[Liblas-devel] .net/mono bindings in c#
Mateusz Loskot
mateusz at loskot.net
Thu Aug 14 06:41:56 EDT 2008
Martin Rodriguez wrote:
>> But you don't have to run IDE to build them.
>> You can use VC# project files from command line:
>> devenv.exe myprj.sln
> Hehe. But i love windows and buttons.
But you can't use any automation with buttons :-)
For instance, nightly builds generation, Buildbot and others
http://buildbot.osgeo.org/
Also, Linux users are familiar with 3 commands then execute to build and
install new software:
./configure
make
make install
With "buttons", users are unable to follow their well-known path of
installation, unless we add the .NET/Mono to Autotools and NMAKE makefiles.
In community-driven projects, buttons are of little help.
That's why NAnt and other powerful builders were invented.
>> Anyway, please document on the Wiki how users should build .NET bindings.
> I´ll try investigate all kind of systems to distribute .net code with
> autotools and so.
If you don't know autotools or nmake, I can add it but I need you to
document building process using your project files, then I will know
what to port to autotools.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
