[Liblas-devel] Number of points by return
Howard Butler hobu.inc at gmail.com
Wed Jan 2 11:58:50 EST 2008
TerraScan doesn't appear to set the point returns by header info.  A
file from the Iowa DNR GeoTree download shows that they aren't set... http://liblas.org/ticket/10
Maybe we can't depend on this.
Howard
On Jan 2, 2008, at 9:35 AM, Mateusz Loskot wrote:
> Kollasch, Pete [DNR] wrote:
>> That rule is fully consistent with my understanding of how LiDAR data
>> works.
> Pete,
> Thanks for confirmation.
>> The only reason I would hesitate to assume it as a rule would be if
>> making the assumption would cause reading data from a broken data
>> set to
>> fail.  If using the assumption causes a failure to read an
>> inconsistent
>> dataset, that's not very robust.
> Yes, I agree with your opinion.
> Perhaps only warning should be issued if verbose mode requested,
> so user is well-informed.
> Best regards
> Mateusz Loskot
> http://mateusz.loskot.net
> Liblas-devel mailing list
> Liblas-devel at mail.hobu.net
> http://mail.hobu.net/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
