[Liblas-devel] Improved SRS support in liblas
Howard Butler
hobu.inc at gmail.com
Fri Feb 6 17:03:08 EST 2009
On Feb 6, 2009, at 3:16 PM, Michael Rosen wrote:
>> Proj.4 can be more expressive than WKT in many instances, but the
>> GeoTIFF keys are our limiting factor.
> If we store the SRS as a WKT can we, in principle, store all the
> GeoRef info in the LAS file?
If GTIFSetFromOGISDefn and GTIFGetOGISDefn allow us to transitively
preserve authority names going in and out of GTIF*, I think we're
good. I propose that we implement the following for the next libLAS
release:
- If GDAL is linked in, we embed/compile our own copies of
GTIFGetOGISDefn and GTIFSetFromOGISDefn and use GDAL's wkt as the
primary storage mechanism (new functionality).
- If GDAL is linked in, provide the ability to set coordinate system
definitions on a LASReader or LASWriter to define the output
coordinate system. If an output coordinate system is set, the points
will be reprojected (from what is defined in the LASHeader to what is
defined on the LASWriter/LASReader). If nothing is set on either the
LASReader or LASWriter, no projection happens. (GDAL's lack of
vertical datum translation support complicates this... maybe we should
use cs-map, which provides VERTCON which should be what most people
need)
- If no GDAL is not linked, but libgeotiff is, revert to using proj4/
libgeotiff (current behavior) and provide naked access to the
interpreted/converted GTIF* (new functionality).
- Provide a flag on the LASReader/LASWriter that skips the
interpretation of the SRS VLR records entirely (new functionality) so
people who just want/need to blindly copy data can do so without penalty
- If no GDAL or libgeotiff is linked, ignore srs information in the
header entirely (current behavior).
I'd be interested to hear if people think these ideas are a good
approach. They are mostly (better) extensions of what we're doing now.
>> I do know that GDAL doesn't support many of the vertical datums
>> descriptions that GeoTIFF keys have.
> Are you sure? Perhaps that was only true of older versions?
> Here's the list of VCRS that geotiff supports: http://www.remotesensing.org/geotiff/spec/geotiff6.html#6.3.4.1
> I think this is the VCRS that gdal 1.5.2 supports: http://gdal.sourcearchive.com/documentation/1.5.2-2/epsg__vertcs_8inc-source.html
Both of these are links to GeoTIFF's epsg_vert file, not GDAL's.
Geotiff supports the description of a few vertical datums, but GDAL/
OSR doesn't do anything with them.
> According to the Geotiff spec, there are no specific Vertical Datum
> codes currently defined.
I think there's a few. The URLs you linked have:
00041 ValuePair(VertCS_North_American_Vertical_Datum_1929, 5102)
00042 ValuePair(VertCS_North_American_Vertical_Datum_1988, 5103)
More information about the Liblas-devel
