[Liblas-devel] .net/mono bindings in c#
    Mateusz Loskot
    mateusz at loskot.net
    Sat Aug  9 08:44:59 EDT 2008
Howard Butler wrote:
> On Aug 7, 2008, at 4:23 AM, Martin Rodriguez wrote:
>> Modules:
>> - Reader
>> - Writer
>> - LASPoints
>> - LAS Header
>> - Exception class
>> - Iterator class
>> - c->C# API
> I saw a Trac login on http://liblas.org under the name 'martin' and I
> assumed that is you.  Anyway, I have given you svn commit access, and I
> created a csharp directory in which you can layout and place your
> bindings.
Dear Fellows,
I'd have one suggestion to the .NET/Mono bindings submission.
Martin, if you don't mind, I'd be thankful if you could first submit a
Ticket for this task, with a short or very short summary of this motion.
Then, please use the ticket number in SVN log message while you will be
importing your module to the repo. The preferred convention is something
like this:
svn ci -m "Importing .... (#23)"
#23 is a sample ticket number
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
