[Liblas-devel] PROJ4 / Georeference info?
Jason Woolard Jason.Woolard at noaa.gov
Fri Oct 31 17:47:06 EDT 2008
hey Howard,
That's strange I found 3 libtiff.dlls and they are all dated 9/1/2008.
Howard Butler wrote:
> aha!
> That's because you have an older libtiff.dll ahead of the one in
> c:\python2x\DLLs in your PATH and it is being picked up.  Search for
> all of your libtiff.dlls and check the dates on them.  The one that
> should be used (make sure it is first on your PATH), is dated 9/1/2008
> On Oct 31, 2008, at 3:49 PM, Jason Woolard wrote:
>> Sure thing. I did get a dialog error running it at the Windows CMD.
>> See attached.
>> Could it possibly be conflicting with something?  I have FWTools
>> installed but I removed everything else Python related .
>>> On Oct 31, 2008, at 1:39 PM, Martin Vales wrote:
>>>> This is the same error in .NET.
>>>> The CAPI is not public for Dynamic loaders like Ctypes or p/invoke..
>>> I have no trouble running the Python unittests under windows with
>>> Python 2.4 or 2.5 and ctypes.  This is using ctypes and the
>>> liblas1.dll that I have built and included in both the windows .zip
>>> file *and* the PyPI libLAS bindings.  This dll was built with:
>>> __declspec(dllexport)
>>> declarations.
>>> Jason,
>>> Could you try running your script from a cmd.exe instead of in the
>>> Python IDE.  Maybe a dialog will come up when ctypes tries to access
>>> the dll and state which procedure it can't find.
>>> Howard
>> <libtiff_error.bmp>
More information about the Liblas-devel mailing list
