[Liblas-devel] RE: LAS header major and minor version number
Steve Harwin SteveH at myriax.com
Thu Dec 18 19:02:14 EST 2008
Thanks Martin,
The problem was on my end, we have the ability to abort the read when the user interface triggers it and I was not calling dispose in the finally block when that abort exception triggered the read to stop.
Thanks for all your efforts on the .NET bindings.
Cheers
Steve
From: Martin Vales [mailto:martinvales00 at gmail.com]
Sent: Thursday, 18 December 2008 7:08 PM
To: Liblas-devel at lists.osgeo.org
Cc: Steve Harwin
Subject: Re: [Liblas-devel] RE: LAS header major and minor version number
2008/12/18 Steve Harwin <SteveH at myriax.com>
The had a another look at my code whilst trying to come up with a sample
that shows the problem and I found that there was a chance that I was
not always disposing the LASReader object, the dispose call is now in a
finally block and since making that change I have not been able to
replicate the version issue.  I will keep testing and get back to you
with a sample if the problem reappears.
Hi steve.
humm. I believe the garbage collector call dispose when they think it´s time. We can call dispose using dispose manually like in GDI graphics. Perhaps i am wrong??.
The IDisposable interface defines a pattern (with language-level support) that provides a deterministic
mechanism for freeing unmanaged resources and avoids the garbage collector-related problems inherent
with destructors.
If we would use the typical c++ destructor:
~killCScharpCodeClass()
// i am Kill
we can not call the destructor by hand but using dispose we can.
The doub i have it´s if we have to call dispose always or only when we want ensure the destructor was called immediately.
Regards.
	Thanks
	Steve
	Liblas-devel mailing list
	http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20081219/4f90b3d0/attachment.html
More information about the Liblas-devel mailing list
