writer(filter);
- // boost::uint64_t numWritten = writer.write(1000);
+ PointBuffer flipped(filter.getSchema(), buffer_size);
+ const boost::uint32_t fliped_read = flipped_iter->read(flipped);
+ BOOST_CHECK_EQUAL(fliped_read, buffer_size);
+ PointBuffer unflipped(schema, buffer_size);
+ const boost::uint32_t unfliped_read = unflipped_iter->read(unflipped);
+ BOOST_CHECK_EQUAL(unfliped_read, buffer_size);
+ int offsetX = schema.getDimensionIndex(Dimension::Field_X, Dimension::Double);
+ int offsetY = schema.getDimensionIndex(Dimension::Field_Y, Dimension::Double);
+ int offsetZ = schema.getDimensionIndex(Dimension::Field_Z, Dimension::Double);
+ int offsetT = schema.getDimensionIndex(Dimension::Field_Time, Dimension::Uint64);
+ BOOST_CHECK_EQUAL(offsetX, 0);
+ BOOST_CHECK_EQUAL(offsetY, 1);
+ BOOST_CHECK_EQUAL(offsetZ, 2);
+ BOOST_CHECK_EQUAL(offsetT, 3);
+ for (boost::uint32_t i = 0 ; i < buffer_size; ++i)
+ double unflipped_x = unflipped.getField<double>(i, offsetX);
More information about the Liblas-commits
