[Liblas-commits] [libLAS/libLAS] 9e9f14: Fix memory leak in C API
GitHub
noreply at github.com
Thu Mar 30 21:40:32 PDT 2017
Branch: refs/heads/master
Home: https://github.com/libLAS/libLAS
Commit: 9e9f140de0ce268348b3b4f5f397d27c593413fc
https://github.com/libLAS/libLAS/commit/9e9f140de0ce268348b3b4f5f397d27c593413fc
Author: Panagiotis Koutsourakis <kutsurak at monetdbsolutions.com>
Date: 2017-03-30 (Thu, 30 Mar 2017)
Changed paths:
M src/c_api.cpp
Log Message:
Commit: 7654ca9495e54af97fba397ba9be0974f81dd4de
https://github.com/libLAS/libLAS/commit/7654ca9495e54af97fba397ba9be0974f81dd4de
Changed paths:
M apps/CMakeLists.txt
A apps/memleak_test.c
Log Message:
Add a small test for memory leak
This is just a smaller version of the bigfile_test, with some extra
deallocations.
Commit: c3804c07f42fa6e186613bad6fa97d9e175a86ab
https://github.com/libLAS/libLAS/commit/c3804c07f42fa6e186613bad6fa97d9e175a86ab
Author: Howard Butler <howard at hobu.co>
Changed paths:
M src/c_api.cpp
Log Message:
Merge pull request #118 from kutsurak/master
Memory leak in the C API
Compare: https://github.com/libLAS/libLAS/compare/ed15b96b451d...c3804c07f42f
More information about the Liblas-commits
