[Liblas-devel] point source id
Mateusz Loskot
mateusz at loskot.net
Thu Apr 2 19:35:44 EDT 2009
Howard Butler wrote:
> On Mar 30, 2009, at 12:07 PM, Mateusz Loskot wrote:
>> Volker Wichmann wrote:
>>> Hi,
>>> I've a question regarding the handling of the point source id:
>>> I just realized that neither txt2las nor las2txt support psid, the
>>> corresponding code seems to be commented out in trunk. Is there any
>>> reason for this?
>> What corresponding code you are referring to?
>> Recently, Point Source ID access has been implemented:
>> http://liblas.org/ticket/87
>> http://liblas.org/ticket/115
> It is commented out because the Point Source ID stuff didn't exist until
> 1.2, but it didn't make it into las2txt and txt2las for the 1.2 release.
> I have fixed this issue in both trunk and the 1.2 branch
> http://liblas.org/ticket/121 If it is convenient for you to build from
> source, I would suggest checking out a copy of the code from subversion
> http://liblas.org/svn/trunk
Hobu,
Right, thanks for reminding.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
