[Liblas-commits] [libLAS/libLAS] 1d8647: cmake: remove unused target names
GitHub
noreply at github.com
Wed Oct 31 10:41:45 PDT 2018
Branch: refs/heads/master
Home: https://github.com/libLAS/libLAS
Commit: 1d86471c13a6536b233fe4c9cd0f74a4a34163a0
https://github.com/libLAS/libLAS/commit/1d86471c13a6536b233fe4c9cd0f74a4a34163a0
Author: Ben Boeckel <ben.boeckel at kitware.com>
Date: 2018-10-31 (Wed, 31 Oct 2018)
Changed paths:
M CMakeLists.txt
Log Message:
Commit: edb793b2880dc1f15cf65bcd22ee8cbc1aa843cf
https://github.com/libLAS/libLAS/commit/edb793b2880dc1f15cf65bcd22ee8cbc1aa843cf
Changed paths:
M apps/CMakeLists.txt
M cmake/liblas-config.cmake.in
M src/CMakeLists.txt
M test/sample/CMakeLists.txt
M test/unit/CMakeLists.txt
Log Message:
cmake: use consistent target names
Instead of using the target name to influence the output library name,
use a consistent target name and use the `OUTPUT_NAME` property to
control the output filename.
Commit: e14cbd6fde01b8ae7e7336bd050b5216bbf56764
https://github.com/libLAS/libLAS/commit/e14cbd6fde01b8ae7e7336bd050b5216bbf56764
Changed paths:
M CMakeLists.txt
Log Message:
cmake: use target_include_directories
This allows the installed targets to be used via `target_link_libraries`
without also needing to manage include directories.
Also move the `cmake_minimum_required` to the top of the file. It should
be the first CMake command in top-level `CMakeLists.txt`.
Commit: b5933bd0f6f1fdd07744441d878ecbd174ae5b62
https://github.com/libLAS/libLAS/commit/b5933bd0f6f1fdd07744441d878ecbd174ae5b62
Author: Howard Butler <howard at hobu.co>
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #153 from mathstuf/cmake-imported-targets
Cmake imported targets
Compare: https://github.com/libLAS/libLAS/compare/1d006edbe01b...b5933bd0f6f1
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the Liblas-commits
