[Liblas-devel] [liblas] Hello world
"Martín RV (OPENGeoMap)" martin at opengeomap.org
Wed Apr 9 13:53:43 EDT 2008
Hi:
> Would you have any comments to the liblas?
This days i am working in other programming task projects, but in a
couple a weeks i will go back to the viewer.
We have to create a desktop viewer with your library , but a web viewer
also. We are thinking in a web software similar to :
http://archive.cyark.org/sites.php?v=media&t=3D%20Point%20Cloud
This was build by java3d. I want implement it in shockwave 3d.
With our lidar viewer we want have a Lasedit free software. ;-)
In my job we use terrasolid software to work. I would like create
similar free software :-D  using your library.
> Have you tried to build/run/use it?
I was working only 2 days, but with Martin Isenburg
<http://www.cs.unc.edu/%7Eisenburg/lastools/> library, because i don´t
know your library. I had many problems, because i could´t compile the
library in mingw, only with visual 6 compiler.  I want develop software
in a easy portable way. Using c++ cookbook from orrealy i am learning
techniques to create crossplatform software in c++.
> How do you like its API?
Well i am not a c++ expert by now, but i promise learn hehe. In my job
we work with ruby(ruby-gnome), C/gobject/gtk, c#/.NET (Microstation,
Autocad, arcgis). I have  with good OOP skills and can understand your
code well. I only can say this hehehe
By know i solve my c++ problems (templates, overload) with glib
(http://library.gnome.org/devel/glib/stable/glib-data-types.html) and
VALA (http://live.gnome.org/Vala).
I know c++, but can be  my first c++ professional work :-[ .
I can see Martin Isenburg <http://www.cs.unc.edu/%7Eisenburg/lastools/>
library very easy to understand and use, but yours library is more
complete and portable, and it´s a open community project.
> Is there anything missing or that would be nice-to-have included?
I like binary files for engineering , but i don´t like LAS format
specification at all hehe, because use little endian, not a cross
platform binary file.
 This days i am working with SQlite, a great local database with direct
binary connection. Binary is perfect for engineering applications, and
it´s used in all mobile devices (Nokia, motorola, palm,
sony-erickson,...) thanks to sqlite.
We have also a binary XML version
(http://en.wikipedia.org/wiki/Extensible_Binary_Meta_Language)
it´s crazy have support for other lidar formats????.
Do you like LAS format?
> Looking forward your comments!
> Greetings
Many job to do :-D :-D :-D :-D :-D
Regards.
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20080409/cc68276b/attachment.html
More information about the Liblas-devel mailing list
