[Liblas-devel] 0.9.6 Released
Howard Butler
hobu.inc at gmail.com
Wed May 14 16:38:17 EDT 2008
Pete,
I think this may be a bug in the Python bindings, not libLAS itself.
There are also a number of other small issues I see with your script,
however. Comments inline...
On May 14, 2008, at 1:59 PM, Kollasch, Pete [DNR] wrote:
> Howard,
> I have encountered a small problem with the Python bindings. I
> wrote a Python program to copy only class 2 into a new file. It
> also counts points read and written, etc. The program follows:
> import math
> from liblas import file
> f = file.File('f804.las')
> f.open
open is called for you when you instantiate the liblas.file.File, so
you shouldn't have to do this manually. Also, f.open is very
different than f.open() in Python. f.open is a reference to the
function open, f.open() actually *calls* the open method.
> h = f.header
> j = 0
> i = 0
> for p in f:
> j += 1
> if j % 100000 == 0:
> print '.',
> if p.classification == 2:
> #print p.x, p.y, p.z
> #print 'return ', p.return_number, ' of ', p.number_of_returns
> #print 'cls = ', p.classification, ' edge = ',
> p.flightline_edge
> i += 1
> print
> print i, ' points will be written'
I would try closing and reopening the file you are reading from at
this point. It might be possible that the iterator you are using
isn't actually at the end of the file. If so, this would be a bug or
at least some poor behavior of the Python bindings and we'll have to
think about how to make it better.
f.close()
f.open()
This will effectively reset the reader.
> h.set_pointrecordscount(i)
> g = file.File('outlas4.las', h, 'w')
> j = 0
> i = 0
> for p in f:
> j += 1
> if j % 100000 == 0:
> print '.',
> g.write(p)
> i += 1
> print
> print i, ' points were written'
> f.close
> g.close
f.close()
g.close()
closing a file that is opened for write effectively flushes all write
operations. Note that you shouldn't have to manually close() the file
if you are running this program as a shell script because the __del__
method (think of this as the file.File destructor method) gets called
when the Python interpreter goes away and liblas.file.File.__del__
attempts to call close() too.
Another suspicion I have has to do with the header you are copying:
> Header Size 227
> Offset to Point Data 229
> Number Var. Length Records 3
If there are three variable length records, the offset to the point
data should be much larger than 229. 229 would be the offset if there
are no VLRs. This is a bug/feature that I am working on fixing
currently http://liblas.org/ticket/50
A simple confirmation would be to do
from liblas import header
h = header.Header()
h.dataformat_id = 1 #make sure to write point format 1, which has
time values.
and use this header for the file you are writing instead of copying it
from the file you are reading from.
I have been working on a tutorial on the wiki http://liblas.org/wiki/PythonTutorial
If you want to register (link for registering is in the top right
part of the site below the search box) for the site and add your
experience and code to the site where you think it is appropriate, it
would be much appreciated :)
I see your lasinfo output says 0.9.5. Are you running the 0.9.5
Python bindings too, or is that 0.9.6? There were numerous fixes for
0.9.6, especially to the Python bindings. http://liblas.org/wiki/0.9.6
> My concern is that when this process is completed, there is a
> slighltly smaller number of points in the output file than the
> program or the class counts given by lasinfo -c for the input file
> indicates.
> In my example, the program gives the following output:
>>>> ================================ RESTART
> 2028818 points will be written
> . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2028818
> points were written
> After doing this, the lasinfo utility reports on the output file as
> follows:
> C:\allstuff\Software\liblas\0.9.5>.\bin\lasinfo -c outlas4.las
> Header Summary
> File Name: outlas4.las
> Version: 1.0
> Source ID: 0
> Reserved: 0
> Project ID/GUID: '00000000-0000-0000-0000-000000000000'
> System Identifier: ''
> Generating Software: 'CPS/RTW LAS Lib v1.08'
> File Creation Day/Year: 0/0
> Header Size 227
> Point Data Format 1
> Point Data Record Length 28
> Number of Point Records 2028818
> Number of Points by Return 3561441 3810 360 9 0
> Scale Factor X Y Z 0.001000 0.001000 0.001000
> Offset X Y Z 0.000000 4000000.000000 0.000000
> Min X Y Z 395999.999000 4803999.999000 350.069000
> Max X Y Z 397999.989000 4805999.989000 383.320000
> end of file encountered
> Point Inspection Summary
> Header Point Count: 2028818
> Actual Point Count: 2028682
> Minimum and Maximum Attributes (min,max)
> Min X,Y,Z: 395999.999000,4803999.998000,350.069000
> Max X,Y,Z: 397999.989000,4805999.989000,363.256000
> Bounding Box: 396000.00,4804000.00,397999.99,4805999.99
> Time: 496966.080479,498706.670229
> Return Number: 1,4
> Return Count: 0,1
> Flightline Edge: 0,0
> Intensity: 0,255
> Scan Direction Flag: 0,0
> Classification: 2,2
> (0) 2026248 (1) 2159 (2) 269 (3) 6 (4) 0
> Total Points: 2028682
> Number of Returns by Pulse
> (1) 2026248 (2) 2159 (3) 269 (4) 6 (5) 0 (6)
> 0 (7) 0
> Total Pulses: 2028682
> Actual number of points by return
> is different from header (actual, header):
> (2026248,3561441) (2159,3810) (269,360)
> (6,9) (0,0)
> Point Classifications
> 2028682 Ground (2)
> Notice the disparity between the points counted by the program, and
> inserted in the header, (both 2028818) and the actual point count
> (2028682).
> Is it possible that some buffer is not being flushed? How do you
> force it to flush the file? Any ideas?
> Pete
More information about the Liblas-devel
