[Liblas-commits] [libLAS/libLAS] c03a24: point at osgeo4w64 instead of osgeo4w
GitHub noreply at github.com
Sun Jul 27 21:10:52 PDT 2014
  Branch: refs/heads/master
  Home:   https://github.com/libLAS/libLAS
  Commit: c03a244857d8be2f97040fed6e84222d8117c46c
      https://github.com/libLAS/libLAS/commit/c03a244857d8be2f97040fed6e84222d8117c46c
  Author: Howard Butler <hobu at hobu.co>
  Date:   2014-07-27 (Sun, 27 Jul 2014)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Commit: 09b687f9ea9602abbd8356f7c1ca4044e5f31baa
      https://github.com/libLAS/libLAS/commit/09b687f9ea9602abbd8356f7c1ca4044e5f31baa
  Changed paths:
    M test/unit/CMakeLists.txt
  Log Message:
  line endings
  Commit: d4fa9bce6966a0771026734b64edb4727655d087
      https://github.com/libLAS/libLAS/commit/d4fa9bce6966a0771026734b64edb4727655d087
  Changed paths:
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M apps/bigfile_boost_iostreams_test.cpp
    M apps/lasblock.cpp
    M apps/laskernel.cpp
    M apps/ts2las.cpp
    M apps/txt2las.c
    M bin/ci/before_install.sh
    M cmake/modules/FindGeoTIFF.cmake
    M doc/_templates/indexsidebar.html
    M doc/_templates/layout.html
    M doc/conf.py
    M doc/development/buildbot.txt
    M doc/index.txt
    M include/liblas/bounds.hpp
    M include/liblas/detail/reader/cachedreader.hpp
    M include/liblas/point.hpp
    M include/liblas/utility.hpp
    M python/tests/Header.txt
    M python/tests/Point.txt
    M python/tests/SRS-GDAL.txt
    M src/CMakeLists.txt
    M src/c_api.cpp
    M src/detail/reader/cachedreader.cpp
    M src/detail/reader/reader.cpp
    M src/detail/reader/zipreader.cpp
    M src/detail/writer/header.cpp
    M src/detail/writer/writer.cpp
    M src/gt_wkt_srs.cpp
    M src/point.cpp
    M src/utility.cpp
    M test/unit/point_test.cpp
    M test/unit/reader_iterator_test.cpp
    M test/unit/reader_test.cpp
    M test/unit/spatialreference_test.cpp
    M test/unit/writer_test.cpp
    M test/unit/zipwriter_test.cpp
  Log Message:
  Merge branch 'master' of https://github.com/libLAS/libLAS
Compare: https://github.com/libLAS/libLAS/compare/6fb937b2323e...d4fa9bce6966
More information about the Liblas-commits mailing list
