[Liblas-commits] [libLAS/libLAS] 699cc5: Remove boost/cstdint.hpp usage and instead move to...
GitHub
noreply at github.com
Sat Jun 7 19:37:06 PDT 2014
Branch: refs/heads/master
Home: https://github.com/libLAS/libLAS
Commit: 699cc5121796c82883a05149bbd8f600749eb9f0
https://github.com/libLAS/libLAS/commit/699cc5121796c82883a05149bbd8f600749eb9f0
Author: Howard Butler <hobu.inc at gmail.com>
Date: 2014-06-07 (Sat, 07 Jun 2014)
Changed paths:
M CMakeLists.txt
M include/liblas/bounds.hpp
M include/liblas/chipper.hpp
M include/liblas/classification.hpp
M include/liblas/color.hpp
M include/liblas/detail/binary.hpp
M include/liblas/detail/index/indexcell.hpp
M include/liblas/detail/index/indexoutput.hpp
M include/liblas/detail/pointrecord.hpp
M include/liblas/detail/private_utility.hpp
M include/liblas/detail/reader/cachedreader.hpp
M include/liblas/detail/reader/reader.hpp
M include/liblas/detail/reader/zipreader.hpp
M include/liblas/detail/writer/header.hpp
M include/liblas/detail/writer/point.hpp
M include/liblas/detail/writer/writer.hpp
M include/liblas/detail/writer/zipwriter.hpp
M include/liblas/detail/zippoint.hpp
M include/liblas/dimension.hpp
M include/liblas/factory.hpp
M include/liblas/filter.hpp
M include/liblas/guid.hpp
M include/liblas/header.hpp
M include/liblas/index.hpp
M include/liblas/liblas.hpp
M include/liblas/point.hpp
M include/liblas/schema.hpp
M include/liblas/spatialreference.hpp
M include/liblas/transform.hpp
M include/liblas/utility.hpp
M include/liblas/variablerecord.hpp
M src/c_api.cpp
M src/chipper.cpp
M src/classification.cpp
M src/color.cpp
M src/detail/index/indexcell.cpp
M src/detail/index/indexoutput.cpp
M src/detail/reader/cachedreader.cpp
M src/detail/reader/header.cpp
M src/detail/reader/zipreader.cpp
M src/detail/zippoint.cpp
M src/dimension.cpp
M src/factory.cpp
M src/header.cpp
M src/index.cpp
M src/point.cpp
M src/schema.cpp
M src/spatialreference.cpp
M src/transform.cpp
M src/utility.cpp
M src/variablerecord.cpp
M test/unit/header_test.cpp
M test/unit/tut/tut_assert.hpp
Log Message:
Remove boost/cstdint.hpp usage and instead move to <stdint.h>. Turn up
the warning noise and clean up issues related to them.
Commit: 03cca35d55be9879d9ae7c26e97bb9a9aacaa5ac
https://github.com/libLAS/libLAS/commit/03cca35d55be9879d9ae7c26e97bb9a9aacaa5ac
Author: Howard Butler <howard at hobu.co>
Changed paths:
M CMakeLists.txt
M src/c_api.cpp
M src/chipper.cpp
M src/color.cpp
M src/dimension.cpp
M src/factory.cpp
M src/header.cpp
M src/index.cpp
M src/point.cpp
M src/schema.cpp
M src/transform.cpp
M src/utility.cpp
Log Message:
Merge pull request #43 from libLAS/remove_boost_int_types
Remove boost/cstdint.hpp usage and instead move to <stdint.h>. Turn up the warning noise and clean up issues related to them.
Compare: https://github.com/libLAS/libLAS/compare/d77d09f01181...03cca35d55be
More information about the Liblas-commits
